SoCal Sprinters
Top Kart USA - SS
Franklin / Merlin USA - FB
Oil ratio
Goto page Previous  1, 2, 3
Kevin Willmorth
PostPosted: Tue Oct 24, 2006 6:54 pm    Post subject: Reply with quote
Larry Andrews wrote:
... Once the plug was pulled, massive amounts of oil mist would just spew out the plug hole...took quite a while for it to stop.
Anybody got any ideas? Is this to be expected?
Blown head gasket on the inner seal surface. I had ours do a similar effect on a CR80, steam blows into the cylinder and washes the oil and carbon out, escaping out the plug hole. The leak was surprisingly very small. New head gasket fixed the problem. A cracked cylinder can have a similar effect.
Keith Young
PostPosted: Wed Oct 25, 2006 7:44 pm    Post subject: Reply with quote
Yes, Castor oil is not Dino oil. But, then again, neither is Dino oil Smile Dino oil is actually from decomposed plankton, algae and other protozoic organisms. Castor oil, if I remember, was that nasty stuff I used to have to swallow when my stomach was upset Crying or Very sad Isn't it from the castor bean?
In anycase, ratios I absolutely understand. I even understand that castor oil, as a lubricant, is adequate for 2 cycle purposes. No arguements. But, it does not mean that synthetics are not good, perhaps even supperior. It is probably has some dimishing marginal utility. It is like which is better? having 100 billion dollars, or 110 billion dollars. 110 is better, but it won't make many any more happy than 100 billion. Very Happy
(unless, of course I wanted to buy that new Aircraft carrier, or Equador!)
Cheers
Charles Ray
PostPosted: Thu Oct 26, 2006 2:50 am    Post subject: Reply with quote
Here in metric land, 1 fluid oz = 28.4ml
1 gal = 4.55 litre (english litres?)
Therefore 8oz per gal = 4550 divided by 227ml = 20:1 ratio
I thought 8oz per gal was 16:1?
Is the error due to the American sized gallon different to the English gallon?
Cheers - Charles
Charles Ray
PostPosted: Thu Oct 26, 2006 3:06 am    Post subject: Reply with quote
Did a conversion search, yes that explains the discrepency.
8 US fluid oz in 1 US gal is 16:1 ratio.
Next question - you'd still run Motul 2T synthetic kart racing oil at this ratio? 20:1 is common over here.
Charles
Page 3 of 3
DB time: 0.202745 (66.31%), total time:0.305776, queries:38
