SKUSA (non-flash) - LB
Axle 40 mm vs. 50mm
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Pete Muller
PostPosted: Thu Oct 27, 2005 8:41 am    Post subject: Reply with quote
Wow... this subject being flogged again! Smile
Rob Daniel and I had a long conversation about this over the period of a few months, and this document is the most significant information I've seen that pertains to an axle in a kart.
Go here and and scroll down to the document on Loss Coefficient Modulus
Of particular interest is section 2.3 on material damping, and figure 6 on page 11 covering "loss coefficient".
Thanks to Rob for finding this and forwarding it to me (quite some time ago).
Muller Machine
How-to pages, tech documents, & more
Ultra-precision machining/blueprinting for engine builders
Andrew Kidd
PostPosted: Thu Oct 27, 2005 11:14 am    Post subject: Reply with quote
Damn.
I came here from the front page, and I expected a picture of Muller with half his hair in his clenched fists with a torn shirt and bloodshot eyes. Very Happy
Cameron Karting - 707.938.9986 - www.cameronkarting.com
My opinions are not shared by any of the businesses I may represent.
Andy Seesemann
Expert
Expert
PostPosted: Thu Oct 27, 2005 11:41 am    Post subject: Reply with quote
That is how he always looks.....
A
Andy Seesemann
FULL THROTTLE KARTING
Orange County, CA.
www.fullthrottlekarting.com
Rotax Challenge of the Americas
www.rotaxchallenge.com
WKA District 10 Trustee
www.worldkarting.com
Really Good Guy.
Todd Bellew
PostPosted: Thu Oct 27, 2005 11:55 am    Post subject: Reply with quote
On the work hardening.
When I've seen factory kart teams set up their axles they will replace a straight axle of the same type almost every day. I think it's because use does change the properties.
Steel also "technically" isn't suppose to change properties to a large degree as mentioend. But,we all know a one year old kart isn't the same as a new one. Something has worn out.
These same forces at work wearing out your chassis are the same ones "wearing" out the axle.
Remember this comes from the factories that are the ones who gave us different axles to begin with. Obvioulsy, they didn't let conventional wisdom affect them when producing better pieces.
Thank You,
Todd Bellew
Andrew (AJ) Weber
PostPosted: Thu Oct 27, 2005 12:15 pm    Post subject: Reply with quote
There we go...a way out of the plastic deformation explanation. I did not know that
damping in different steels could vary so much. I still think evidence says we are
really close to the elastic limit with soft axles, but now I can buy we are not past the
limit by design.
So if the axle's rebound is what we are tuning with 'advertised hardness' (really
meaning damping) that opens up new details to pay attention to in testing. That could
indicate that axle geometry (mainly just thickness in practice) and axle 'hardness' are
fairly independent tunables, instead of the common perception of just a single
stiffness spectrum. (2D vs. 1D).
Todd Bellew
PostPosted: Thu Oct 27, 2005 12:31 pm    Post subject: Reply with quote
I've tried to explain that different alloys have different damping properties for about 5 years now. lol
To iterate the thickness and dimension dictate the spring rate not the damping rates.
Look at my old posts.
Thank You,
Todd Bellew
Andrew (AJ) Weber
PostPosted: Thu Oct 27, 2005 1:02 pm    Post subject: Reply with quote
That's what I meant about 2 distinct tunables:
1 -- thickness == spring rate
2 -- 'axle-chart hardness' == damping
However, due to axle costs, this probably amounts to no change in tuning procedure.
Just try the few axles one has for a given event, and pick the fastest one.
Tommy Griffith
PostPosted: Sat Oct 29, 2005 12:19 pm    Post subject: Reply with quote
joseph hollinger wrote:
Chris:
This is a topic that gets rehashed around here quite a bit. I'm going to
try and give you the fair and balanced viewpoint:
1) The stiffness of an axle (i.e., the amount that it will deflect
under a given load) depends only on the axle's outer and inner
diameters. A 50mm axle is generally stiffer for this reason.
2) The stiffness of an axle does not depend on the type of
steel used in its construction.
These above statements are totally inaccurate.
4130 alloy steel has a molecular structure such that the molecules are more tightly packed together than 1018 mild steel. That is why 4130 is "Stiffer" than 1018. It is also the reason that 4130 is much stronger and also why 4130 has a better "Memory" than 1018 mild steel.
However, 4130 will break once it reaches it yield point, where 1018 will deform and stretch farther than 4130 before it breaks.
