Ocala Gran Prix - LB
RLV - SS
DRT Racing - FB
KG Sprocket/Chain Cover Mounting...
Howard Trafford
PostPosted: Fri Feb 22, 2013 9:39 am    Post subject: KG Sprocket/Chain Cover Mounting... Reply with quote
I have a KG plastic sprocket/chain cover, like this
http://www.accelerationkarting.com/kgplasticsprocketcover.aspx
Should there be separate mounting brackets, or should the inside half be directly attached to the bolts that hold the right side bearing to the chassis?
TIA!
H
PostPosted: Fri Feb 22, 2013 11:06 am    Post subject: Reply with quote
I mounted one to the bearing carrier on a kart I had. Can't remember if it was connected directly with the same bolts holding the cassette or if it was attached to spare holes but definitely not with a separate bracket.
Cheers,
Heartbeat Power, LLC.
DB time: 0.234953 (53.36%), total time:0.440316, queries:38
