Viewing 2 reply threads
    • #41985
      Connor Tebbe
      I’m curious if anyone has done back-back testing with the new OTK M6 bodywork (especially at a track like Jacksonville or Newcastle). I know OTK touts it as being developed in the wind tunnel, just curious if anyone has seen measurable results on the track.
      DT
    • #42023
      Tim Salvino
      I dont care what bodywork you have, if you are running the big plastic CIK rear bumper, you will have a TON of drag. Switching to a metal tube rear bumper will give you a noticable gain above ~60mph.
      • #42225
        Connor Tebbe
        Luckily I have the option of either bumper and have been running the tubular one. I have been looking at testing some different noses to see if any work better than others in the draft. OTK seems to be the only ones that work on that, and when you look at the size/shape of the noses it shows. They really try to cover/deflect over the front tires and driver’s feet.
    • #42238
      Gary Lawson
      I wouldn’t get too carried away comparing OTK bodywork. As soon as you touch someone with it they get dented in and likely become worse than any nose on the market as far as aerodynamics. No cik nose is going to direct the air over/around the driver so any differences between styles will be negligible IMO.
