OTK - LB
MRP - SS
Tony Kart/Vortex - FB
CR 125 Build Help
Goto page 1, 2, 3  Next
Charles Frerking
PostPosted: Tue Feb 26, 2013 7:54 am    Post subject: CR 125 Build Help Reply with quote
Ok, so I detonated the top end of the Vortex that came in the kart when I bought it. If I could say anything about the motor, I'd say it got me absolutely HOOKED on 125 shifters.
I picked up a 1994 CR 125 motor awhile back, in case this happened. My plan is to do a top and bottom end rebuild on the motor, and give it a good once-over. Other than the obvious like engine mount and exhaust, what are the absolute MUST haves to make this motor work in my kart?
I'm thinkin kart specific items like kick start block off, CDI box, etc.
Any help would be awesome! Trying to keep this thing on a budget!
Jim McMahon
PostPosted: Tue Feb 26, 2013 8:02 am    Post subject: Reply with quote
You could rebuild the Vortex.....Often you can clean the nikasil with muratic acid, slap a piston in, check for air leaks, jet the thing up and go.
Failing that, what do you intend running with the CR? I noticed in your FS ad that you mentioned Stock Moto and if thats the case, this 94 aint gonna do it. Its not "Stock Moto" legal. However if the '94 is just for fun/practice or a track that doesnt care too much it'll be OK. Can you post pics of what you have? If the motor came off a bike you might consider a pumparound carb, there's some debate about that however.
Charles Frerking
PostPosted: Tue Feb 26, 2013 8:26 am    Post subject: Reply with quote
My mistake, I get in the habit of calling it "stock moto" not per the regulations of that class, but by what it is.
It's a hobby, not a lifestyle. I need something that's cheap to repair and can run longer between rebuilds (with any luck) and it if it doesn't go longer between, be cheaper to rebuild. CR motors seem to be the way to go - can't beat $350 for a top and bottom rebuild kit!
Racing isn't really in my plans, if it does become a possibility, I think a new kart will come first.
Jim McMahon
PostPosted: Tue Feb 26, 2013 8:44 am    Post subject: Reply with quote
Totally get what you are saying. That's why I wanted to clarify. It wouldn't be fun to go to all that trouble to build something thats a stock, moto under the impression that you can run "Stock Moto" with it.
The KZ stuff isn't as bad as its made out to be, but that's another discussion. Since you already have the CR it worth trying giving it a go.
Sounds like your "kart" parts list is pretty close. I think your next step might be to put a wanted ad up for the parts you need: carb, pipe, silencer, mount (hard to get used though).
Michael Taksa
PostPosted: Tue Feb 26, 2013 8:57 am    Post subject: Reply with quote
What Jim said, plus fuel pump, or two, if you get pump around they will come with the carb, and a "pulse fitting" for the pump, be carefull on the mount, chances are you have a 32 mm frame, but the spacing is different between CRG, GP, PTK and Birel, Tony, Top, etc, 90 mm as opposed to 92 mm between the two right side frame rails
Charles Frerking
PostPosted: Tue Feb 26, 2013 9:19 am    Post subject: Reply with quote
I have a '08 MBA Las Vegas - I'll get to measuring when I get home.
Any little pieces you guys can think of, let me know - ANY little pieces
Michael Taksa
PostPosted: Tue Feb 26, 2013 10:12 am    Post subject: Reply with quote
To get motor from bike running:
install pulse fitting
get a filter or airbox for carb
get a carb
get exhaust pipe and silencer (need to mount these somehow, higly recommend the oringed exhaust header that mount to cylinder insted of stock one, and highly recommend "Hegar" exhaust and silenced mounts)
plumb fuel system wtih return line (need pumps and fuel line for this)
mount the motor, (need motor mount, I think MBA is 32-92)
This should get you going. Nice to have, but not necessary:
Remove and plug the power valves
Remove and plag kick start gears
May want to eventually remove kick start boss and go with straight reed cage as opposed to stock angeled one.
