Mitch Wright
Shannon Schmidt
Joined: 24 Jun 2002 Posts: 381 Location: United States, Utah, Salt Lake City
Posted: Fri Jun 05, 2009 6:11 pm Post subject: |
That is REALLY COOL.
I especially like the version that allows you to mount the clutch on the right side of the motor..much easier to remove and clean.
How much energy is lost using two chains? _________________ Miller Motorsport Park
2006 Rotax Masters Champion
2007 Rotax Masters Runner-Up
2009 F200 Champion
Monza Z32C #7
"Don't brake till you see God!"
"A great racing driver has his head in communication with his balls." -Richie Evans |
Paul Williamson
Joined: 26 Mar 2004 Posts: 1638 Location: United States, California, Frazier park
Posted: Sat Jun 06, 2009 7:24 am Post subject: |
That was my question, how much power does it rob? Nice, though, no matter what... _________________ My Behavior Does Not Reflect Anything |
Mitch Wright
Posted: Sat Jun 06, 2009 11:14 am Post subject: |
My guess is some but I would think with good bearings and chain it wouldn't be much at all. A chassis dyno would be the test running back to back.
Sure looks like it will save a lot of time and effort fitting a 4/ to some sprint chassis's though. |
Paul Williamson
Posted: Sat Jun 06, 2009 11:57 am Post subject: |
I'm looking forward to seeing some dyno comparisons. If it is only a tiny loss, I have to have a clutch end model! I can see some cool benefits...
easy access to clutch
less rotating mass on the crankshaft
for those of us that don't run a third bearing, it puts the sprocket closer to a bearing
don't need to bend seat struts on 2 cycle chassis
probably less chance of throwing a chain _________________ My Behavior Does Not Reflect Anything |
Bob Ogden
Joined: 22 Jul 2002 Posts: 3448 Location: United States, California, Grass Valley
Posted: Sat Jun 06, 2009 9:15 pm Post subject: |
I'd like to see pics of it on a 2 stroke chassis. The one in the pics looks like an Arrow 4 stroke.
I looked at my AX8 30/32 and even with the clutch outboard on the jackshaft and direct drive engine sprocket it looks like I'd need to perform surgery on my seat strut. |
Wayne ONeil
Joined: 28 Apr 2006 Posts: 319 Location: United States, Oregon, Newberg
Posted: Sun Jun 07, 2009 8:31 pm Post subject: |
| Would be nice not to have to run split sprockets anymore. |
Mike Burris
Joined: 10 Nov 2004 Posts: 574 Location: United States, California, Huntington Beach
Posted: Sun Jun 07, 2009 9:05 pm Post subject: |
Shannon the extra drag is minimal once the chain and shaft bearings break in and a simple axle spin test shows that it takes about the same time to wind down with or without the jack shaft.
Paul, the CE type unit was designed primarily for Mini Sprints with the engine mounted on the left and adapting it to replace an engine clutch would not really be an advantage except you could use could use the same clutch for multiple engines.
Bob, the photos showing the Arrow 4 cycle chassis are for just to show the different mounting & output positions and all the 2 cycle chassis we mocked it up on fitted without any problems except the Arrow which had an interference issue with the rear side pod mount stub. We are working on a chassis plate to take care of that.
Mike |
Frank lowers
Joined: 14 Apr 2003 Posts: 1509 Location: United States, usa,
Posted: Sun Jun 07, 2009 11:08 pm Post subject: |
| Quote: | | Would be nice not to have to run split sprockets anymore. |
You can buy 35 solid sprockets. You then just cut one side. My brother-in-law showed this euro trick. Slides over the axle no problem. Works great and no 2p sprockets. _________________ -------------------------------------------------------
Your New Home of the Next Region 7
Parking Lot Track. |
Bob Ogden
Posted: Tue Jun 09, 2009 8:13 am Post subject: |
| Thanks, Mike. |
michael schorn
Joined: 02 Feb 2003 Posts: 578 Location: United States, Oregon, Banks
Posted: Sun Jun 21, 2009 8:50 am Post subject: |
Mike
That is a sweet motor mount.
Do you think there will be one for racers to see and fondle at the 4 Cycle Grands.
Scribner was talking about getting one to show off to the masses.
This is a great item for those that want to get old 2 cycle chassis out on the track with any 4 cycle set up.
Great job. _________________ OK everyone It's my opinion only, no one elses, and does not reflect any organization or office that I belong to or hold. Thank you for your support.
Portland Karting Association
Host 2013 IKF 4 Cycle Sprint
& Road Race Grand Nationals |
Mike Burris
Posted: Mon Jun 22, 2009 12:07 pm Post subject: |
Mike, I think Corey has one but if not I'll send a DE type up there to the Grands for you to check. I'll call him after while to see what the story is and go from there.
Mike |
michael schorn
Posted: Mon Jun 22, 2009 12:27 pm Post subject: |
Mike
Scribner is there already.
We are leaving tonight. _________________ OK everyone It's my opinion only, no one elses, and does not reflect any organization or office that I belong to or hold. Thank you for your support.
Mike Burrell
Posted: Tue Jun 23, 2009 5:14 am Post subject: |
We ran it a couple of weeks ago on a Birel in a WKA regional sprint series and it worked great. Didn't really notice any drop off in power; after a couple of heat cycles on the bearings it seemed to spin as free before we had it.
I think this could be a good product to help "revive" 4cycle sprint racing. It at least opens up the chassis choices a bit... _________________ National Karting Alliance |
Eric Franzen
Joined: 15 May 2009 Posts: 31 Location: United States, Washington, Seattle
Posted: Thu Jun 25, 2009 8:49 pm Post subject: |
Would this work on something like an Arrow X1 with a Briggs World Formula?
I am thinking of getting into karting next year. The Arrow chassis sounds interesting to me, and I'd like to start in something like World Formula. But I'd like the option to move into some type of 2-stroke at a later time. |
