Mike Goebel
Posted: Sun Apr 03, 2005 5:04 pm Post subject: |
| Scott Woeckener wrote: | Remember: Karting is just a spring board to higher levels of racing.
Thanks, Scott |
Dang that's the sales pitch of the year.
Mike G.
My balls never get hot enough to turn blue. |
Michael Brookes
Joined: 20 Jul 2001 Posts: 182 Location: United States, Oklahoma, Oklahoma City
Posted: Mon Apr 04, 2005 1:09 pm Post subject: |
| Scott Woeckener wrote: | Yet those cannot afford a $150.00 set of engine bearings towards a race advantage for which states "It's not within the budget" to win but painting a helmet for $450.00 is???
www.northstar-ceramicbearings.com |
Scott,
I would pay $150.00 for a set of 50mm spaceage bearings, but your website list them at almost $700.00.
Michael Brookes |
Scott Woeckener
Posted: Mon Apr 04, 2005 4:27 pm Post subject: |
Mike: Surely you DIDN"T see that on our site. 40mm are 205.00 each and 50mm each are $225.00....???????????? The Silicon Nitride balls cost approx $15.00 each...do the math.
Now the engine bearings are $150 for the Set of 2.
Scott www.northstar-ceramicbearings.com |
Tom Jensen
Joined: 08 Jul 2003 Posts: 10146 Location: United States, Nevada, Reno
Posted: Mon Apr 04, 2005 5:15 pm Post subject: |
| Mike Goebel wrote: | | Scott Woeckener wrote: | Remember: Karting is just a spring board to higher levels of racing.
Thanks, Scott |
Mike G. |
No, they charge for advertising on this site.
Luv, tom.jensen@sothebysrealty.com _________________ Sex is like pizza. When it's good it's great and when it's bad, it's still pretty good. |
Andrew Kidd
Joined: 02 Sep 2004 Posts: 3954 Location: United States, California, Mountain View
Posted: Mon Apr 04, 2005 6:09 pm Post subject: |
The bottom line is that the money you might be able to spend in bearings would be better spent in another set of tires (or multiple sets of tires) to test on. A tenth of a second is practically driver error; unless a machine is driving that kart, you will not see the gains from expensive bearings. _________________ Cameron Karting - 707.938.9986 - www.cameronkarting.com
My opinions are not shared by any of the businesses I may represent. |
Scott Woeckener
Posted: Mon Apr 04, 2005 6:45 pm Post subject: |
Your absolutely right! On the chassis alone...If you could only lower your laptimes 1-2 tenths per lap...hummmmm ...20 lap feature...Wait!
That's 2 seconds less than my NORMAL expert driving time. Now let's talk about adding them to your engine at higher Rpms, much more Hp and greater power curve than your competition. That's a whole different discussion.
Scott northstar-ceramicbearings.com |
Andrew Kidd
Posted: Mon Apr 04, 2005 7:14 pm Post subject: |
No, it's not. Jetting errors can account for the amount of power gained from ceramic bearings. If your motor came from the factory better than Joe Schmoe's motor, that could more than make up for the gains. You cannot tell me that you can gain a meaningful amount of power from a motor just from adding ceramic bearings. _________________ Cameron Karting - 707.938.9986 - www.cameronkarting.com
Rick Blood
Joined: 24 Jul 2001 Posts: 2976 Location: United States, that guy in Anaheim, California
Posted: Mon Apr 04, 2005 8:39 pm Post subject: |
Wow, the kidds catching on. _________________ Rick Blood
www.flowdata.net |
Mike Goebel
Posted: Mon Apr 04, 2005 9:18 pm Post subject: |
Go get em Kidd. Bears smearings.
Mike G. |
Tim Doll
Joined: 18 Jul 2001 Posts: 2643 Location: United States, Washington,
Posted: Mon Apr 04, 2005 9:59 pm Post subject: |
OK, let's do the math - typical sit-up kart has three rear axle bearings (some have four, but I'll stay with typical). So a 40 mm axle is $615, a 50mm axle $675. That's a pretty good chuck of change for something that "might?" be good for a tenth a second per lap?
