marc-andre hubert
Posted: Mon Feb 25, 2013 9:49 am Post subject: check my tires. |
been reading alot about kart handling, and i feel very confortable in the kart, i always know what it will do, but i got alot of buildup on inside of tires front and back, check pic and if you could tell me whats up.
Britt Robinson
Joined: 22 Mar 2012 Posts: 73 Location: United States, Washington, Richland
Posted: Mon Feb 25, 2013 1:20 pm Post subject: |
You are going too slow and picking up rubber left behind from the 4cycle clones...  _________________ I am a precisional instrument of speed and aeromatics. - Mater |
Randy Mckee
Posted: Mon Feb 25, 2013 2:43 pm Post subject: |
You have anything more close-up? Difficult to tell, but those look completely shot. I personally don't read too much into tires that are well used-up. They almost always develop cupping on the inside edge, which is what I see in your tires. The grain pattern looks OK, but it's a little too far away to get a good read.
Now, if my tires looked like that after a few runs, I would say I have a massive entry push and slap over-steer. The reason I say that is the front inside edge is cupped badly. That can result from under-steer in any part of the turn. However, rears also have bad cupping on the inside edge which usually results from tire spin on exit of the corner (when applying power). Either condition can occur together or separately depending on how the kart is handling. The most common is to see fronts showing some under-steer.
Again, if they are wasted, don't read too much into the wear. Put a new set on when you're ready, and then take some pics after a few track sessions. _________________ Randy
#123 TonyKart - S4 Stock Honda |
Doug Ring
Joined: 30 Jul 2001 Posts: 1806 Location: United States, California, San Diego
Posted: Mon Feb 25, 2013 4:41 pm Post subject: |
| Randy Mckee wrote: | You have anything more close-up? Difficult to tell, but those look completely shot. I personally don't read too much into tires that are well used-up. They almost always develop cupping on the inside edge, which is what I see in your tires. The grain pattern looks OK, but it's a little too far away to get a good read.
Again, if they are wasted, don't read too much into the wear. Put a new set on when you're ready, and then take some pics after a few track sessions. |
Randy is spot on. Once tires begin to "go away", they will make any handling issues get worse and worse, which will exacerbate the problem. Put on a new set, drive them for a few sessions (or a typical race day), and/or until your lap times begin to get worse - that is the time when you will get a good read on tire consumption.
BTW - more information on your kart, setup, track, etc. would be helpful. For example, our local club races at the parking lot for the football stadium, which is a very abrasive surface - hence, we tend to get a lot of front tire wear on the TAG karts, regardless of class/weight. |
marc-andre hubert
Posted: Mon Feb 25, 2013 6:44 pm Post subject: |
well here is a video, first few laps im getting here in motor /tires so skip, these tires are old (2 races and this practice) and yes they are shot i have fresh ones in trailer but keeping them for march 30 race,
IIRC 46.5 " front 54.75" rear, medium axle/ hubs, 2 seat struts each side, good amount of castor, 3 neg camber, no rear bar, side bar and front bar in, 32mm chassis. seat 8.25" from top of axle, bottom is flush with bottom of rail, bearing out
http://www.youtube.com/watch?v=jlNdXc01YDo |
Jay McKeage
Joined: 21 Feb 2002 Posts: 74 Location: United States, Florida, Tampa Bay Area
Posted: Mon Feb 25, 2013 8:57 pm Post subject: |
thats palmetto, so best advice i would give u is to talk with kyle klepp or kevin greeno. they have garages there still i think and have been doing shifters a long time. looks like the tires have a lot of heat cycles on them and are worn out. next couple of times out you should start to see the chords. you do not learn much testing on tires like that for chassis set up. good luck and if u are in orlando this weekend stop by the tent.
jay |
marc-andre hubert
Posted: Tue Feb 26, 2013 4:35 am Post subject: |
| tires are in the garbage, was just looking for a idea if there too warn out then no worrys, i always change my tires before hand but was just having fun. |
