2D2W - LB
MG Tires - SS
Chassis design
Mike Unger
PostPosted: Thu Jul 26, 2001 5:29 pm    Post subject: Chassis design Reply with quote
I've been noticing that the newest chassis out of Europe have a triangular design on both sides near the waist of the kart. This seems to be a trend. Can anyone comment of this purpose of this and why it seems to be working?
Mark Dismore Jr
Advertiser
Advertiser
PostPosted: Thu Jul 26, 2001 6:41 pm    Post subject: Chassis design Reply with quote
quote:
It's not just Europe, we do it on our karts.
A. It looks cool.
B. It helps stiffen the chassis in the center where it is weakest. Which makes the chassis use the front and rear of the sections more, it's best to isolate both ends where the adjustments are. Also, we have been doing it for years but with smaller bars, they were called "K" braces and I think Invader still does it.
Mark www.cometkartsales.com
Andy Seesemann
Expert
Expert
PostPosted: Thu Jul 26, 2001 6:50 pm    Post subject: Chassis design Reply with quote
Mike,
It's also not that new. The CRG Heron (originally Daytona Heron, then Heron Plus, now Heron Evo) has had this design for more than 5 years now. This is the original chassis with the triangulated braces at the midsection. CRG has made minor updates to this design and in my opinion, the Heron is still one of the best chassis on the market.
ANDY SEESEMANN
PITTS Performance
Tim Paul
PostPosted: Thu Jul 26, 2001 9:40 pm    Post subject: Chassis design Reply with quote
Mike,
We have tried all of that stuff, we even tried ones that you could adjust them to be loose. We found that they were never in. Maybe some karts need um we dont.
Tim Paul
CTS Championship Race Karts www.ctsshifterkarts.com
John Wehrheim
PostPosted: Fri Jul 27, 2001 11:25 am    Post subject: Chassis design Reply with quote
We run Invader and Invader does have the k struts. Invader has the struts cut so you can clamp them or leave the clamp off. The advantage is more adjustability. I have run them on and off. I take the clamp off when I want more front grip and have the front lay flatter. I rather have more adjustability than less.
[ July 27, 2001: Message edited by: John Wehrheim ]
Taylor Y.
PostPosted: Sun Aug 05, 2001 10:50 am    Post subject: Chassis design Reply with quote
i think it's mostly a trend, crg is the only good frame (in my opinion) do have this disign. i don't see any of the other frames with that disign doing that well in europe or in the u.s. for that matter.
jconard
PostPosted: Mon Aug 06, 2001 11:29 am    Post subject: Chassis design Reply with quote
Well,
Iff you mean the triangulated waist forward of the mid cross member, both the Birel, as well as the Tony Mitox use this design.
Not sure of the success of the birel, though I know it has been successful. As for the Mitox, it was the 2000 World FSA champion and has propelled the Scott Speed/ JM racing to the top of the Promoto this year.
So, T Man while CRG is a great chasis, several others have used this means of stiffening the waist to good effect. I have no doubt that there are other quality chasis that have as well.
John
Taylor Y.
PostPosted: Mon Aug 06, 2001 9:37 pm    Post subject: Chassis design Reply with quote
i forgot about tony and birel, they're great chassis.
Tim Blaney
PostPosted: Tue Aug 07, 2001 5:46 am    Post subject: Chassis design Reply with quote
Ban him. . . .
Ronnie Swyers
PostPosted: Tue Aug 07, 2001 6:50 am    Post subject: Chassis design Reply with quote
Yeah....What Tim said!
Jeff Franz
PostPosted: Tue Aug 07, 2001 10:08 am    Post subject: Chassis design Reply with quote
quote
Quote:
Originally posted by T man:
T man,
I am unsure if you received the private message that the board moderators sent to you. If not, let me offer the reminder that you will need to update your user profile to display your real name and an active email address.
To make the appropriate changes, kindly use the "my profile" link in the top right area of these forums. If you are having a technical problem making the changes, please email us at jeff@ekartingnews.com
You were warned in another thread about this, please don't become the first person that needs to be banned. That is how serious we are about the use of real names.
Thanks much,
Jeff Franz
DB time: 0.136223 (40.58%), total time:0.335681, queries:40
