MaxSpeed - LB
K1 Speed - SS
Hone This
Goto page 1, 2, 3, 4  Next
Martin Secrest
PostPosted: Tue Jun 15, 2004 10:08 am    Post subject: Hone This Reply with quote
I'm wondering about people's opinions on how the KT100 cylinder should be honed.
Let's presume it is being done correctly, on a Sunnen machine.
I know the old saying about what opinions are like -- but I'd like to hear 'em all anyway. Wink
PostPosted: Tue Jun 15, 2004 2:25 pm    Post subject: Reply with quote
It's not rocket science and, you don't need a big sunnen machine.
I use aluminum torque plates top and bottom and put on an old header. The bottom torque plate has a tang for holding the cylinder in the vise and I use a squirt bottle with kerosene to keep the stones from loading up.
My hone is an Ammco 3950 small engine hone and, I don't use the 2 felts but, instead use 4 stones. I believe it is stone set #3952-1 and they are the finest stones made for that hone. You have to keep the set together so the stones wear evenly. Don't mix with other sets. If one stone gets damaged you have to replace the set. A hand held drill provides rotation.
You should hone from both ends and controll the stroke so the stones don't pop out of the bore too much and bell mouth the end. Your hone may cut slightly more on one end than the other but, if you know which end and, measure often, you can use this to advantage. Vary the length of stroke, speed of the stroke, speed of the drill and flip the cylinder often and this will give you a nice even bore with a random crosshatch.
With OEM Yamaha pistons I use a piston clearance of .0025" for engines I intend to give a good break-in, .003" for engines that get a break-in during morning practice and .0035" for customers who run them hard right off the bench. I have used down to .002" clearance but, there seems too be too much piston scuffing even after a proper break-in.
Giffy Cool
Yamaha KT100 Service Center
40 years karting experience
Pete Muller
PostPosted: Tue Jun 15, 2004 8:23 pm    Post subject: Reply with quote
I have a Sunnen MBB-1660 floor model honing machine.
For a KT-100 (and most other 100cc cylinder), I use a Y56-2000PE keyway mandrel (single stone with 2 brass shoes opposite).
I spend at least 75% of the total job time setting up the mandrel. I use a truing sleeve that is as close as possible to the bore size (preferably exactly the bore size) to set up the mandrel.
I typically use around a 280 grit stone on a KT-100, though I have used a number of stones on either side of that.
Lots of time is spent getting the cylinder ready for honing... top torque plate, exhaust header flange, intake manifold... all installed and torqued in exactly the same sequence and with the exact same torque increments as when assembling the engine.
Once the mandrel has been set up and lapped-in to the bore size (using the truing sleeve), and the cylinder is ready to go... honing is a very simple process.
Using the above procedure, I have run KT-100 engines with a piston to bore clearance as tight as .0005 (half a thousandths) clearance when running direct drive. (more clearance is required depending on type of exhaust pipe, piston taper, and a number of other things).
'bout it
Muller Machine
How-to pages, tech documents, & more
Ultra-precision machining/blueprinting for engine builders
George Petry
PostPosted: Wed Jun 16, 2004 6:10 am    Post subject: Reply with quote
What’s your opinion on ball hones? If you read there sales literature you would think That Sunnen hones are a thing of the past. Do any of you folks have any experiences or opinions on ball hones? I We used ours a little to often in our pits at Road America last weekend.
Martin Secrest
PostPosted: Wed Jun 16, 2004 6:25 am    Post subject: Reply with quote
What's a ball hone? Is this a "manual" device?
And to Pete -- have you ever used a two-stage hone process? That is, a first coarse cut, followed by a fine cut?
John Kuntze
PostPosted: Wed Jun 16, 2004 7:21 am    Post subject: Reply with quote
I knew a guy that used a ball hone on his Yamaha because it was cheaper to get honed. It screwed up the cylinder so bad it took a cone shape and he had to trash it he never did that again.
John Kuntze
ekart99@aol.com
Pete Muller
PostPosted: Wed Jun 16, 2004 7:22 am    Post subject: Reply with quote
A ball hone is the quickest way to ruin a 2-cycle cylinder.
