Bondurant - LB
Russell Karting - SS
Tony Kart/Vortex - FB
does this look broken to you?
Joe Foss
PostPosted: Tue Sep 08, 2009 3:51 am    Post subject: Reply with quote
Yep, ca ca occurs, and yep, it is a bummer. Mine is modded, and has been all good for several years. I guess I certainally can't whine to much:( Thanks for the info guys, I will be more careful.
Ken Schilling
PostPosted: Tue Sep 08, 2009 8:15 am    Post subject: Reply with quote
So, what kind of torque wrench can you use to tighten the cylinder base studs with the engine still on the kart? Right now I just use a 12mm box end wrench and replicate the cylinder head torque as best as possible by hand (I use a torque wrench on the cylinder head).
Ken Schilling
SKUSA Data Administrator
joseph hollinger
PostPosted: Tue Sep 08, 2009 8:28 am    Post subject: Reply with quote
http://www.motionpro.com/motorcycle/tools/category/torque_setting/
The cheap one. I had to grind mine slightly for clearance around the 12mm box end. Mine works, on the kart, but just barely. Most people will have to tilt the seat to get access.
Clarence Carter
PostPosted: Tue Sep 08, 2009 9:00 am    Post subject: Reply with quote
I have an Idea on how to repair these broken lugs on these cylinders. I will repair 1 free of charge to the first taker if anyone is interested. PM me. Clarence
where ever I go, I bring it
Clarence Carter
PostPosted: Tue Sep 08, 2009 8:33 pm    Post subject: Reply with quote
I think they are breaking from the stress of pressing in the casting plug. Think about it and look at the pics. Most of these cylinders are breaking in the exact same spot.
Ken Schilling
PostPosted: Wed Sep 09, 2009 10:00 am    Post subject: Reply with quote
I was just shown an inexpensive way to fabricate a way to do this (~$10 overall cost in parts + welding):
Take a 2" socket extension and weld it to the center of a 12mm box end wrench (12 point / preferably a flat one with no bend if you can find it). You may have to grind the left side of the box end (don't use the open end) to clear the right front nut area (a water jacket in the cylinder might cause clearance issues / don't grind the cylinder to clear it!!!). Keep in mind that this will add a couple of inches to the lever arm increasing the torque so you must compensate a little by decreasing the torque setting on the torque wrench. Not sure how much though...perhaps someone a lot smarter than me can provide a calculation to compensate. I can't imagine that it would be more than ~1lb/ft.
I'm also looking into having my cylinder spot faced where the base nuts meet the cylinder.
SwedeTech is now doing this additional prepping to Stock Honda cylinders.
And yes, it's currently SKUSA legal.
20.3.2.6.4. Cylinder: ...Cylinder mounting flanges for retaining cylinder to cases may be spot faced in the area where the nut meets the flange only...
Ken Schilling
joseph hollinger
PostPosted: Wed Sep 09, 2009 10:10 am    Post subject: Reply with quote
That's basically the way that the motion pro tool works. The difference being that they show you how to make the calculation and you have to pay an extra $5. Smile
For what its worth, with my torque wrench and the motion pro tool, the correct setting is 16 foot pounds (to achieve 20 foot pounds at the nut).
joseph hollinger
PostPosted: Wed Sep 09, 2009 10:20 am    Post subject: Reply with quote
I forgot to mention,
The chick who works at the counter at Motion Pro has really big boobs.
Clarence Carter
PostPosted: Wed Sep 09, 2009 11:42 am    Post subject: Reply with quote
I have a sudden urge to go to motion pro.
Jimmy McNeil
PostPosted: Wed Sep 09, 2009 5:45 pm    Post subject: Reply with quote
LMAO Laughing
Erik Maxfield
PostPosted: Wed Sep 09, 2009 7:31 pm    Post subject: Reply with quote
Are the boobs named Joe and Clarence?
Erik
The early bird gets the worm.....
The second mouse gets the cheese....
Stock CR125.
Chassis-FrankenKART
Intrepid/ITAL combination
Clarence Carter
PostPosted: Wed Sep 09, 2009 7:54 pm    Post subject: Reply with quote
What, you don't like boobs?
Sonny Van Hook
PostPosted: Wed Sep 09, 2009 9:00 pm    Post subject: Reply with quote
I love Clarence and Joseph. Wink
Sonny
Kosmic T9/CR80
FREE Stock Moto Build and Rebuild Guides
Slip-fit crankshaft bearings for Stock Moto engines (CLICK)
Joe Foss
PostPosted: Thu Sep 10, 2009 3:46 am    Post subject: Reply with quote
Jimmy McNeil wrote:
LMAO Laughing
+1. Ya'll are nuts, or maybe, boobies..... And off topic. Wink
So I sent my cylinder to Clarence for him to have a go at repairing the lug. We will advise as progress is made.
Dan Davis
PostPosted: Thu Sep 10, 2009 6:30 am    Post subject: Reply with quote
I've seen some success welding broken cylinder lugs then turning the cylinders gasket surface flat again. Then more base gasket or thicker spacer is needed to make up the diff. there. It will likely break again unless you have the swedetech type mod. (spacer and long stud). Then, it might last for quite a while or it may break shortly after.
Page 5 of 6
DB time: 0.248328 (53.65%), total time:0.46285, queries:38
