Ribtect - SS (non-flash)
DRT Racing - FB
axle keys
Scott Minehart
PostPosted: Wed Aug 15, 2001 3:41 pm    Post subject: axle keys Reply with quote
I have a 2001 Tony Mitox and i need some axle keys tomorrow. I am leaving NC and going to IN tomorrow afternoon. The axle has the keys wiht the rounded ends on them. Are all shifter keys the same? Its for the rear hub. I am trying to see if maybe comet would carry them. Thanks
Scott
Marc Miller
Advertiser
Advertiser
PostPosted: Wed Aug 15, 2001 3:51 pm    Post subject: axle keys Reply with quote
Scott-
I UPS'd two axle keys to you tuesday... you should have them tomorrow. No charge. If they don't happen to get there... then anyone at the track will have extras.. I have 5-6 extra keys and I don;t carry much stuff, so someone will have them. They are standard keys for almost ANY 40mm axle (use the thinner ones).
MM
[ August 15, 2001: Message edited by: Marc Miller ]
Nopes67
PostPosted: Wed Aug 15, 2001 4:31 pm    Post subject: axle keys Reply with quote
Scott and Marc,
On our Mitox 50mm the keys are thin with two round tabs on them. Im not sure about the 40 but I know the 50 will not take a standard key. At least ours wont because of these tabs. If tony has changed the design, its something I havent heard or seen.
Hope this helps
Chad Stapleton
PostPosted: Wed Aug 15, 2001 4:50 pm    Post subject: axle keys Reply with quote
Marc, I am sure scott will thank you himself, and even if they are not the correct keys, that was a tremendous, thoughtful gesture. You are a credit to your sport, and country.
Now, i desperately need a spare Rotax max ............!!
Mark Dismore Jr
Advertiser
Advertiser
PostPosted: Wed Aug 15, 2001 5:50 pm    Post subject: axle keys Reply with quote
I've got more metric keys than I know what to do with, so I'm sure I have them. Peg style, short long, uncut, thin, thick, blah blah blah...
Marc Miller
Advertiser
Advertiser
PostPosted: Thu Aug 16, 2001 5:36 am    Post subject: axle keys Reply with quote
Chris-
The axle in Scott's kart is a 40mm Tony axle. The 40mm stuff takes standard keys and should be the same.
I wasn't sure if the 50mm axle used a standard key or not.. I assumed they use the THIN keys for obvious reasons, but so do I... the 50 isn't drilled is it? like the righetti axles are?
MM
jconard
PostPosted: Thu Aug 16, 2001 6:43 am    Post subject: axle keys Reply with quote
The 50mm is drilled with two dowels on the brake and axle hub locations and three holes on the drive sproket location. I checked and JM racing has them in stock for immediate fedex if required.
Marc Miller
Advertiser
Advertiser
PostPosted: Thu Aug 16, 2001 7:05 am    Post subject: axle keys Reply with quote
OK.. Thanks John.. wasn't sure if they were Righetti style or not.
Scott has a 40mm axle with recessed axle slots as is what is most standard on euro karts.. he is taken care of then.
MM
DB time: 0.120416 (39.13%), total time:0.307772, queries:37
