Joined: 04 Dec 2004 Posts: 1992 Location: United States, Michigan, Williamsburg
Posted: Wed Jan 23, 2013 7:57 am Post subject: |
Your most likely market for this would be minibike drag racers, Shane at AGK can point you in the right direction.
I'd be interested in testing one on my dyno though. Do you know how much power it'll take? Also how much would it cost the racer and does it take the standard Bully type drivers?
As for Kers for karts if anyone can design and build it for $400 they'll win the lifetime achievement award in my book, almost like me racing with extra weight
Heartbeat Power, LLC. |
Nathan Adair
Joined: 19 Dec 2011 Posts: 62 Location: United States, Florida, Orlando
Posted: Wed Jan 23, 2013 8:58 am Post subject: |
| Brian Degulis wrote: | | Take a shifter kart and select a gear that gives you a ratio close to TAG. Then go try it in that gear using the clutch as you describe. I think you would find dificult to drive and slower than a TAG. |
While you are probably correct on this, it would most likely be due to the narrow and peaky powerband of the shifter and not the clutch. My understanding and experience with TAG clutches is that they are locked up anywhere above 3500-4500 rpms, which you never get below on track. This is completely different than a Yamaha. If you get below stall with a TAG clutch during a hot lap, you're doing something wrong.
edited for clarity.
Last edited by Nathan Adair on Wed Jan 23, 2013 11:08 am, edited 1 time in total |
Danny Downs
Posted: Wed Jan 23, 2013 9:32 am Post subject: |
| John Matthews wrote: | Your most likely market for this would be minibike drag racers, Shane at AGK can point you in the right direction.
Cheers, |
Thanks for the heads-up. I will contact Shane at AGK as I'm sure that this product would definitely be beneficial to mini bike drag racing.
Yes it takes the standard Bully type driver. We haven't finalized cost yet, but we are looking at the range of $100-125 so definitely affordable.
I now realize that most of the people on here race, but speaking from someone who has driven yard karts all their life, this clutch is awesome for just having some fun. And with an affordable price, it does add a new dimension to driving go karts. |
My thoughts You don't run at 4500 RPM but when you take your foot off the gas entering a turn your TAG clutch dis engages. When you accelerate out of the turn the cluctch engages slowly. If it really locked up at 4500 then you would have very slow acceleration like you would in a shifter if you didn't drop gears. I think it would be very difficult to control the rate of engagement with a manual clutch. I'm no expert just my thoughts.
Brian |
Danny Downs
Posted: Wed Jan 23, 2013 10:00 am Post subject: |
| Brian Degulis wrote: | My thoughts You don't run at 4500 RPM but when you take your foot off the gas entering a turn your TAG clutch dis engages. When you accelerate out of the turn the cluctch engages slowly. If it really locked up at 4500 then you would have very slow acceleration like you would in a shifter if you didn't drop gears. I think it would be very difficult to control the rate of engagement with a manual clutch. I'm no expert just my thoughts.
Brian |
Instant positive engagement would be better. You're already moving so you can pop the clutch at RPM higher than normal stall speed for a track and get even more torque. For really tight tracks where you're almost stopping around turns this would be very beneficial. Sounds like most of you guys do oval racing so it wouldn't have much advantage there.
I appreciate the feedback and questions everyone, keep it coming! |
Jeff DeMello
Joined: 13 Sep 2002 Posts: 2213 Location: United States, Pittsburgh Pa,
Posted: Wed Jan 23, 2013 10:45 am Post subject: |
They race sprint tracks _________________ Jeff DeMello
Emmick F125 Pavesi |
Russell Stevens
Posted: Wed Jan 23, 2013 11:15 am Post subject: |
If you take your foot off of the gas, and the clutch isn't locked up... your engine would quickly drop to idle. The lock or partial lock of the clutch causes the engine to be driven by the wheels and maintain it's RPM relative to your ground speed. Exiting a turn at 4500RPM on my rotax is a slow climb till I hit about 6000RPM. This is a regular occurance when you take the 180 hairpin at our track slightly wrong. If you are getting a ton of drive at 4500RPM in a tag you either have a clutch that is slipping a lot at that RPM, or some crazy gearing. A centrifical clutch engages based on RPM, once engaged it doesn't care which side the rotational power is coming from. It will stay engaged until the rotational speed drops below it's lock threshhold. Model helicopters use the same type of clutch that the TAGS use (smaller scale) and have a one way bearing in the clutch. This is required to let the rotor "freewheel" for autorotation landings. If you don't have a one way bearing in the clutch the rotor blades slow down extremely rapidly when the motor flames out. This is because the clutch is locked till the RPM drops. I don't see a one way bearing listed for the Leopard or the Rotax. Try this experiment - Head down a long straight at about 10kRPM. Kill the ignition. Does the engine go silent or does it pop and try to turn over till your ground speed is slow enough to let the clutch dissengage?