That is why NASCAR doesn't allow Roll Cages to be build from 4130.
joseph hollinger
PostPosted: Sat Oct 29, 2005 6:33 pm    Post subject: Reply with quote
Chris:
Totally inaccurate? I doubt it. First off no one is talking about
building axles from mild steel. Secondly, what I trying to do was
to present what is the "group wisdom" around here. As mentioned,
this topic gets brought up fairly often. And the result is always the
same. If you read this thread all the way through, you'll see that's
exactly what has happened this time.
Kevin Willmorth
PostPosted: Sat Oct 29, 2005 7:39 pm    Post subject: Reply with quote
From what I have found, the difference in stiffness is not attributable to the wall thickness, as has been suggested. Virtually all 50mm axles are 2.5mm thick, while most every 40mm axle is 3mm. The one exception I found is the 40mm super-soft axle, which may be (bit not necessarily) 2.5mm. Further, from what else I have found, each axle made by the various providers - Freeline, CRG, Margay, R&R - are the same basic alloy, all are a chromolly alloy, although each, manufacturer may use a unique version of the alloy, as is common in frame building. This means that the difference between soft and hard axles, and everything in between, is in how each of these axles is heat treated.
I suspect from this that the soft axles are annealed, while the hardest axles must be through hardened. In each case, the 50mm axle assembly will be a little stiffer for the same heat treatment state, and a bit heavier. The 40mm axle will provide the softest possible setup, while the 50mm will potentially produce the greatest stiffness, should that be desired.
On a side note, I would postulate that the affect of hub length is greater on the softest axle, and less on the hardest axle.
Add this to the affect of rim width, bearing to bearing distance, weight and center of gravity... it's amazing how tunable a kart with supposedly zero suspension really is.
Doug Welch
PostPosted: Sat Oct 29, 2005 10:18 pm    Post subject: Reply with quote
Actually, we don't make any 2.5, except our new Pro axle which has a variable wall with 2.5 at the thickest point. Our standard 50mm axles are 2.3, 2.0 and 1.8 Our standard 40mm axles are 3.3, 2.8, 2.5, 2.1, 1.8.
Quote:
Further, from what else I have found, each axle made by the various providers - Freeline, CRG, Margay, R&R - are the same basic alloy, all are a chromolly alloy,.....
I have run spectrograph analysis on over a dozen different axles from 4 different manufacturers and I've found that only the hard axles are made from chromoly steel. Typically they make the soft from a 1010/1012 material, the mediums from 1018/1020 and hards from 4130.
Quote:
although each, manufacturer may use a unique version of the alloy, .....
I haven't found anything unique about the material in any axle tested. All were off the shelf material, common ordinary alloys.
Not a single axle tested was in any condition other than full annealed. I have tested dozens of axles with a Rockwell hardness tester and have never found any axle to be in any condition other than dead soft.
Sorry Kevin, I don't mean to sound nasty but I've done a lot of heavy lifting and testing on axles and this is what I've found. We made and sold over 2,000 axles this year and many people would be surprised to know who all is using them.
Doug
Kevin Willmorth
PostPosted: Sun Oct 30, 2005 4:13 am    Post subject: Reply with quote
I give up... Uncle.
[quote="Doug Welch]Sorry Kevin, I don't mean to sound nasty but I've done a lot of heavy lifting and testing on axles and this is what I've found. We made and sold over 2,000 axles this year and many people would be surprised to know who all is using them.[/quote]
Sorry Doug, but what you are saying conflicts with the data provided by other providers.
Freeline = 40mm x 3mm, 50mm x 2mm various hardness
http://www.freeline.it/uk_assali.asp
R&R =40mm x 3mm, 50mm x 2.5mm various hardness
http://www.cometkartsales.com/store/axles/axles.htm
CRG and Top Kart axles = 40mm x 3mm, 50mm x 2mm
https://www.pittsperformance.com/index.php?cPath=26_92_130&osCsid=c870eacb28f85d281deaad4db0da1b9e
I did find some minor differences in the Veloce and Brava axles shown on:
http://www.tsracing.com/store/showprod.cfm?&DID=7&User_ID=904767&st=7176&st2=65633527&st3=-44486913&CATID=28&ObjectGroup_ID=113
and http://www.tsracing.com/store/showprod.cfm?&DID=7&CATID=28&ObjectGroup_ID=218
So, while I completely appreciate your approach, experience and research into the subject - I do not understand why it is being presented as a singularity, as though no other approach has been taken - and why you have not assisted in our understanding why others take the appraoch they do - rather than just acting as though they don't exist.
