marc-andre hubert
Posted: Sun Feb 17, 2013 6:43 am Post subject: carb overfilling. |
can't figure it out.. i clean everything i start it no fuel filling up on bottom of overfill tube on carb bowl cover, then out of nowhere it will overfill and well overfill and foul plugs
if i blow on fuel feed line into carb and hold floats at 90degree no air goes thru so no fuel should go in and overflow it? needle seat and needle are perfect. this is keihin cr125 no pump around, runs awesome 90% time..
any idea |
Joined: 13 Aug 2012 Posts: 452 Location: United States, Florida,
Posted: Mon Feb 18, 2013 6:11 am Post subject: |
Marc the fuel pump pressure is poping the the float needle. It's a common problem that happens because the carb is designed for gravity feed and we use pumps. There's a lot of posts on it and solutions try a search.
Brian |
Todd Kageals
Posted: Mon Feb 18, 2013 8:58 am Post subject: |
Marc,
Try adjusting the floats. My brand new PWK was doing this with my Dellorto fuel pump. I adjusted the floats about 1 mm and all is well now. Of course....you could just get it converted to pump around.
Todd |
marc-andre hubert
Posted: Mon Feb 18, 2013 11:45 am Post subject: |
thanks will reduce pressure first, since i have gone thru the floats a few time, and when its upside down at 90degree no air goes thru so fuel is being shut down at the rigth level,
on a side note, i went and tapped on side of carb gently and started it and everything is perfect. maybe needle got stuck open.. but will where i have the Y coming off the fuel pump i will now have 1 line direct from pump to carb and other direct back to tank. should not hurt anyway |
Jeff DeMello
Joined: 13 Sep 2002 Posts: 2219 Location: United States, Pittsburgh Pa,
Posted: Mon Feb 18, 2013 12:00 pm Post subject: |
Try Todd's suggestion first... _________________ Jeff DeMello
Emmick F125 Pavesi |
marc-andre hubert
Posted: Mon Feb 18, 2013 12:04 pm Post subject: |
| unless i got wrong info, i already adjusted, maybe im doing it wrong? but karts hauls and runs a1 then out of the blue it will overfill? if it was the floats it would overfill right away no? |
Tyson Henry
Joined: 10 Aug 2011 Posts: 359 Location: United States, Texas, Arlington
Posted: Mon Feb 18, 2013 12:13 pm Post subject: |
| Jeff DeMello wrote: | | Try Todd's suggestion first... |
I will +2 this.
Just try raising the float height 1mm. Then if it still does it, try another. If you go too high it will starve the motor during cornering. Once you get it just right it shouldn't lose fuel while cornering and there should be just a little overflow into your catch. |
Jeff DeMello
Posted: Mon Feb 18, 2013 12:14 pm Post subject: |
Check the needle and seat and make sure it is clean.. Do yo filter your fuel?? It sounds like your needle is sticking from debree in the fuel. _________________ Jeff DeMello
marc-andre hubert
Posted: Mon Feb 18, 2013 12:17 pm Post subject: |
only have filter from tank to pump not pump to carb. will add one now,
also when you say raising the floats it means pushing them up higher in the body not down into the bowl right. |
Jeff DeMello
Posted: Mon Feb 18, 2013 12:33 pm Post subject: |
Float lower into the bowl. You want less fuel in bowl. _________________ Jeff DeMello
Tyson Henry
Posted: Mon Feb 18, 2013 12:34 pm Post subject: |
| marc-andre hubert wrote: | only have filter from tank to pump not pump to carb. will add one now,
Raising the float height means higher from the seating surface. If the carb is upside down, the floats should be higher. The idea is that with less fuel in the bowl the floats will close the needle off. |
Jeff DeMello
Posted: Mon Feb 18, 2013 12:37 pm Post subject: |
Don't add another filter. The one you have is good enough. _________________ Jeff DeMello
marc-andre hubert
Posted: Mon Feb 18, 2013 6:14 pm Post subject: |
| thanks guys you all have been very helpfull, off to work and lapping this sat for results. |
Josh Michalosky Advertiser
Posted: Wed Feb 20, 2013 5:13 pm Post subject: |
We usually put a T in the fuel line between the carb and the pump, then run it back to the tank as a pressure release. _________________ Josh Michalosky
Accelerationkarting.com
1-888-466-KART
sales@accelerationkarting.com |
marc-andre hubert
Posted: Wed Feb 20, 2013 5:25 pm Post subject: |
yeah i have that.
fuel pump to Y then T at the carb one to carb the other back to tank, and of course i have the other return going straight to tank |
