Viewing 2 reply threads
    • #32854
      Steen Carstensen
      You can run both, the deciding factor is which weight you run at. Most 30 mm chassis max out at around 390 lbs, after that you would want to use a 32 mm.
    • #33235
      Joey Guyon
      You may want to contact Msquared in Utah. They prefer the 32mm and can give you their reasons. For the most part guys run the 30mm though
    • #33509
      Carl Beavers
      Like Steen said – It depends on your weight.
      I race shifter with 2013 Kosmic Lynx (aka:TonyKart) at 210# with gear and run the 32mm, kart and driver weigh ~420#.