I said it before, and will say it again: I am not an expert on this subject, nor have I sold 2,000 axles. However, I am not prone to making stuff up either. I have attempted to explore the subject to understand it better, and to make some sense out of what is being offered by the producers of the axles themselves. In my own small collected of parts, all of the 40mm axles, in three hardness ratings are 3mm thick, I only have one 50mm axle at this moment, which is the freeline, 2mm thick, which I thought was 2.5 - my bad.
I, as I am sure others have, give up trying to figure this one out, as it has long since stopped being fun. Wink
FWIW, if you'd simply provided a summary of your offering and rationale, along with your findings, rather than wait for an opportunity to jump in and making a point of proving me wrong, you would have succeeded in two ways: 1.) contributed valuable information, and 2.) Gained a customer. I guess one out of two ain't bad. Razz
Mike Goebel
PostPosted: Sun Oct 30, 2005 7:17 am    Post subject: Reply with quote
That's exactly what he did. I don't think that Doug could be any clearer. Kevin you are using sales information to get your point across, Doug used science and engineering.
Mike G.
Doug Welch
PostPosted: Sun Oct 30, 2005 7:56 am    Post subject: Reply with quote
Kevin
Let me give you an example, I've tested SKM's A, B, C axles. All were 40mm diametyer, 3mm wall and 1040 length. The materials used were 1010 for the A, 1020 for the B and 4130 for the C, None were heat treated in any way. Now they can put together any sales brouchure they want with any kind of module numbers they want but I know exactly how they are made. I've done similar testing on Freeline, CRG and Tony. I've found exactly nothing different in them.
If you look at their so called module numbers, one of the biggest factors is the length of the axle. Personally, I think these numbers do little but confuse the customer into thinking there is some sort of vodoo-whodoo behind axles. There isn't. From my testing, its all about wall thickness.
The best thing you can do is test, test and test some more. Almost every weekend we are out to the track testing axles and other componets. Different materials do affect what I call the springyness of an axle. Two axles of the same wall thickness will have different dampening properties when you change the material. For example, in general, the 4130 axles will be more bouncy than an axle from 1010. That is why I don't use it in thin wall axles. The car will literaly hop off the ground. Its a very brutal ride.
Almost every day we get requests to build thinner and thinner axles. Many of the top racers have found that as the axle gets thinner, it really frees up the kart. For example, I'm working on a 2.1 30mm axle right now. Our 2.5 30mm axle has proven to be very popular, we've sold well over 300 of them this year alone. Many "factory" teams are using them. They use them because they work.
You want to free up the back of that Biland, get one of my 50mm softs. or better yet, ask for the Pro axle. You would be amazed how much faster you go. A thin wall axle can really increase corner exit speed. Often 3 or 4 mph.
Doug
Kevin Willmorth
PostPosted: Sun Oct 30, 2005 8:22 am    Post subject: Reply with quote
Doug Welch wrote:
Kevin
Let me give you an example, I've tested SKM's A, B, C axles. All were 40mm diametyer, 3mm wall and 1040 length. The materials used were 1010 for the A, 1020 for the B and 4130 for the C, None were heat treated in any way. Now they can put together any sales brouchure they want with any kind of module numbers they want but I know exactly how they are made. I've done similar testing on Freeline, CRG and Tony. I've found exactly nothing different in them.....
Thanks, maybe we'll talk next season. FWIW, I have found in our own limited tests that our soft Freeline axle is indeed softer than the medium, and far quicker than the hard axle. The hard axle creates a harsh hopping of the chassis. I found the soft axle in the 30mm chassis a little too much the other way and lost time. The medium with short hubs worked best so far. All are 40mm x 3mm. I gave up on the 32mm chassis and 50mm axle for where we run normally. We've tried most every other part we own in a pile of configurations, so it's not like I'm not doing any testing at all. We have been doing quite a bit this season actually. I have a very hard time beleiving that their is no difference in the axles we've run this season - as they change in the kart seemed obvious and noticable. We also tested abiut 15 different configurations of front torsion bar, resulting in our creating a custom part from thin wall aluminum with slugs to adjust stiffness - another topic of course.
Page 3 of 7
DB time: 0.173627 (39.75%), total time:0.436832, queries:38
