2D2W - LB
MG Tires - SS
SCCA Enterprises - FB
Cold Stick or Lean Stick
Goto page 1, 2  Next
Erik Frank
PostPosted: Mon Aug 13, 2001 11:26 am    Post subject: Cold Stick or Lean Stick Reply with quote
That basically is a function of what the piston to wall clearance is inside a given motor. If you have a stock MX engine (or an engine set up with stock type piston to wall clearances), they are set up pretty tight, and you can very easily cold stick one. It can also be a (weaker) function of the particular piston construction. For example, a cast piston expands differently than forged piston. Both OEM honda and HRC (Honda RS) pistons are cast.
hope this helps,
erik
Vernon Head
PostPosted: Mon Aug 13, 2001 12:53 pm    Post subject: Cold Stick or Lean Stick Reply with quote
Considering that many people try to keep their water temp under 140 degrees, isn't this a pretty small window?
Matt Kull
PostPosted: Mon Aug 13, 2001 1:29 pm    Post subject: Cold Stick or Lean Stick Reply with quote
I think that it is more of a function of getting the metal up to temp so that it has expanded all the way through.
Steve Clark
PostPosted: Mon Aug 13, 2001 2:49 pm    Post subject: Cold Stick or Lean Stick Reply with quote
Pardon my rookie question . . .
Are the temperatures for water in celsius or fahrenheit (sp?)
So when I first run my shifter I should do a couple of easy laps to check temps?
Russ McGrane
PostPosted: Mon Aug 13, 2001 3:19 pm    Post subject: Cold Stick or Lean Stick Reply with quote
Water temp is in F. At 135 C it would be called steam.
John Wehrheim
PostPosted: Mon Aug 13, 2001 10:29 pm    Post subject: Cold Stick or Lean Stick Reply with quote
I have heard that you can stick a motor by not having the motor temp high enough. Is this true or is it just that the carb jetting was not set right? What is the preferred temp for a 125 and an 80cc. I have heard around 135 degrees.
Tim Blaney
PostPosted: Mon Aug 13, 2001 10:49 pm    Post subject: Cold Stick or Lean Stick Reply with quote
Yes it is true. I have my motors built by Paul Leary at Hi-Tech and he told me that under no circumstances was I to run my motor hard before the water temp was at least 120, preferrable 125.
Steve Clark
PostPosted: Tue Aug 14, 2001 2:52 am    Post subject: Cold Stick or Lean Stick Reply with quote
Oh yeah. I knew I should have paid attention in science class.
Like I said rookie question.
Todd Stoffer
PostPosted: Tue Aug 14, 2001 5:14 am    Post subject: Cold Stick or Lean Stick Reply with quote
quote:
Unless it's under pressure.
Jon Betts
PostPosted: Tue Aug 14, 2001 5:46 am    Post subject: Cold Stick or Lean Stick Reply with quote
OK 120F min temp? I ran all race day last race with steady 122F water and 1300F EGT plug looked great maybe even still a bit rich. it seems that water was too cold and EGT too hot what should I do? By the way it's a stock CR125
Thanks JB
Scott Davis
PostPosted: Tue Aug 14, 2001 6:13 am    Post subject: Cold Stick or Lean Stick Reply with quote
No matter which way you stick it, it is not a cheap fix.
Tim Blaney
PostPosted: Tue Aug 14, 2001 7:28 am    Post subject: Cold Stick or Lean Stick Reply with quote
quote:
Thanks JB
JB, slap a strip of tape on your radiator to get the water temp up. Be sure to fold a tab into the tape, that way if the temp goes too high, you can reach over and yank the tape off.
John Wehrheim
PostPosted: Tue Aug 14, 2001 11:43 am    Post subject: Cold Stick or Lean Stick Reply with quote
Thanks for the information, but what is the optium temp for a 125 and 80cc. I have heard some guys run them up around 170 degrees. Ouch. But what is the preferred temp. I usually try around 135.
Tim Blaney
PostPosted: Tue Aug 14, 2001 12:48 pm    Post subject: Cold Stick or Lean Stick Reply with quote
John,
I have always been told that 135-140 is optimum. 170 seems a "bit" on the high side.
Terry Tilton
PostPosted: Wed Aug 15, 2001 1:03 am    Post subject: Cold Stick or Lean Stick Reply with quote
170 could be head temp. They tend to run about 30 degrees hotter than the water temp.
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.18567 (65.13%), total time:0.285086, queries:37
