2D2W - LB
Brett King Design
44' trailers with living quarters. $43,000 - trade
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Misc.
Richard Davies
PostPosted: Wed Dec 12, 2012 7:28 am    Post subject: 44' trailers with living quarters. $43,000 - trade Reply with quote
2010 Millennium (Vintage) Gooseneck Living Quarters
This is a beautiful custom trailer I ordered. We have used it the last two years with no problems. Forty-four (44) foot overall length with 16’-6” living quarters. The entire trailer has an extra 1’ height and the portion over the gooseneck has an additional foot (2 feet total) so you can move around without hitting your head. Has a 6 foot slide out to give you extra space inside. I travel with my wife and two daughters so we made this as comfortable as possible. There is a lot of cabinet space in both living quarters and garage area for storage of cloths and tools.
The front is 16'6" LQ package. Complete kitchen, bath and sleeps 6. Built in bunk beds sleeps two, two couches convert to beds and room for a queen size above gooseneck. Two extra feet of height above gooseneck so you can move around comfortably, and an extra foot for the rest of the trailer.Smooth side so it is ready for graphics. Rear of the trailer has cabinets across the front. Trailer listed at $63,000 when new. Tapered front so it can be pulled with a short box. Still has a warranty on it until March of 2013. Triple 6,000 pound axles.
Total floor space in the cargo area is 17'-4".
E-mail me for pictures, details or call me.
Want to sell this so make me an offer.
We are looking for a smaller trailer since we are now short track racing a midget. I will take a smaller TAG trailer in on partial trade.
Can work with you on delivery.
richandlesliedavies@gmail.com
765-464-4229
The following is from the build sheet.
Interior Features
Built in bunk beds
Double couches that convert to beds and have tables
Sink
Large 8 cubic foot refrigerator and freezer
Stove top
Extra counter space
Bathroom with shower
50 amp 110v electrical package (no generator)
Grey water Tank 60 gallon
Black water tank 30 gallon
Clear water tank 59 gallon
3 burner stove with oven
6 gallon propane hot water tank
Monitoring system for tanks (not propane)
Cherry colored interior option
Two televisions
Antenna and cable hook-up
Inverter mounted in trailer to run AC items off batteries.
Exterior Features
Screw less exterior
Rear 8’ of trailer is walk on roof
Power landing gear jack (center powered side manual).
Built in ladder to access roof
Side quartz lights
Garage Features
Front to rear E-track on the floor and double E-track on the walls, one high one low to secure gear to the side of the trailer
Cabinets across the front high and low with a stainless steel bench top
Coin rubber floor
RV side door
Swing out quartz lights
Complete specifications for the trailer per work order:
1 102" Body Width -Standard-
1 6' 6" Interior Height -Standard-
1 96" Interior Width -Standard-
1 82" Between Wheel Wells -Standard-
1 Bull Nose - Front Cast Corners W/ Brite Anodized Top Wrap -Standard-
1 1 Piece Aluminum Roof -Standard-
1 .030 Aluminum Exterior -Standard-
1 Heavy Duty 8" Tubular Main Frame Rails -Standard-
1 Wall Construction: 1" X 1 - 1/2" Steel Box Tube Sidewalls W/ Dust Shield -Standard-
1 White Vinyl Walls & Ceiling -Standard-
1 3/4" Plywood Floor W/ Darco Moisture Barrier -Standard-
1 16" On Center Walls, Ceiling & Floor -Standard-
1 All Wheel Electric Brakes -Standard-
1 Dexter E-Z Lube Torsion Axles -Standard-
1 15" Radial Tires With Silver Mod Rims -Standard-
1 Chrome Center Caps W/ 6 Lug Nuts -Standard-
1 48" Side Door W/ Flush Lock, Deadbolt & Piano Hinge ( Selection of LQ Option
Will Changed Size and Availability)
