Bondurant - LB
Brett King Design
SODI Celesta 2012 OFFICIAL RMAX CHASSIS
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Chassis
Sam Beasley
PostPosted: Tue Jan 01, 2013 1:44 pm    Post subject: SODI Celesta 2012 OFFICIAL RMAX CHASSIS Reply with quote
Like new and never raced is a 2012 Sodi Celesta for sale. This chassis has no wear to the bottom of the frame. It was only used for testing purposes. Comes complete with wheels, Rotax motor mount, seat, and exhaust brackets. There are also spare caster/camber pills as well as an additional rear bumper.
-$2,700 complete. Shipping methods or Pick Up can be arranged.
-Contact Ben or Sam at 1-440-413-4803 or ben@3ace.net
-No Private Messages.
-Chassis specs as followed..
-http://www.sodikart.com/en/kart-celesta.html
• Wheelbase : 1040 mm
• Frame : Double tube removable, CIK approved
• Removable front stabilizer, adjustable front chassis geometry using eccentrics
• Tube : Chrome molybdenum steel, ø 28 / ø 30
• Rear axle : Hollow steel, ø 50 - 3 bearings, ø 80
• Axle bearing supports : Anodized, quick release, ø 80
• Stub axles : ø 25 mm
• Rear hubs : Long with twin pinch bolts, anodized, fully machined, L. 90 mm
• Brake: 4 pistons hydraulic brake system. CIK approved under number 37/FR/14
• Brake disk : Floating, turbo ventilated, thickness 18 mm with increased ventilation
• Front wheels : Magnesium, 130 mm
• Rear wheels : Magnesium, 212 mm
• Tank : Removable 8,5 L
• Seat : Clear polyester
• Steering wheel : Aluminum with suede-type covering, Sodi logo embroiled
• Security : Protective base plate for brake disk, brake pedal with 2 points attachment, integral chain
• Cover, anti-locking bar
• Frame colour : Dark grey + varnish
• Bodywork : KG Sodi CIK approved
• Rear bumper : KG plastic
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Chassis All times are GMT - 8 Hours
DB time: 0.152968 (59.85%), total time:0.255598, queries:38
