Ray Lovestead
Joined: 21 Dec 2011 Posts: 156 Location: United States, Colorado, Louisville
Posted: Mon Feb 18, 2013 8:49 pm Post subject: Rear right seat struts |
I have a (very) old DFM chassis that has seat struts on the rear right side that mount to the inner bearing cassettes bolts. It occurs to me that it is possible that this is pressing down on the INNER bearing when it should be pressing down on the OUTER right bearing.
Question: If you guys go out to your garage, do you see that your rear right seat strut is attached to your inner or outer bearing?
Ray _________________ "Karting Expert Since 2014" |
Posted: Mon Feb 18, 2013 9:16 pm Post subject: |
Sometimes you need a specially bent strut to get to the outside carrier, which is the preferred carrier to have the strut mounted to. _________________ T.J. Koyen
www.oktanevisual.com
Exprit/Leopard |
