MG Tires - SS
Franklin / Merlin USA - FB
Fast KPV2 w/mount, blueprinted carb, header, EGT sensor
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Engines
Saul Morse
PostPosted: Sat Feb 16, 2013 1:19 pm    Post subject: Fast KPV2 w/mount, blueprinted carb, header, EGT sensor Reply with quote
We're exclusively running Rotax now but have been holding onto a very fast KPV2 motor which we are now looking to sell. The motor is a Kaos (Phoenix, AZ) prepped motor which is on it's second piston from stock so lots of life left. The motor has one race on it and 3 light practices since it was last rebuilt. It was a really fast motor for us and consistently at the sharp end of the grid. Below is a screenshot of the last race on it (and the only race since rebuild) where we set fast time in the main at our local club race.
It comes with a very fast blueprinted carb as well as an Odenthal mount and header with EGT sensor. It has an old style clutch on it that I had left over, but it will need some freshening pretty soon. Would be good for a handful of practices most likely. I may be able to scrounge up an airbox and filter as well, but do not have a pipe at this point.
$800 obo takes it. I can be reached at saul (at) photoplace (dot) com or by phone at 623.850.3456. Currently motor is in the Albany, NY area and we will be starting spring practice at OVRP pretty shortly and could bring it down there as well.
Larger versions of these photos are available for closer inspection at http://www.photoplace.com/Miscellaneous/KPV2
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Engines All times are GMT - 8 Hours
DB time: 0.073187000000001 (44.32%), total time:0.165119, queries:38
