2D2W - LB
RLV - SS
SCCA Enterprises - FB
dellorto carb
Goto page Previous  1, 2
shaun everard
PostPosted: Thu Jun 24, 2010 8:49 am    Post subject: dellorto carb Reply with quote
I currently have a 39mm dellorto but was going to try and get the data from that to then go to the agents for mikuni`s and get there equivalent in the mikuni as i have a 39mm mikuni and a 41.5mm carb both are mikuni tm flat slide pro series carbs.
Cheers for the help Shaun
Riley Will
PostPosted: Thu Jun 24, 2010 10:15 am    Post subject: Reply with quote
Ian, I already knew the answer:) Just getting other people's grey matter pulsating was the idea...... We measured our carb to have 41.15mm of movement. I believe this may vary with prodiction tolerances. Hence why I use 41.0mm in the Comparative Main Jet Size program I use.
Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com
Dean Martin
PostPosted: Thu Jun 24, 2010 10:32 am    Post subject: Reply with quote
Great info Ian. Do you think Ted Dale is also formed by the intersection of two circles Wink
DEAN MARTIN
shaun everard
PostPosted: Tue Jun 26, 2012 2:01 pm    Post subject: mikuni carb Reply with quote
I have got the mikuni tm pro series flat slide to work on my cr. When back to back tested against my delloro it seemed to have much More mid range Power and better Top end. The engine its self is a 2001 cr with a total of 1.5mm in spacers under Barrel including gaskets, Pvl ignition with a retarder Box and v force 3 reeds. Plus also found a de squish banded head didnt seem as harsh when the Power came in.
I am currently unable to get it tested on the dyno at present but as soon as i do i will Post the results.
Andy Kiker
PostPosted: Tue Jun 26, 2012 5:40 pm    Post subject: Reply with quote
Dean,
That was great one liner! I am laughing my a$$ off. Laughing Laughing Laughing Laughing Laughing
Andy Kiker #24
Anderson Karts
WiWa GasGas
Powrpad
Page 2 of 2
DB time: 0.163741 (43.26%), total time:0.378498, queries:38
