Ocala Gran Prix - LB
Ribtect - SS (non-flash)
KG Plastics - FB
Wb3a
Goto page 1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Wed Oct 13, 2010 9:05 pm    Post subject: Wb3a Reply with quote
How many Wb3a carbs do you own?
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Jim White
PostPosted: Thu Oct 14, 2010 7:48 am    Post subject: Reply with quote
5 total.
How many do I use?
Only one.
It just seems to run and tune better than any of the others Very Happy
Brian Mead
PostPosted: Thu Oct 14, 2010 10:48 am    Post subject: Reply with quote
6 plus parts for another and a good ol wb24. Still runs good btw.
PostPosted: Thu Oct 14, 2010 1:13 pm    Post subject: Reply with quote
I'd have to go through a few boxes but I have about 10 but, I have 5 engines. It would be cool to dyno all 10, there has to be at least one really good one.
Gif Cool
John Mulvihill
PostPosted: Thu Oct 14, 2010 3:18 pm    Post subject: Reply with quote
Hi Walt,
About a dozen. Track tested 8 of them a few years back. 6 were the same. One was a second faster. One was a second slower. Ran the fast one and the slow one against each other and there was two seconds difference.
I still haven't really figured out why. I've noticed variations in where the jets are drilled. And, when I spray carb cleaner through the passages the spray patterns differ.
With the dyno up and running this may be another winter project........
John
I bowl overhand..........
Steve O'Hara
PostPosted: Thu Oct 14, 2010 11:27 pm    Post subject: Reply with quote
John,
Just curious.... what kind of track did you do the testing on and how long does a lap take?
Steve O'Hara
John Mulvihill
PostPosted: Fri Oct 15, 2010 4:28 pm    Post subject: Reply with quote
Hi Steve,
Roadracing at Daytona back when the event was longer and there was more practice time. Forgot the exact lap times but the driver was extremely consistant (better than me). 2.5 minute laptimes? The lap times of the good carb vs the 'other 6' was very consistently 1 second better. The bad carb was pretty much 1 second slower.
We then ran the good carb vs the bad carb within one practice session and there was two seconds difference,
This was without a trigger so we could switch them quickly. All of the carbs had fulcrum heights and pop-off's set as close as possible.
I'm sure that I didn't have all of the variables covered. So it was not as purely scientific as possble. That one good carb has seemed to be better than other carbs whenever I've been able to run it back to back against another. I'd love to know what makes it better so I could make others perform as well. Open to any and all suggestions.
Now that we can do some controlled testing, I can look for more 'good' carbs. However, it would be better ($$$$$) for most folks to be able to modify one carb rather than buying a bunch for testing.
Any thoughts?
John
PostPosted: Fri Oct 15, 2010 6:20 pm    Post subject: Reply with quote
Here is what I suggest, send me the carb for a detailed examination under 5x magnification.
Gif Cool
Steve O'Hara
PostPosted: Fri Oct 15, 2010 10:46 pm    Post subject: Reply with quote
John,
Back in the day when I was running the KT100s on the long road race tracks I had one carb that seemed to work better than the rest too.
One second on the long tracks sounds about right. I don't think it had anything to do with air flow rates but we never flow bench tested the carbs.
The good carb just seemed to tune better and the engine ran better through the acceleration sections but did not show higher peak rpm.
If I still had it I would send it to you to play around with but it is long gone now.
Keep us posted on your testing... it would be interesting to learn what you find.
Steve O'Hara
Kyle Prokup
PostPosted: Sat Oct 16, 2010 8:24 pm    Post subject: Reply with quote
I believe we have 6 or 7, but I only use one. In the KPV classes, the one that I do use requires no leaning at the starts on the low speed. Its fast Twisted Evil.
Kyle Prokup Racing
Tony Kart EVRR
John Mulvihill
PostPosted: Sat Oct 16, 2010 9:04 pm    Post subject: Reply with quote
Hi Steve,
I thought this link to Kinsler might have some bearing:
http://www.kinsler.com/Cat_32_Pgs/Cat_32_4_09_Pg_202.pdf
The drilled Walbro passages resemble the passage in the Kinsler article (that didn't have a radius) except that the Walbro passages are next to internal obstructions and have twists and turns.
When I have a chance, I'll do a visual comparison and see if anything is obvious. I have some jewelers loupes so I can do up to a 10X close-up look (Walt--I'll see your 5X and raise it to 10X<LOL>)
Its gonna be a long winter.......
John
al nunley
PostPosted: Sat Oct 16, 2010 10:26 pm    Post subject: Reply with quote
You don't think people actually use "Drills" do you? I'm guessing you're using the term "drilled" as just a "for instance", right? I can't imagine someone actually using "drills" to open the passages in that carb.
When I did them I used .001”, under max, reamers. You can get these reamers in most any size from Rutland Tool, or most any of the big tooling shops.
I know I’m just showing off, but it’s true.
JIM SILVERHEELS
PostPosted: Sun Oct 17, 2010 11:43 am    Post subject: So Reply with quote
So the question is, what makes a Walbro atomize better.
John Mulvihill
PostPosted: Sun Oct 17, 2010 12:50 pm    Post subject: Reply with quote
Hi Al,
I use small reamers. but I have no idea what Walbro does. They may not really care that much since you have to drill a hole before it can be reamed. Just drilling would be so much easier.
Hi Jim,
Atomize better and deliver the fuel you need through the rpm range.
John
al nunley
PostPosted: Sun Oct 17, 2010 1:47 pm    Post subject: Reply with quote
Hi Al,
When I was drag racing, I "heard" that carb jets were "punched" out, but I've never seen or heard for sure.
Seems like I've seen reamer/drills. A short drill, on the end, to open the hole and a reamer to finish it. It would be interesting to find out how they do it.
Page 1 of 7
DB time: 0.165069 (43.75%), total time:0.377328, queries:38