Eventually Mod the cylinder, lower head and get programmable ignition, but this is way down the list.
Charles Frerking
PostPosted: Tue Feb 26, 2013 10:36 am    Post subject: Reply with quote
get a carb
I have the stock Mikuni carb that I plan to rebuild, what's the biggest advantage to a pump around system? I've heard better fuel delivery under heavy cornering? Is it a pressurized system?
I'll just turn this thread into an "answer all my questions" thread, haha
Thanks! Very Happy
Ace Rossi
PostPosted: Tue Feb 26, 2013 10:39 am    Post subject: Reply with quote
Get with Jason at Swedetech for any or ALL your Honda stuff! If your gonna want less problems out if the box, look at a GFS...Smile
Vernon Head
PostPosted: Tue Feb 26, 2013 10:44 am    Post subject: Reply with quote
Everybody uses the RLV R4 pipe, which comes with a mount.
You need a silencer that accepts the 1" OD of the pipe and a mount for it
Get the O-ringed exhaust header as already stated
Get the appropriate motor mount
Pick up a Keihin PWM or PWK 38mm carb, and pump-around fuel pump system (or GFS if money is not a problem)
You need some way to mount the fuel pump, the coil, and the ignition box. Lots of shops sell the mounts, or you can just bolt them to the back of the seat.
Get lots of 1/4" fuel line
You'll need a front gear that goes on the engine (typical sprint size: 15 or 16)
You'll need an axle gear (24, 25, 26 are good) and a 428 chain
Remove the power valve assembly and get the O-ringed plugs (they need to be blended) from a kart shop
Use 98 octane race gas or higher, 4-6 ounces of oil per gallon (synthetic or castor)
Get some CarbonTech medium reeds
Leave the cylinder, piston and head stock
joseph hollinger
PostPosted: Tue Feb 26, 2013 11:05 am    Post subject: Reply with quote
www.metal-matrix.com/s
Jim McMahon
PostPosted: Tue Feb 26, 2013 11:24 am    Post subject: Reply with quote
Could you get the VHSH30 from your Vortex to go onto the CR? I think the boot on the CR might be bigger though. That's what I'd be doing! It's a great carb for a shifter, would require a little to get your jetting figured out but after that you'd be fine.
Yes the pumparound setup came about because of fuel metering issues under cornering. The pumparound removes the floats completely and maintains fuel level by way of flow and return lines on the carb, as well as dual fuel pumps.
another setup utilized is the square mikuni fuel pump with a built in bypass.
Tyson Henry
PostPosted: Tue Feb 26, 2013 12:39 pm    Post subject: Reply with quote
Also a standard PWK or PWM with a smaller valve inlet seat and needle. Works great also.
Charles Frerking
PostPosted: Tue Feb 26, 2013 2:52 pm    Post subject: Reply with quote
this is all really helpful information, keep it coming. I feel more confident about doing this myself rather than purchasing a pre-prepped motor - I can handle all of these things.
Todd Kageals
PostPosted: Tue Feb 26, 2013 5:36 pm    Post subject: Reply with quote
If you are just out for fun, you can keep the carb that came with the '94. My kart ran just as well with that setup as it did with the pump around. I was not racing it though. I just got finished rebuilding two motors for stock Honda. I had lots of questions like you. The guys here were great and provided lots of help. Feel free to ask any questions you have. For your purposes, forget the power valves if they are operational. No need to spend money on the plugs and you won't notice the .1 sec you lost! Pipe, silencer, radiator, mounts for all the above, water hose or kit, fuel pump and a T....should get you going for not too much money. Also, save money by running a CR125 radiator. I could not get temps up above 125 with that radiator even when on track.....but again.....I was just having fun, not racing at that time. Good luck.
Page 1 of 3
DB time: 0.129982 (36.65%), total time:0.354636, queries:38
