Steven Hilbrant
Joined: 15 Mar 2005 Posts: 11 Location: United States, Georgia,
Posted: Tue Mar 15, 2005 9:18 pm Post subject: New to Superkarting and...... |
| Am looking for a motor mount for a 2000 YZ 250. Anyone? Sure would appreciate any input here, Tahnx in advance! |
Chris DeCicco
Joined: 03 Aug 2004 Posts: 717 Location: United States, Oregon, newberg
Posted: Tue Mar 15, 2005 10:13 pm Post subject: |
before marc yells at u, ur not allowed to have screennames, u need ur real name _________________ i like to go fast
2007 Swiss Hutless Toxic/Rotax |
Steven Hilbrant
Posted: Wed Mar 16, 2005 4:50 am Post subject: |
| Sorry, just found that out...thanx for the info. |
KK Nelson
Joined: 02 Oct 2003 Posts: 250 Location: United States, California, Fairfield
Posted: Wed Mar 16, 2005 10:21 am Post subject: |
Power Source Racing. Neil can build one for you. (562) 989-9400. _________________ KK
YZ 250 Guy |
Charlie Tackett
Joined: 22 Jul 2001 Posts: 3105 Location: United States, Michigan,
Posted: Wed Mar 16, 2005 12:30 pm Post subject: |
| Steve....if you scroll down the list of forums, you'll see one specifically for 250 superkarts. Might get more responses there. What chassis are you putting it on? I see you are in Ga. Might try Marc Croslyn or try Atlanta superkarts, if they are still around. |
Marc Miller Advertiser
Steven Hilbrant
Posted: Thu Mar 17, 2005 10:07 am Post subject: |
| Thanx all! I talked to Neil and he's looking into it. The chassis I was thinking of putting it on is a TopKart EVO 125 chassis 32/32mm. Hopefully Neil will be able to hook me up. Appreciate all your responses, and hopefully see you at the track! |
michael pattison
Posted: Thu Mar 24, 2005 12:54 pm Post subject: i know how it is |
| good luck finding someone that will fabricate you a mount. I built a 250 superkart out of a birel r32 and you will need to custom make one to fit that chasis like i did also you will need to add bout 3 inchs to the frame. It took a very long time to custom fabricate my motor mount. |
KK Nelson
Posted: Thu Mar 24, 2005 1:20 pm Post subject: |
If you find someone to fabricate you a mount and they tell you that you must add 3 inches to your chassis....my advice is to turn around, walk away, and find someone else.
If Neil at PSR will still do motor mounts for karts he is the guy to use. You DO NOT have to cut your frame. _________________ KK
YZ 250 Guy |
michael pattison
Posted: Thu Mar 24, 2005 6:57 pm Post subject: |
| your right you don't have to cut your frame for the motor mount but the sprint karts are not as long as the superkart chasis so by adding length you will have better handling and the sprint chassis is not long enough according to the world superkart rules. most sprint chassis are about 41 inches long and minium for super kart rules is 42 and i made mine 43 which makes it still legal as a sprint kart |
michael pattison
Posted: Wed Mar 30, 2005 9:20 pm Post subject: |
| Was neil able to make a mount? |
KK Nelson
Posted: Wed Mar 30, 2005 10:40 pm Post subject: |
Neil made me the slickest articulating mount you've ever seen. I takes 20 seconds to adjust my chain and.....no cuts to the frame. _________________ KK
YZ 250 Guy |
Steven Hilbrant
Posted: Thu Mar 31, 2005 4:14 pm Post subject: |
Wow, KK....Sounds like a nice mount. Wish I could get one of those.... Neil still hasn't called me back. He either must be busy or fergot. Oh well.....any other suggestions? |
michael pattison
Posted: Thu Mar 31, 2005 7:45 pm Post subject: |
I NEVER MEANT YOU HAVE TO CUT THE FRAME FOR THE MOTOR MOUNT
THE SUPERKART BODY WORK WON"T EVEN BODYWORK WON'T EVEN FIT A REGULAR LENGTH SPRINT KART-
K.K. what kind of kart do you have? I think if you had a sprint kart you would have ran into the problems i did. |
Frank Dawley
Joined: 18 Jul 2001 Posts: 266 Location: United States, Michigan, Royal Oak
Posted: Fri Apr 01, 2005 4:42 am Post subject: |
Correct me if I'm wrong. WSK is dead, or at least a 1 race org. (Laguna)
The USSC is the 250 org. now.
In the USSC rules it state (no 125 sprint chassis allowed).
If your going to run WKA races, the Unlimited class is a (LAYDOWN) class except for IC/E style karts."i.e. Anderson/Zip/Swift/Stratos"
Before you build a 250 sprint kart i.e. Tony/Topkart/CRG/Birel Check you local rules to find a place to run it. _________________ 2-G.P. Karts / 2-GFK TM K9B |