Rusty
Brian |
Nathan Adair
Posted: Wed Jan 23, 2013 11:32 am Post subject: |
Brian |
In my experience, the only time my Leopard clutch disengages is when pulling off the track before coming to a stop and when the wheel speed is low enough (below ~4000rpm engine speed). On track, it acts just like a direct drive. That's why when you let off the throttle going down a straight, the engine just doesn't return to idle, it follows wheel speed because the clutch is engaged. Ever notice how the engine cuts when you stand on the brakes a little too hard and the rear locks momentarily? Same reason. |
Danny Downs
Posted: Wed Jan 23, 2013 11:56 am Post subject: |
| Russell Stevens wrote: | Try this experiment - Head down a long straight at about 10kRPM. Kill the ignition. Does the engine go silent or does it pop and try to turn over till your ground speed is slow enough to let the clutch dissengage?
Rusty
It's impossible. With a centrifugal it will not start the motor. This is simple Mechanics 101. As soon as you let off the gas, the engine wants to return to idle and it will not couple to the motor. Same reason you can't start a kart by rolling down a hill. Even if you were already started then killed the motor it wont bump start the kart.
Paul Makarucha
Joined: 11 Jun 2002 Posts: 860 Location: United States, New Jersey,
Posted: Wed Jan 23, 2013 12:36 pm Post subject: |
| Nathan Adair wrote: | | Ever notice how the engine cuts when you stand on the brakes a little too hard and the rear locks momentarily? Same reason. |
This is something that drove me nuts with the leopard (and would probably happen with any tag). The optimal carb setup does not allow for any idling. When you're off the gas that butterfly should slam closed and the engine should be forced to draw in as much fuel as possible (i.e. as little air as possible) for the impending return to the throttle. Just like an ICA setup.
The problem was during hard braking with a carb setup like this I would consistently chirp the rears enough that the engine would actually die. In more than one case I actually had to hit the starter and refire the engine mid-corner.
It was a very frustrating balance between optimal carb setup and adjusting my braking. _________________ CKR/KZ
CRG/ICA
http://Jaymotorsports.com
Do you have any special rituals when the helmet is concerned like many have? - "I wipe it so that I can see better." - Kimi |
Nathan Adair
Posted: Wed Jan 23, 2013 1:13 pm Post subject: |
| I've only had the engine completely die under serious panic-braking-style spin-inducing lockup. Otherwise it's never been more than a quick cut out under normal hard braking, and I usually try to keep the rears right on the edge of being talkative. |
Jim McMahon
Joined: 07 Apr 2007 Posts: 2685 Location: United States, St. Paul,
Posted: Wed Jan 23, 2013 2:39 pm Post subject: |
| Danny Downs wrote: | | It's impossible. With a centrifugal it will not start the motor. This is simple Mechanics 101. As soon as you let off the gas, the engine wants to return to idle and it will not couple to the motor. Same reason you can't start a kart by rolling down a hill. Even if you were already started then killed the motor it wont bump start the kart. |
Once engaged, the centrifugal (centripetal?) force comes from the speed of the rotation of the clutch assembly, it has zero to do with whether power is being applied or not. The clutch will stay engaged and spin the motor over until it drops below engagement speed. Cut the ignition at 10K, clutch will stay engaged until it drops below 4500 or whatever the engagement speed is. turn on the ignition before that point and it'll fire right up, assuming the motor is flooded or whatnot.
Also as hinted by paul, optimum carb setup and idling are usually in opposition of each other with a TaG running a pumper carb. _________________ Live in the midwest and have a TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart?
