Viewing 2 reply threads
    • #41640
      Ted Hamilton
      Just curious if anyone’s tried a 180* header with a “standard” kart pipe on the exit for shifter kart exhaust…  Would be interesting.
    • #41758
      Greg Wright
      Can’t see it working. “standard” kart pipes are designed to have as wide a power band as possible and shifter pipes are designed to work in a narrower rpm range which is usable due to the tranny.
    • #41767
      Ted Hamilton
      I guess on shifters with powervalve plugs, it wouldn’t benefit much…if it was on an actual bike where the rpm ranges were wider, then maybe.  Would be interesting to see an ICC pipe on a MX engine on a dyno…
      • #41872
        William Martin
        It’s mostly about the exhaust port timing. If it’s similar to the ICC spec in degrees, it should work just fine.
