Bondurant - LB
MG Tires - SS
Franklin / Merlin USA - FB
Electric water pump
Goto page 1, 2  Next
Jeff Standridge
PostPosted: Wed Feb 27, 2013 4:57 pm    Post subject: Electric water pump Reply with quote
Does anyone have info on electric water pump for use on a Icc eng kart. Thank's
Jim McMahon
PostPosted: Wed Feb 27, 2013 6:36 pm    Post subject: Reply with quote
Look up Robert Lawson, I believe he had something like this setup on his Vortex.
Jim White
PostPosted: Wed Feb 27, 2013 8:13 pm    Post subject: Reply with quote
I also believe that some of the gas-gas 250's run an electric pump too.
Sam Zavaglia
PostPosted: Wed Feb 27, 2013 9:20 pm    Post subject: Reply with quote
I've used this before and sold it to Jeff DeMello on this forum who uses it on his ICC 125cc. PM Jeff if this link is not enough and got further questions.
http://www.daviescraig.com.au/Electric_Water_Pumps-ELECTRIC_BOOSTER_PUMP_12V_SHORT___PART_No__9002-details.aspx
www.samzavaglia.com
Jeff DeMello
PostPosted: Thu Feb 28, 2013 6:01 am    Post subject: Reply with quote
It works great on my F125. Sam I was hoping you saw this as I'm in Philly working and couldn't get the info on my pump.
Jeff DeMello
Emmick F125 Pavesi
Joe Ricard
PostPosted: Thu Feb 28, 2013 8:52 am    Post subject: Reply with quote
Hey Jeff that looks like the awesome set up. Is it variable speed? Since I race my ICC with all those honda guys who and put the kart on the ground and sit still warming up the motor.
So now I could do the same right?
Arrow AX-8/ Rotax Sr.
Brian Wilhelm
PostPosted: Thu Feb 28, 2013 11:41 am    Post subject: ? Reply with quote
The Davies-Craig pump is not variable speed, you really don't need it. This unit really works well and I use them on every kart I build.
Jeff DeMello
PostPosted: Thu Feb 28, 2013 4:09 pm    Post subject: Reply with quote
Yes Joe you can let it sit on the ground just like the Hondas ..
Jeff DeMello
Emmick F125 Pavesi
Jeff Standridge
PostPosted: Thu Feb 28, 2013 8:23 pm    Post subject: electric water pump Reply with quote
Thank's for all of the help guy's.
Chuck Bunnell
PostPosted: Fri Mar 01, 2013 9:37 am    Post subject: Reply with quote
What are you guys running for batteries with the electric water pumps?
Brian Wilhelm
PostPosted: Fri Mar 01, 2013 10:02 am    Post subject: ? Reply with quote
3.4ah 12v battery. Perfect size (about 2 1/2" X 2 1/4" X 6")and it will run this pump for 70 minutes. Batteries Plus, Battery Outfitters, etc. Cost is about $20.
Chris Hutchinson
PostPosted: Fri Mar 01, 2013 1:02 pm    Post subject: Reply with quote
Can anyone post a picture with the unit installed battery components and all?
Also, does the pump operate at one continuous speed at all times? i.e. for instance does it spin at the same speed when you are sitting idle vs. going flat out, or is there some sought of sense, or pulse line that detects increase rpm off of the coil wire so that it would spin faster or slower?
Brian Wilhelm
PostPosted: Fri Mar 01, 2013 4:08 pm    Post subject: ? Reply with quote
Constant speed. It's not controlled by anything other than an on/off switch. Personally, I use them with an IAME Leopard inlne thermostat. No taping off the rad, quick warmup, etc. Variable speed is not needed.
To warm up the motor before you go out, just let it idle. When it gets warm, turn on the pump. When you drive it, the t-stat modulates to keep the water temp 130deg. I drill more bypass holes in the t-stat to make it react quicker during warmup.
Don't overthink it!
Jeff DeMello
PostPosted: Fri Mar 01, 2013 5:22 pm    Post subject: Reply with quote
I'll post pic when I get home Saturday morning. Or send text number or email
Jeff DeMello
Emmick F125 Pavesi
Sam Zavaglia
PostPosted: Fri Mar 01, 2013 5:47 pm    Post subject: Re: ? Reply with quote
I have looked at the little bypass hole many times but why has the light bulb never lit up to drill more or bigger hole in it. I guess I must have other things more pressing on my mind at the time.
Thanks Brian for giving me a slap across the back of the head, stooge style, I'll be doing that mod myself now. Will also make it easier/quicker to bleed the air out of the water system. Wink
Cheers.
www.samzavaglia.com
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.086864999999999 (43.23%), total time:0.200948, queries:38
