Margay Racing
MRP - SS
DRT Racing - FB
Front brakes...
Axel Korn
PostPosted: Wed Apr 28, 2004 1:28 pm    Post subject: Reply with quote
Mitch, proposing "TaG Open" would be the first step in going down the same fragmented path that we now have with 10 Yamaha classes.
I would rather buy more brake pads, than consider that option.
That's my point Tim. I do have a vented rear rotor, but adding front brakes could potentially reduce the cost substantially and everyone can benefit from it.
Ben Bottomley
PostPosted: Wed Apr 28, 2004 1:54 pm    Post subject: Reply with quote
Thats a relief to hear I am not the only one throwing 4 brake pads into a race day. I have been thinking my brake system was the issue.
joseph hollinger
PostPosted: Wed Apr 28, 2004 2:02 pm    Post subject: Reply with quote
It still could be. I've been using the same set of pads all year
(buttonwillow, grange, moran and two practice days). And our
laptimes aren't all that different.
Opps, that should have been buttonwillow, grange, moran, moran and
three practice days.
Rob Linders
PostPosted: Wed Apr 28, 2004 3:17 pm    Post subject: Reply with quote
Joseph,
What chassis and brake system are you using compared to the others. Ben and Axel, what are you using?
joseph hollinger
PostPosted: Wed Apr 28, 2004 3:27 pm    Post subject: Reply with quote
Rob Linders wrote:
Joseph,
Margay Brava 1.2 with Ital brakes.
Richard Haight
PostPosted: Wed Apr 28, 2004 3:34 pm    Post subject: Tag Front brakes Reply with quote
While we can debate all day long about front brakes, I find the comments that "it would cost a lot to add front brakes", either disingenuous, or a simple failure to do the homework.
Many people in Rotax or TAG (heavy) classes, already use a 125 shifter Chassis, because it has been shown to work better. So, what that means, is that a lot of people have been removing or disconnecting the front brakes. But, they still have them!
Although some karts have a dual rear brake set-up, which is better then a single, it does not provide as much safety, You are still feeding the heat of two full calipers into the mass of one disc. Can you say "Heat"?
As more organizations allow, or even mandate front brakes for some classes, such as the recent change to 80cc shifter classes, front brakes will become the norm, not the exception.
As some have mentioned, the use of front brakes seems to reduce the overall wear of the brake system, with many people going half a season with little brake wear, as compared to some of the CRG's Maximo's, which went through a set of rear pads in half of a practice day, and ruined discs as well! It sounds like front brakes equates to = (A)"Better Braking" (B) Less wear, and therefore potentially less expense, and (C) SAFER!
There are SO many good used chassis and parts out there, that getting a set of front brakes is probably less expensive then everyone wants to make it seem.
I would prefer to have full brakes, front and rear, it simply works better. Yes, I am sure that there are those who will say "I go pretty fast without it, so why change?", but the truth is that you will probably go even faster with them.
Although many of us do not have any aspirations to move up to cars, a lot of racers do..... and in case you haven't noticed, virtually every full size race car built, has 4 wheel brakes! You might as well learn to use them, and to set them up now, rather then play catch up later!
Some organizations allow front brakes, but impose a 10 pound weight penalty. Hey, add the front brakes, which is about a 5 pound addition, and it is 5 pounds less of lead to add on!
Rob Linders
PostPosted: Wed Apr 28, 2004 3:42 pm    Post subject: Reply with quote
joseph hollinger wrote:
Rob Linders wrote:
Joseph,
Thank you. I presume the Ital brakes are an upgrade, do they work much better than the Margay factory brakes? I still have a Tony with Tony brakes and they work fine for a Yamaha, not sure how well they would work with TAG horsepower.
joseph hollinger
PostPosted: Wed Apr 28, 2004 3:49 pm    Post subject: Reply with quote
Rob Linders wrote:
Joseph,
Actually, those are the brakes that came with the kart from the factory. Doug, who really should chime in here, is running the same setup and
having the same pad wear problems that Ben and Axel have reported.
Our hypothesis is that it all comes down the the type of pad you are
using. The pads I'm running, which I believe are Ferrodo S-1, seem
to have pretty good feel and very good durability. I've ordered some
OEM Margay pads to test against the current setup.
John Denman
PostPosted: Wed Apr 28, 2004 4:07 pm    Post subject: Reply with quote
When I first proposed the TAG Standards we let people vote on allowing front brakes or not. We had about 35 interested parties, mostly track owners, that voted. 21 against, 14 for. I woud have made 15 for, but I didn't vote.
During our testing we used a Trackmagic Spitfire chassis as the test mule. This is a 32MM thats very similar to the Diablo. I also put both a Leopard and a Rotax on one of our Diablos and tested to see what the differences were - front brakes were about 3/10 slower at NTK in both directions. Like an 80, the TAG power seems to be faster by with rear only brakes.
I would still like to see it as an option, but my voice is now just one in the crowd with TAG.
I have to agree it does make for some different driving characteristics that might be a little less safe at the beginner level. I don't agree that it would drive the cost up since it would be optional, and at most tracks slower. It's certainly not a "must have" component.
John Denman
Producer for RTMP
http://www.kartweb.com
Chad Stapleton
PostPosted: Wed Apr 28, 2004 5:20 pm    Post subject: Re: Tag Front brakes Reply with quote
Richard Haight wrote:
...... and in case you haven't noticed, virtually every full size race car built, has 4 wheel brakes! You might as well learn to use them, and to set them up now, rather then play catch up later!
Richard, .. you could say the same for gearboxes...or suspension,... or bodywork...or , etc etc.
