OTK - LB
K1 Speed - SS
Shifter Gearing for Amago...
Christofer Hoff
PostPosted: Wed Aug 15, 2001 9:02 am    Post subject: Shifter Gearing for Amago... Reply with quote
Anyone have a baseline for 125cc Shifter Gearing (CR125 Stock, CRG Heron Plus) for Amago?
Thanks in advance,
Chris
Randolph Ferguson
PostPosted: Wed Aug 15, 2001 11:13 am    Post subject: Shifter Gearing for Amago... Reply with quote
Preferrably round ones, manufactured from either steel or alumnum
Randolph Ferguson
PostPosted: Wed Aug 15, 2001 11:30 am    Post subject: Shifter Gearing for Amago... Reply with quote
Just kidding. I couldn't resist...
Try starting with 15/25 for Honda 125. Good luck.
Christofer Hoff
PostPosted: Wed Aug 15, 2001 12:57 pm    Post subject: Shifter Gearing for Amago... Reply with quote
quote:
So THAT'S what's wrong!?
I suppose I need a chaing-thingy from the front cog to the back, also, huh?
Now, if I can get the handlebars to fit, I'll be ready for the PMT!
Thanks Randolph, 15/25 it is...
CHris
[ August 15, 2001: Message edited by: Christofer Hoff ]
John August
PostPosted: Wed Aug 15, 2001 2:41 pm    Post subject: Shifter Gearing for Amago... Reply with quote
Although it's been a little while since I've been to Amago, I used 15/27, particularlly if you don't know the track, it's very tight at places.
Larry Ferguson
PostPosted: Wed Aug 15, 2001 3:30 pm    Post subject: Shifter Gearing for Amago... Reply with quote
quote:
With the current track condition and the improvement that have been made, you'll be lucky to get out of fourth gear . definatly drop a tooth!
Gary Kozuma2
PostPosted: Wed Aug 15, 2001 7:35 pm    Post subject: Shifter Gearing for Amago... Reply with quote
John, I'll bet that was with 6" tires and before the track was improved.
The range for a CR 125 at Amago with 5" tires is between 15/24 and 15/26.
Have fun, say hi to pete.
Gary K.
John August
PostPosted: Thu Aug 16, 2001 4:55 am    Post subject: Shifter Gearing for Amago... Reply with quote
Gary K.
Gary: thanks for the update, you're right, it was on 6" wheels. I would suggest starting at the lower end of the range for learning the track.
DB time: 0.135492 (41.19%), total time:0.328936, queries:37
