Viewing 3 reply threads
    • #29811
      Austin Garrett
      Found this kit for $40.00 if anyone else needs the link.
      https://www.lightningkarts.com.au/index.php?select=66&productType=378&product=3735
    • #29818
      Steen Carstensen
      I don’t know where you live, but that link is from a shop in Australia. Should be able to find a supplier closer to home.
    • #29991
      FREDDY SANDOVAL
      Dude!
      You don’t need all those extra parts, with springs and pistons, just clean, hone and install new seals with assembly lube, or brake fluid.
      You can find all those seals at FASTECH-RACING.COM
      Just go on the menu for brake group
      And select the desired diameter ( they all come in MM increments )
      These guys are really good, and ship super fast.
      Good luck
    • #30008
      Austin Garrett
      Thanks for the reply Freddy. I think they are 19mm and 22mm pistons (will double check tomorrow) but much cheaper than the kit. Thanks for the recommendation