BTW, if someone really cares to do the test, don't mess with lap times. Measure bearing temperatures - friction is HEAT!. Most sprint karts have two engine side bearings - put a good quality bearing on one side, a $200+ ceramic bearing on the other. Run 10-15 laps, come in and measure the bearing temps. Now swap the bearings side to side and repeat.
Dollars to donuts the difference is zilch - or more specifically one degree C or less.
Money where the mouth is .......
Everett, Washington |
Peter Stolper
Posted: Tue Apr 05, 2005 2:17 am Post subject: |
Jim:
See, Ive been away for 4 days and this is still going on!!
Part number is on the side of your bearing, go to local bearing supplier and ask him (or her) for a sealed version, mine are SKF made in sweden, and they aint no jewels! (they are not ceramic either)
Quinn:
out of interest, What conclusions have you come to? Please  _________________ Seatorque Control Systems LLC
E.T.M.Engineering |
Michael Brookes
Posted: Tue Apr 05, 2005 11:16 am Post subject: |
| Scott Woeckener wrote: | Mike: Surely you DIDN"T see that on our site. 40mm are 205.00 each and 50mm each are $225.00....???????????? The Silicon Nitride balls cost approx $15.00 each...do the math.
Scott,
This thread WAS, IS , and SHOULD BE about Rear Axle Bearings. I took your post about $150 for a set of bearings as Axle Bearings since it was in the tread about AXLE BEARINGS.
Just to let you know, The tag classes are restricted to the OEM Bearings in the engine. The class that MIGHT benefit from low resistance bearing can not even use them.
If you can prove that there is a measurable gain that is worth the price of almost $700.00 for a set of 3 raer axle bearings, I would buy them.
I would like real world kart related test results. Not a bunch of Hocus Pocas.
Michael Brookes |
Paul Clifton
Joined: 07 Nov 2003 Posts: 933 Location: United States, Washington, Kenmore
Posted: Tue Apr 05, 2005 3:03 pm Post subject: |
IF I ran a TaG class sprint kart road racing, I would run these rear axle bearings, and run them in my Nor Cal Leopard motor. The money I'd save NOT running front brakes would pay for these bearings, and I'd have a cool helmet too. (All sarcasm implied is intended)  _________________ I love deadlines. I love the swooshing noise they make as they go by!
My new policy is to reject ideas involving extra work from people who aren't actually doing the work |
Charles Frear
Joined: 19 Jul 2001 Posts: 171 Location: Afghanistan, Alabama,
Posted: Wed Apr 06, 2005 9:17 pm Post subject: |
To Scott, I admire your passion about your products. I would like to clarify something. In one of your earliest post you stated that when a bearing heats up the balls get tighter in the metal seperator because the individual pockets get smaller due to heat expansion. I believe you also stated that the space between the ball bearings and the inner and outer races gets tighter because as the races heat up they expand so as to reduce the space between the balls and races.
I was a jet engine mechanic for eight years and my primary job was to re-assembled a 500 pound reduction gear box that contained dozens of various type bearings and gears. These bearings were of a far higher load and technology than any kart will ever see.
When ever you heat say the inner race of a bearing, both the I.D. and O.D. will expand. When ever you heat an outer race both the I.D. and O.D. will also expand. The same would apply to the ball bearing seperator, both the I.D. and O.D. of the pockets will expand. The same applys to the balls the O.D. will also expand with heat.
What to make of these facts about heat expansion?
So the now larger ball will ride on now the larger O.D. of the inner race. Inside of now a larger I.D. of the outer race. Being that the outer race is bigger than the inner race it will expand at a greater ratio to allow for the larger ball bearing and larger O.D. of the inner race.
Which as long as the bearing was properly designed would take these facts into account.
I would like to think all of these laws of physics applys to go-kart bearings as well.
From a highly experienced source on this subject.
Charlie Frear, DeepSeat Inc. |
Tom Jensen
Posted: Wed Apr 06, 2005 9:46 pm Post subject: |
If some of you lard butts got some excercise and lost 10 pounds you could pick up a few tenths without having to spend the $700. I'm just saying. No names. _________________ Sex is like pizza. When it's good it's great and when it's bad, it's still pretty good. |