PM
Pete Muller
PostPosted: Wed Jun 16, 2004 7:26 am    Post subject: Reply with quote
Absolutely. I started experimenting with that back in the 70's. Cool
As you might imagine, that takes even more setup work on the mandrel, because if the mandrel is not perfect for the fine stone, you instantly defeat the purpose of it.
fwiw: I never found a positive, measureable, clear-cut advantage to it.
I still like the idea... even though it's a lot of work to do it right.
PM
Jack Burroughs
PostPosted: Thu Jun 17, 2004 5:04 am    Post subject: Ball hone? Reply with quote
The only place I ever use a ball hone is in briggs cyls, and other straight holes with NO ports, and basicly for de-glazing, 'cause all they are is a expensive, glorified glaze breaker. NEVER use in any 2-stroke cyl., the balls will get into every port hole and bell-mouth to where it will render it useless. A 2-stroke should be de-glazed, (if thats what you want to do), with a hone, and the truing fixture is an essential part of doin' the job right.
Martin Secrest
PostPosted: Thu Jun 17, 2004 6:43 am    Post subject: Reply with quote
I've never honed a KT100 cylinder, and I don't know the first thing about it ... but ... how does the crosshatch interact with the fuel charge, i.e., the oil? Does the crosshatch trap the charge, thus enabling the compression?
John Burgess
PostPosted: Thu Jun 17, 2004 7:40 am    Post subject: Reply with quote
IMHO the crosshatch serves two purposes, the 1st being oil retention for the lubrication of the ring. If the surface is two slick, the oil will not have a place to attach and be available to lubricate the ring as it passes by. I believe the second reason for the crosshatch pattern is to give a more tortuous patch for the compression pressure to leak by. If you slow down the leak rate, you will have more pressure available at TDC.
Remember the piston ring is a mechanical seal that is spring loaded against the walls of the cylinder so its fit in the cylinder, (end gap), its fit on the piston (groove width) and how the piston fits in the cylinder all have some optimum tolerances.
Martin Secrest
PostPosted: Thu Jun 17, 2004 8:32 am    Post subject: Reply with quote
Right -- but why does an uneven surface (i.e., the crosshatch), enable the compression? I presume it does so by providing cylinder wall "valleys" in which the fuel charge can accumulate, leading to compression (?)
If this is true, then don't bigger valleys (that is, a coarser crosshatch) presume higher compression?
Chuck Bunnell
PostPosted: Thu Jun 17, 2004 8:38 am    Post subject: Reply with quote
Remember that it's an uneven surface on a very small scale. And there's some magic about riding peak to peak versus surface to surface where you have less drag going peak to peak. I know there's more to it than that, but it escapes me right now and I think that's the gist of it. The droplet size of the oil on the walls should be small from the atomization and needs to be kept small to keep drag down too. Something like that.
Pete Muller
PostPosted: Thu Jun 17, 2004 9:04 am    Post subject: Reply with quote
... but why does an uneven surface (i.e., the crosshatch), enable the compression?
It doesn't "enable" compression.
The crosshatch really has nothing (or very little) to do with compression. Ever see an engine with a chrome bore (or nikasil)? It has no crosshatch at all... and compression is not a problem.
When running a a steel ring and an aluminum piston on a cast iron bore, history has shown us that it just works a bit better if you can "hold" a bit of oil on the surface. That's why a crosshatch is there.
If you run chrome or nikasil bore (upwards of 70 Rockwell C in hardness for hard chrome, and I'm certain nikasil is up there as well), then there doesn't seem to be nearly the need to hold the oil... probably because the coefficient of friction is so much lower running on the hard surface - and aluminum and steel don't have nearly the "tendency" to gall with those surfaces).
PM
Martin Secrest
PostPosted: Thu Jun 17, 2004 9:23 am    Post subject: Reply with quote
I see. But then, Pete, what's the best procedure or process to maximize a Yammie's compression? Other than using castor, that is?
Page 1 of 4
DB time: 0.132091 (36.98%), total time:0.357219, queries:38