Russell Stevens
Posted: Wed Jan 23, 2013 2:49 pm Post subject: |
Danny,
I don't know your experience level with mechanics or karting. Please don't assume to educate me on mechanics 101. Try to follow along. Or read the "Cliff Notes" version that is posted just above this wall of text
1) When the RPM has reached the lock threshold for the clutch the axle and engine are locked together and will turn together at the ratio that is set by the gearing.
2) The only way to unlock the clutch is by dropping the speed of the engine below the lock threshold. Now unless the engine is seized, has a high enough compression ratio to cause slippage somewhere else in the system, the tires lock and slide, or the clutch slips and isn't really locked up this will only happen once the axle and engine have slowed enough to equate to an engine speed lower then the cluch lockup speed. Please refer to point one if this is confusing you. (hint: they are locked togetther by the clutch because the system is spinning above the lockup RPM)
3) Anyone who has driven a kart and locked up the brakes by accident and killed the engine will tell you that it either re-fires, or skids the tires and the clutch unlocks because the engine RPM fell below the threshold. At 10000 RPM if you shut the ignition off and turn it back on it will either re-fire or skid the tires. Either way the point that simply letting off of the throttle DOES NOT unlock the clutch is proven correct.
To your last point. you are correct. If the engine speed is not high enough to initially lock the clutch, the axle and engine are not coupled, and will turn (relatively) independent of each-other. However, this conversation is about what happend once the clutch drive section has been spun fast enough to force the friction surfaces to swing out and interface with the driven surface. Again once this happens it does not matter if the power is coming from the drive surface or the driven surface, and untill the RPM is low enough to allow the drive fingers to retract the two will remain coupled.
If you wish to go into this on a 201 or 301 level I'd be glad to explain the physics behind it for you.
Rusty
[/quote]
It's impossible. With a centrifugal it will not start the motor. This is simple Mechanics 101. As soon as you let off the gas, the engine wants to return to idle and it will not couple to the motor. Same reason you can't start a kart by rolling down a hill. Even if you were already started then killed the motor it wont bump start the kart.[/quote] |
Danny Downs
Posted: Wed Jan 23, 2013 3:01 pm Post subject: |
We are arguing the same point. I hold a degree in engineering so I am definitely well versed on the topic.
It's all about engine RPM and stall speed of the clutch. Once the engine RPM falls below stall speed, that's it you're decoupled. There may be a little slippage in the system but in a perfect world once you let off the gas it doesn't matter how fast you're going, the crank will decouple from the rear drive. Obviously if you skid and allow the motor to temporarily die, it's momentum will allow it to fire back up if the engine RPM was high enough.
We are arguing the exact same point! I like this kind of stuff, since when did internet forums get so technical!  |
Russell Stevens
Posted: Wed Jan 23, 2013 4:17 pm Post subject: |
My appologies sir. I took when you said the kart would not refire and that the clutch would decouple the instant the engine stopped running to indicate a disbelief in the principals of centripetal force. I can see from your most rescent post that this is only a partially correct understanding on my part.
Let me ask you something, one egg head to another. If you cut the ignition on the engine with the clutch in a coupled state, and you have an appropriate amount of inertia built up (in the form of the kart moving down the track), how is it that the driving portion of the clutch (the part with the fingers that is hooked to the output shaft of the engine) slows instantly past it's stall speed when it is being driven by the clutch bell that it is coupled to? If the clutch assembly is coupled and turning above stall speed what causes the centripetal forces that are keeping the fingers pushed against the clutch bell to simply vanish? My understanding was that the engine does not directly force these out into the bell, and that it was simply the rotational forces keeping them engaged. If this is the case, and again slippage in the system is not causing the driving portion of the clutch to loose RPM past the stall point, what forces are pulling the fingers away from the bell and causing the clutch to instantly disengage when the throttle is cut, or the ignition shut off at speed?
I understand what you are saying about RPM and stall speed, and think that you may be assuming that zero throttle <=> zero crank speed. This would be the only case where what you are saying makes sense. Throttle position has little to do with the actual crank speed when the crank is driven though an outside force (like an axle and a locked clutch).
Rusty |
