IKF Region 7 - LB
K1 Speed - SS
SCCA Enterprises - FB
Does it matter if I mount my motor closer to the axel?
Greg Narvas
PostPosted: Fri Jan 18, 2013 2:18 pm    Post subject: Does it matter if I mount my motor closer to the axel? Reply with quote
Im currently bulding my first shifter and i have a 2007 birel cr32 and I just finished rebuilding my 98 cr125 motor. I have a steel psr engine mount and I have a med ribtech carbon seat exactly where I want it. This morning I put the motor on the kart for the first time and of course, the motor was hitting the seat so that the motor would not clamp onto the Kart's rails ( just barely). I removed the engine bump stop off the rear cassette so that I could mount the motor flush on the rails but now the motor is sitting an inch forward from the Axel's bearing cassettes. Is that ok to mount like this? Is there a preferable mounting position for the motor (ex. Is the motor supposed to be centered over the rail that is perpendicular to the rest of the frame rails?). Is there a certain distance the motor has to be away from the axel? Thanks!
Matt Dixon
PostPosted: Fri Jan 18, 2013 2:51 pm    Post subject: Reply with quote
Ill start with this, if I don't have the motor stop agaisnt the motor after about 8 laps the chain will be to loose. No matter how much I torque the mount.
Matt Dixon
94y Energy Corse/Swedetech
Greg Narvas
PostPosted: Fri Jan 18, 2013 3:15 pm    Post subject: Reply with quote
Ok so I'll reinstall the bump stop as far back as it will go for the mount mount to rest on. Will that be ok? Or would it be better to move the motor forward and reposition the seat?
Matt Dixon
PostPosted: Fri Jan 18, 2013 3:56 pm    Post subject: Reply with quote
If it handles good to you no problem, unless your chain is to long, hyme joints on shifter rod aren't stressed, shifter lever isn't to close to the wheel... You are limiting range for gear changes but multiple chains can fix that.
Motors the second heaviest thing so it may be better forward but until you test your kart no way to tell
Matt Dixon
joseph hollinger
PostPosted: Fri Jan 18, 2013 5:15 pm    Post subject: Reply with quote
I'm willing to bet that "exactly where you want it" is the wrong place for the seat.
Steve Buckner
PostPosted: Fri Jan 18, 2013 5:25 pm    Post subject: Reply with quote
http://a248.e.akamai.net/origin-cdn.volusion.com/vwkg9.anhp6/v/vspfiles/photos/Engine%20Mount%20-%20CR125-2T.jpg
This will move the engine over approximately 8mm, left to right.
SwedeTech CR125 Aluminum Mount Wink
Sam Zavaglia
PostPosted: Fri Jan 18, 2013 7:28 pm    Post subject: Reply with quote
Found this on the web
* Adjust the engine from left to right for proper clearance approximately 12mm, left to right More adjustment then any other mount
* Engine Mount sits the rear of the engine up to 1" lower most other mounts
* Anodized 6061 T6 Aluminum Alloy Engine mount
* Chassis clamps designed for 1 bolt per clamp
* Proper machining from front to back, engine will not be twisted when mounted to a straight frame.
* Proper radius on frame contact point
* Left side of rear engine mount machined to allow for chassis cross tubing weld clearance.You will not find a better motor mount . With the
Sharkshifter factory Pricing. $199.00
www.samzavaglia.com
andy graham
PostPosted: Sat Jan 19, 2013 2:48 pm    Post subject: Reply with quote
AMC racing out of Washington state makes a cool engine stop that mounts between the rails..super easy to adjust the engine placement and about $25...it works and was designed by shifter drivers for shifter drivers.
DB time: 0.162458 (45.41%), total time:0.357774, queries:38