-Standard-
1 Turn Signals Over Fenders -Standard-
1 L.E.D.Tail Lights In Uprights -Standard-
1 Painted Under Carriage - Z-Tech Undercoating -Standard-
1 ATP Stoneguard -Standard-
1 Spring Asst. Ramp Door A.B.S. Spring Cover & 16" Flap -Standard-
1 Ramp Door Trimmed W/ Mill Finish Aluminum -Standard-
1 4' Sculpted Beavertail -Standard-
1 4 - D - Rings Loose -Standard-
1 1 Non Powered Roof Vent -Standard-
1 Automotive Style Weather Stripping -Standard-
1 2 - 12V Lights W/ Switch -Standard-
1 Three Year Factory Warranty -Standard-
1 2 Cambar Locks On Ramp Door W/ 2 Grab Handles -Standard-
70 M-TDET-1 E-Track: (pmf) ( Surface Mounted)
1 DM 2ND PART WALL DOOR
1 DM ALUMINUM WB TOP ILO RUBBER
1 DM BUILT-IN BUNKS ILO FOLD DOWN
2 DM CABINETS AT BUNKS
1 DM CUSTOMER SUPPLIED BOX SPRING!
1 DM DELETE MICROWAVE
1 DM DOUBLE SOFAS WITH TABLES
1 DM FENCE IN OLD MICROWAVE SPACE
1 DM GRAY TANK 60 GAL
1 DM LEAVE 110 WHERE MICR WAS
1 DM TAPERED GOOSENECK
1 DM UPCHARGE OVEN W 3 BURNER STOV
35 M-TDEREC Recessed E-Track On Floor Only (pmf)
1 CHERRY CAB TO BE CHERRY COLOR 0.00
1 M-AU5260TA3/5200# Axles Upgrade To 3/6000# Axles (16" Tires)
1 M-4412G 12" Extra Height(44 G N) 831.25
36 .040 Smooth Side Exterior 7'6" High
( Must Add Extra Height To Trailer)
1002 1,436.40
8 .040 Smooth Side Exterior 8'6" High
1004 3
1 M-WAPW@GPartition Wall at Gooseneck Riser
1 M-WAPW1F 12" Extra High Partition Wall
20 M-INSC Insulated Ceiling
20 M-INSSWEX 7'6" High Insulated Side Walls
1 M-LQ1EXHL 12" Extra High Living Quarters
1 16' B- Bunk W/ Slide Lounge Area Standard Feature:
6' Slide
Walls & Ceiling Insulated
White Ceiling
Decorator Wall Board
Gas Refrigerator 8.0 Large
Propane Package Includes: Gas Furnace, Gas Stove Top, Stove Hood, Gas Hot Water
Tank, LP & Co2 Detectors, LP Bottles
Complete Dry Vented Bathroom Includes: Shower W/hide-Away Door, Vanity &
Stool
Microwave
Dinette Folds Down To Bed
Fold Down Couch (72')
(2)-32" X 72" Bunks
Queen Size Mattress With Spread
Roof Vent Wired & Framed for A/c
Tinted Windows:
2 - 30" X 22" (1 Egress) Window
1 - 30" X 15" Window
1 - 48" X 22" Dinette Window
Valances & Mini Blinds
Oak Raised Panel Cabinet Doors
Stainless Steel Sink & Faucet
Formica Counter Tops:
Lavatory, Kitchen & Table
4 Door Closet Above Bed In Gooseneck
2 Door Closet W/ Shelf
Cabinets Above Sink
Cabinets Above Dinette
Plush Tan Carpeting On the Riser Wall and Bed Area
City Water Hook Up
50amp Panel W/life Line
12-Volt Lighting
110v Receptacles
Battery, Box & Converter
Pressurized Hot & Cold Water System W/tanks
12-Volt On Demand Water System
30-Gallon Fresh Water
30-Gallon Black Water Tank
30-Gallon Gray Water Tank
6 - Gallon Hot Water Tank
Rv Step
Rv Door W/screen
Acrylic or Large Grab Handle
Porch Light W/switch
Smoke Detector
Fire Extinguisher
1 M-LQAC15R 15,000 BTU Coleman Air W/remote Thermostat
1 M-LQ59FW 59 Gallon Fresh Water Tank In Lieu 30 Gallon
1 M-LQMS Monitoring System for Holding Tanks
1 M-LQANTCB Antenna W/cable Hook-Up for T V
1 M-EXTVPLU Outside Cable Hook up - T V
1 M-LQSTERE AM / FM Stereo W/ CD Player & 4 Speakers
2 M-LQXCLGN Extra Closet In Gooseneck (each)
1 M-LQGRAB Large Grab Handle @ R V Door
1 M-RVW&F Roof Vent: Wired & Framed for Future A / C
1 M-RV12VRV 12 V Roof Vent W/ Switch
1 Racing Light Package:
4 - 4' Fluorescent Lights W/defuser
2 - 110V Recessed Quartz Lights
2 - 12V Chrome Loading Lights
4 - 12V Chrome Dome Lights
4 - 110V Recepts
2 - 110V GFI Recepts
2 - 110V Switches
1 - 12V Switch
50 Amp Box With Lifeline
1 M-ERDLWS 2-500 Watt Quartz Lights Out Back Door W/ Switch
2 M-EEXCABL Extra Cable Hookup for Tv
1 M-FLRDFWD 36" Ramp Door Flaps W/ 3' Bumpers On Plywood Ramp
1 M-GFLDR14 14"x14" Fuel Door W/ Keyed Lock
1 M-COHC24 24" Tall Straight Overhead Cabinet:
1 M-CWBS 36" High Straight Workbench
1 M-CDRAW 4 Drawers Added To Workbench
1 M-JSHJBGNLSingle Hydraulic Jack & Battery W/ Std. Jack & Access Door
1 M-D32RVDW32" RV Door W/ Window & Screen In Lieu of 48" Side Door
1 M-DRLD Recessed Cam Lock On Back Door In Lieu 2 Cam Bars
1 M-RFSR240 Sprint Roof 24" H X 0' To 10' Long
8 M-RFWOR Walk On Roof ( P M F)
1 M-LARL Recessed Ladder
1 M-LARL1EX 12" Extra High Recessed Ladder
1 M-SPCRFH Recessed Spare-Tire Compartment W/ Hinged Lid 36"x36"
1 M-WHSPOKE6000# 16" Silver Spoke Spare Tire & Wheel: 235/75/16
2 M-WN1518R 18"X15" RADIUS SLIDER WINDOW
1 M-WNEGRES30"x22" Egress Window ( Roadside)
2 M-LQB&V15 15"x18" Window Blind & Valance
1 M-LQB&V30 30"x22" Window Blind & Valance
1 ENGFEE ENGINEERING FEE
1 REARDOOR REAR DOOR HEIGHT 7'6"
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Misc. All times are GMT - 8 Hours
DB time: 0.147218 (41.9%), total time:0.351359, queries:38
