Viewing 4 reply threads
    • #31533
      Jim Silverheels
      Check the rotor to see if the magnets are strong. This was the cause for us on several engines. Why they lost their magnetism I don’t know but this WAS THE CULPRIT.
    • #31574
      oldmeatwad
      Thanks Jim will do. Additionally, I emailed PRD to see if they can provide voltage and ohm specs for the CDI module. If the voltage coming from the CDI is wrong, then I know we have another bum module and/or something is killing the module. I say this as the Kart did start on its own within 2 seconds before we shut it off and then encountered the no start condition.
      LINK TO PHOTOS OF EASYSTART PIN-OUT THAT I NEED SPECS FOR:  pics
    • #31908
      Lawrence Doty
      Will it start with an external starter?
      What carb are you using?
      Can you see fuel moving in the line while cranking?
      Reason’s my PRD didn’t start….
      1) Wire connections at starter loose. The crimps looked tight but they weren’t…
      2) Wire rubbed against chassis and grounded.
      3) Air filter boot torn.
      4) carb settings too lean.
    • #33144
      James Churchill
      I would love to know the outcome of this for general knowledge when dealing with my PRD Fireball.
    • #33146
      oldmeatwad
      OUTCOME –
      The Coil was bad and fried the CDI. This made perfect sense as the CDI I replaced lasted for 1 start and then was toast. With the new coil and CDI it literally starts in 5 seconds on first button push.
      That aside – HUGE PROPS to Art and Rod at RLV (http://www.rlv.com/). These guys were nothing but pros all the way. Lots of same day emails, extremely responsive and even brought in a test kart to confirm what the readings should have been. In the end I shipped them our entire Easystart system that they diagnosed the same day it arrived in cali. I cant say enough about the service I received and how happy I am to have these guys backing us up.
      Concerning the technicals – here it is.
      FACTORY = Known good easystart system
      ME = the readings from our kart before the repair. You can see readings off the relay were definitely not right and our CDI was .11V off.
      BATTERY
      FACTORY:  12.7v / 10.4v on crank
      ME: 12.58v / 10.55v on crank
      RELAY GREEN WIRE
      FACTORY: .63v
      ME: .19v
      RELAY WHITE WIRE
      FACTORY: 9v
      ME: 9.9v
      BLACK & YELLOW TO COIL FROM CDI:
      FACTORY: .43
      ME: .32 on crank
      RED & WHITE/GREEN CDI
      FACTORY:  9.23 ohmns
      ME:  9.23 ohmns
      TRIGGER ON STATOR WHITE/RED
      FACTORY:   .12 ohms with switch off
      ME:  .12
      FACTORY:  .17 ohms with switch on
      ME: .12
      FACTORY:  .4 volts cranking
      ME: .3
      I hope this helps others in the future. I will carry these readings in my box from this day forward.
