MIR Racewear - LB
Tony Kart/Vortex - FB
anybody considered swapping in a 4 stroke?
Goto page 1, 2  Next
Scott Nagler
PostPosted: Mon Oct 09, 2006 3:04 am    Post subject: anybody considered swapping in a 4 stroke? Reply with quote
With the new 4 strokes like the Yamaha WR250 rapping out at 13k and plenty of stock power and more to be had through exhaust mods n other little things. I've thought about swapping one in as it would still be legal for F125, could get into the 30+hp range easily, elec start, 4 stroke quietness, and I can only assume its got broader hp thus ideal for autox. Anybody else look into this yet? I'm already a light driver so a little extra weight is inevidible.
Still a noob, but can't wait to be "on the pipe"
Larry MacLeod
PostPosted: Mon Oct 09, 2006 2:07 pm    Post subject: Re: anybody considered swapping in a 4 stroke? Reply with quote
Are engines over 125cc specifically allowed yet, even if they're 4 stroke? I'm not sure they are allowed at any SCCA event (even regionally). I doubt it would be quicker than a CR125 or ICC though. So it should be allowed. Someone just has to write the letters and request approval from the BoD.
Regarding your "ideal for solo" comment, I'm still not convinced that a more "broad" power band is better than a higher peak. With 6 gears to use, give me the highest HP I can get. I can always keep shifting. Its not like a car when you want to stay in one gear if you can. We're going to shift a lot anyway. Why sacrifice top end for some low end torque?
Lefty
my $0.02
F125 #196
Lefty Funk
Detroit Region
Scott Nagler
PostPosted: Mon Oct 09, 2006 9:22 pm    Post subject: Reply with quote
actually I have read the rules, thus why I mentioned it. You can use up to a 250cc 4 stroke, no limitations on elec start, can't have a "gear box" and otherwise similar rules as a 2stroke. It still would have as much or more hp than my current 125cc, but be more linear with some slight peakiness still... titanium valves help there. It'd be nice n quiet too, I figured my gas savings would be good too. Rebuilding costs aren't as bad, and because the exhaust pipe isn't as critical you don't have to worry about the industry dropping them off the list of motors to support.
Brian Garfield
PostPosted: Mon Oct 16, 2006 3:28 pm    Post subject: Reply with quote
I'm confused, you said you read the rules, and say there's no 4 Stroke gearbox motors allowed, but suggest the WR250. Isn't that a shifter?? No 250 4 Stroke shifters allowed...right?
Vernon Head
PostPosted: Mon Oct 16, 2006 3:50 pm    Post subject: Reply with quote
Brian is correct:
3. Other Engines: Engines must be either a) mass produced
single cylinder two-stroke engines not to exceed 125cc or b)
mass produced single or twin cylinder, four-stroke engines
not to exceed 250cc of total displacement. No prototype, preproduction,
“works type” motors or road race engines are
allowed. Shifter or gear-box type motors are prohibited. Karts
with engines under this specification must run at a minimum
weight of 360 lbs. Exception: the engine must not appear on
the following list, which may be altered at any time by the
SEB upon notification of membership: No engines are currently
listed
Brad Linkus
PostPosted: Sun Oct 22, 2006 5:40 pm    Post subject: Reply with quote
We are the importers of all three 250cc 4-stroke engines you can use. Vampire, Biland, Oral. We can supply you with what you need. Engines 4 Racing, 303-833-0474, imimotorsports@hotmail.com
Brad Linkus
Kristian Werkley
PostPosted: Mon Oct 23, 2006 7:12 am    Post subject: Reply with quote
Has anyone tried using the current crop of 250 4 stroke MX motors, or try to have them homologated for moto classes?
Vernon Head
PostPosted: Mon Oct 23, 2006 1:50 pm    Post subject: Reply with quote
Not that I know of. You can ask your local region to allow it, since it should be about the same performance as the current formula. Or, you can write to SCCA Solo Events Board and ask them to add this to the list of allowed motors. If enough people show interest, they will give it more serious consideration.
The future of karting in general is, in my opinion, probably headed towards 4-strokes because of the pollution. At least that's what I've been reading. Nobody knows how long this will take. I would guess 3-5 years. It's already happening in Motocross, and the manufacturers are no longer developing the 2-stroke technology (also my opinion).
Kristian Werkley
PostPosted: Tue Oct 24, 2006 11:11 am    Post subject: Reply with quote
Yea I definitely agree with all of that.
I think it could probably be an advantage just as it has been in motocross, firing the thing up would probably become more painful though. Rolling Eyes
I imagine it wouldn't be terribley hard to get the SCCA to come around, but I was thinking more interms of what it takes the likes of WKA, CIK, or some of the others to homologate engines.
Scott Nagler
PostPosted: Thu Oct 26, 2006 9:09 am    Post subject: Reply with quote
well now I'm confused... I thought I understood that it could have the same tranny config as a 125cc. Wouldn't make any sense to not allow a 4stroke to have a 5 or 6spd tranny like the 125's do. In motox they are allowed to, so I can only assume that you can in karting too?
"Shifter or gear-box type motors are prohibited" I understood this to be a generic statement for the karts and not specifically attributed to 4 strokes since the 125cc was also mentioned in this section. If they can put ICC 125's with tranny's then they can do the same with 4strokes. I understood shifter/gearbox to be some sort of specialized tranny other than the normal motox tranny... like a paddle shifter or what not, and something that would allow LSD. I don't recall seeing the 360lb, always thought 385 for F125 no matter what. If doesn't get to have a tranny then its not F125, its Jr Kart.
Scott Nagler
PostPosted: Thu Oct 26, 2006 9:24 am    Post subject: Reply with quote
Vernon Head wrote:
Brian is correct:
listed
do you have a link to the full F125 class rules?
Christian Hubbell
PostPosted: Thu Oct 26, 2006 9:30 am    Post subject: Reply with quote
http://scca.org/_FileLibrary/File/2006_solo_rules.pdf
Scott Nagler
PostPosted: Thu Oct 26, 2006 9:37 am    Post subject: Reply with quote
lol, just found it... guess I'm wrong... I sure didn't read it that way when I first read it... I mean how could you prohibit a tranny'd motor in a class full of em... seems like BS to me. I'm gonna see if I can get them to make a specific 4stroke section like they did for the ICC's. 4 stroke not exceeding 250cc and be of MotoX origins..... cam changes allowed or not allowed... etc. We need to get some more interesting competition and I think the world is going 4 stroke anyways so why not go with it? Maybe make a 4 stroke class all together
Vernon Head
PostPosted: Thu Oct 26, 2006 3:36 pm    Post subject: Reply with quote
I need to take back what I said earlier about asking your local region for a 250 4-stroke gearbox class. Can't do it for insurance reasons. 125cc is the largest gearbox engine allowed in SCCA Solo karts.
Scott Nagler
PostPosted: Thu Oct 26, 2006 6:53 pm    Post subject: Reply with quote
really?? that is interesting, hadn't even thought about that... would it just be too wicked of a setup or something? If its geared for 70mph and makes 30hp, I don't see how thats soo diff from 125cc 2strk
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.281507 (56.36%), total time:0.499503, queries:38
