KartSport North America - LB
RLV - SS
SCCA Enterprises - FB
Electric kart stands
Goto page 1, 2  Next
Billy Smith
PostPosted: Tue Dec 18, 2012 8:59 pm    Post subject: Electric kart stands Reply with quote
I have been looking for an electric kart stand for a while. However all the ones I find seem like they are insanely heavy.
What is the point of having a 1-person kart stand if the stand itself weighs 60 or 70 pounds???????????????
So that way you can lift the kart, except you still need help to lift the stand itself. Rolling Eyes Doesn't that completely defeat the purpose of a 1 person stand? At that point I would rather save the cash and find somebody to help me lift the kart onto the regular stand.
Aren't there any lightweight 1 person stands out there?
Also, who came up with the idea of supporting the entire weight of the kart by the rear bumper? Seems like a bad idea. Aren't there any designs the distribute the weight of the kart more evenly?
David McDowell
PostPosted: Tue Dec 18, 2012 9:18 pm    Post subject: Reply with quote
I love my electric kart stand and have created an easy way of loading it in and out of the trailer. I do see the down size for only lifting from the rear bumper but take one look at a kart and there is no other location to grab a kart from. I have seen a few that act like a scissor jack at a tire shop and slide under the frame but they are all pneumatic.
If you transport your kart in the back of a truck then I would stick with a normal stand for ease of loading and unloading.
Tim Koyen
Advertiser
Advertiser
PostPosted: Tue Dec 18, 2012 10:18 pm    Post subject: Reply with quote
Just get one that isn't electric. There are plenty of one person stands that weigh less. My Pro KartLift weighs under 50 lbs. and folds up small.
http://kartlift.com/pro.php
Most my customers that buy the heavier electric stands just roll the stand into the trailer. They aren't lifting it anywhere, so the weight isn't a big issue. Durability is more important, so I overbuild it.
www.kartlift.com
www.facebook.com/kartlift
Justin Martin
PostPosted: Tue Dec 18, 2012 10:19 pm    Post subject: Reply with quote
I currently load my kart up into a 95 yukon. It fits perfectly with the side pods removed, however there is only enough room for a folding stand.
I ran into some less than helpful advice from one of the owners of one of the companies building self lifting stands... Long story short he had some very negative thigns to say. Until you look at his stand and it comes with a harbor freight winch! ::palmface::
Anyhow, I am currently drawing up my own It will be winch power as well, however the winch strap will be on a removable hook. It will incorporate a trailer hitch, and simply by repositioning the winch strap to a different location it will rotate its self vertically on the back of my vehicle.
I currently have 2 designs drawn up, both of which use a winch, one is based on the same principles as the currently available self lifting stands. The other, is a design similar to a scissor lift. When the stand is all the way down and the front casters rotate, collapsing the front down so the kart doesn't scrape the front bumper. As you lift the kart it pulls it onto the stand until it hits a stop on the back of the stand, it then proceeds to pull the scissor lift together at the bottom lifting the kart. Doing it this way will allow for adjustable height as well as the ability to push the kart off the stand and into the back of my truck!
I'll keep you updated if you'd like
David McDowell
PostPosted: Tue Dec 18, 2012 10:24 pm    Post subject: Reply with quote
I couldn't remember the name of mine but after watching the videos it is a old kartlift.
John Van Nghiem
Advertiser
Advertiser
PostPosted: Tue Dec 18, 2012 10:40 pm    Post subject: Reply with quote
Check out the Dalmi electric stand. Incredible quality, lightweight, compact with four big wheels.
http://www.ekartingnews.com/viewtopic.php?t=119585
Fastech-Racing / Woltjer Racing / Swedetech Racing
Toll Free: 1.888.333.4181 or 831.384.5278
www.fastech-racing.com
Billy Smith
PostPosted: Tue Dec 18, 2012 11:34 pm    Post subject: Reply with quote
Looks nice, have there been any issues with the new style plastic bumpers being able to support the weight of the karts?
Billy Smith
PostPosted: Tue Dec 18, 2012 11:37 pm    Post subject: Reply with quote
According to the description it weighs 66 pounds. That is fairly heavy for one person to lift by themselves.
Cory Ross
PostPosted: Wed Dec 19, 2012 12:07 am    Post subject: Reply with quote
I have toyed around with the idea of something more like a snowmobile stand. The biggest issue is with wheels to make the stand mobile with a kart on it means getting the kart onto the lowered stand would be a problem. for a stationary stand lifting one end of the kart and sliding the stand underneath would not be hard at all.
You can use a hand crank or just hook a drill to the end of the screw jack to lift and lower the stand.
I guess you could have four small ramps to roll the kart up onto to lift it the initial amount to roll the stand underneath the kart.
Justin Martin
PostPosted: Wed Dec 19, 2012 12:33 am    Post subject: Reply with quote
I have an easier idea for the tilting....
Anyhow for his purposes I would agree that the pro wouldn't be bad, its light weight and easy to use.
I am making my own because I wanted something that didn't NEED to constantly pull on the bumper to stay up. I wanted something adjustable height, and most of all it needs to go on a trailer hitch as I don't have enough room in the truck
Billy Smith
PostPosted: Wed Dec 19, 2012 3:14 am    Post subject: Reply with quote
Your designs sound interesting. Please update this thread with your progress.
Billy Smith
PostPosted: Wed Dec 19, 2012 3:23 am    Post subject: Reply with quote
These Stone Kart stands seem interesting. They support the kart at four central points on the chassis instead of the rear bumper. Has anybody tried one?
http://www.stone-kart.eu/index.php/Stone-Kart-Trollies/LIFT-KART-TROLLEY-4WD-CIK-+-BRAKE/flypage_images.tpl.html
They also have a really slick vertical stand that looks like it also only requires one person to use.
http://www.stone-kart.eu/index.php/Stone-Kart-Trollies/VERTICAL-STAND-TROLLEY/flypage_images.tpl.html
Billy Smith
PostPosted: Wed Dec 19, 2012 3:27 am    Post subject: Reply with quote
Here is a link to a video of the Stone Kart stand in action.
http://youtu.be/nDaRuVXVANY
mike wallace
PostPosted: Wed Dec 19, 2012 5:14 am    Post subject: Reply with quote
Billy I actually seen the guy in the video at WKA roadracing series with that kart stand. He drives a mini cooper and fits kart and stand, seems to work great. I currently also use the larger heavier style but also have trailer so no issues.
http://mancaveracing.com
Woodbridge Kart Club
DR Racing Kart
Brian Fisher Race Engines
Stock Honda
Billy Smith
PostPosted: Wed Dec 19, 2012 5:35 am    Post subject: Reply with quote
Is it a regular Mini Cooper, or is it one of those Clubman versions that have the extended wheelbase and the two doors in back instead of the hatch?
Either way, does he really get a full size kart to fit inside?
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.161047 (41.31%), total time:0.389821, queries:38
