2D2W - LB
Ribtect - SS (non-flash)
horstman clutch
Joe Payne
PostPosted: Fri Nov 23, 2001 5:11 pm    Post subject: horstman clutch Reply with quote
I just put new floaters and discs in my axle
clutch and it doesnt turn so freely now.
Will it loosen up when turned at high rpm.
Mark Dismore Jr
Advertiser
Advertiser
PostPosted: Sat Nov 24, 2001 10:04 am    Post subject: horstman clutch Reply with quote
Whoops, just noticed you said AXLE clutch. I withdraw my answer!
[ November 24, 2001: Message edited by: Mark Dismore Jr ]
John Kuntze
PostPosted: Sat Nov 24, 2001 4:00 pm    Post subject: horstman clutch Reply with quote
Did you check the air gap before you
closed the clutch up?The air gap should
be around .050" Whenever I have put new
lignings in the past I have had to sand
them a little bit and sometimes put in
thinner floaters.If the air gap is to tight the clutch won't work properly and is
usually hard to turn.
John Kuntze
Joe Payne
PostPosted: Sun Nov 25, 2001 6:22 am    Post subject: horstman clutch Reply with quote
thanks John for the info. I will chech the air gap today and see you at the streets
Joe
Ian Morgan
PostPosted: Sun Nov 25, 2001 6:44 am    Post subject: horstman clutch Reply with quote
This may be a long shot but did you crank the adjuster screws in enough? If you just have them started in and not to close to the proper height, the clutch will seem locked up. good luck,
Ian M.
DB time: 0.099755 (49.17%), total time:0.202866, queries:37