The point is, karts are meant to be simple, low cost, and uncomplicated by un-neccessary parts. If you want to race sophisticated karts , move on to the gearox classes.
The "trickle down" effect of technology and cost to the lower classes will eventually move it out of reach of the masses.
I do believe the more powerful TaG karts should have a dual braking curcuit for safety, but front brakes are an un-neccessary complication.
Anybody using more than one set of pads for a race meeting needs to seriously queery their brake rotor & pad choice. That is a totally un-neccessary !
Chad
Richard Haight
PostPosted: Wed Apr 28, 2004 5:49 pm    Post subject: Brakes Reply with quote
Chad:
I don't disagree that karts are meant to be relatively simple and cost effective. If we are talking about KT100's or HPV's or the like, I have no problem with just rear brakes.
However, as you rightly mentioned, the TAG karts are approaching 30 HP, and in the senior classes, nearly 400 pounds.
Whether it is front brakes, or dual (and separate!) rear brake systems, is not the point. Karts on average tracks have progressed to the point that they are going over 75 miles an hour down the straights. And all of the tracks are not up to "Current Safety standards". Many have short turns at the end of fast straightaway's with no effective run-off.
It would be nice if we had better brakes, but as karts are supposed to be "relatively simple", the technology has NOT kept pace with the speeds.
As far as the pad wear problem, you can say what you wish, but the both the original pad and disc combination, as well as other pads, and a new factory disc, all went through pads like toilet paper. It was an under-designed system, built by CRG to a "Price Point", and it was inadequate.
Dai Feng
PostPosted: Wed Apr 28, 2004 6:01 pm    Post subject: Reply with quote
Faster with just rear brake than with front and rear brake? This seems counter intuitive Rolling Eyes Could some explain how this is so? May be the kart was not setup for using the front brake or requires a different driving style??
Dai
John Denman
PostPosted: Wed Apr 28, 2004 6:43 pm    Post subject: Reply with quote
Dai
Here is the long and the short of it;
I have always driven a kart with front brakes, Yamaha to 125. A 125 needs front brakes it always has so much torque available it just drives defferently then anything else. My son who also runs a both 80 & 125 also tested with the same results.
TAG motors, even the Biland, just doesn't have the same bottom end torque to control the rear on slower turns. That makes the TAG a little faster to trail brake into slower turns. Trail braking results in about a 1 MPH higher turn speed. That might no seem like much but think about it - thats a 1.5 foot per second exit speed and you carry it all the way down a straight. If the time on the straight is 8 seconds, thats a 12' gain in distance. On a track wrehe the average speed is 45MPH, thats 67 FPS and 12/67 = .18 seconds. Do that twice on a track and its .36 seconds.
On the other hand, front brakes allow you to brake later right? How much later? On a track where we slow from 75MPH to 32 mph in a shifter, it allows braking to be about 12 feet later then a comparable 80JR with rear brakes only. Without getting into factorals and squares etc of deceleration rates, that 12 feet later braking makes much less difference then 1/10 of a sceond. Add to that you have to slow a little more due to having all 4 wheels working at the threshold of adhesion up until turn-in, plus the stabilization time of the chassis/tires. Thats why 4 wheel brakes are slightly slower in turns.
If you know how to read the Mychron data and you have a chance to compare speeds and G-forces you'll see what I am saying.
If you don't know how to use the Race Studio software in the application level to going faster you are in for a treat. Thats what the June feature is on, complete with a video that explains how to read what's going on, and how to apply the mapping to go faster. Cool
John Denman
Producer for RTMP
Axel Korn
PostPosted: Wed Apr 28, 2004 7:12 pm    Post subject: Re: Tag Front brakes Reply with quote
There is nothing complicated about front brakes.
Complicated is custom welding brackets to the rear bearing hanger and aligning a secong caliper on the same rotor. Complicated is plumbing a secong brake master cylinder to that second caliper with custom length brake lines and connectros to make them work.
As far as queering rotor and pad choice....been there and done that. Count yourself lucky if you can go through a full raceday and have pad left at the end of the day. There are many drivers on many different chassis with different brake systems that are currently experiencing the same problem.
One thing I do have to add is that our typical raceday at the Golden State Gatorz Cup includes much more track time than most other races. We have a 1/2 hour practice with a 20 minute qualifying, 15 minute heat race and a 25 minute main.
Mitch Gillick
PostPosted: Wed Apr 28, 2004 8:16 pm    Post subject: Reply with quote
Axel, please don't ask IKF to rewrite the rules for EVERYONE else, because you have brake pad issues... I got 3 full race seasons (at least 3,000 road racing miles), on three sets of Brembo brake pads, on a CTS 80 shifter (rear brakes only)... And, that included lots of play days at sprint tracks.
At Thunderhill Park (3-mile road course), no 80 shifter that I know of has ever tried to run front brakes more than once or twice... They always take them off, because it is faster and less complicated to run rear brakes only.
The fastest 80 shifters are a full 10 seconds per lap faster than the fastest Leopard time... I'm a mid-packer, running on YDS tires, but I've still run laps over 4 seconds faster than the fastest Leopard.
Yesterday, I was quoted $960.00 (master cylinder, reservoir, brake lines, rotors, calipers, etc.), to add matching Brembo front brakes to my kart... That's a pretty large percentage of the total cost of most TaG karts. Some of you might say that you don't need to spend a lot of money for brakes... But, I feel much safer running quality rear brakes only, versus running budget front and rear brakes. As far as I'm concerned, if you are running budget front and rear brakes, versus quality rear only brakes, you are not only putting yourself at risk, you are also putting everyone else at risk as well.
Page 2 of 4
DB time: 0.143834 (37.24%), total time:0.386264, queries:38
