Bondurant - LB
Streeter - SS
KG Plastics - FB
Yamaha Peak Torque
george wilson
PostPosted: Wed Nov 28, 2012 5:50 am    Post subject: Yamaha Peak Torque Reply with quote
What would be the average peak torque (at what RPM) on a Yamaha KT100 set up for Senior or Master classes?
Patrick Hubbell
PostPosted: Thu Nov 29, 2012 12:44 pm    Post subject: Reply with quote
With a pipe, peak torque is between 9,000 and 10,000 rpm
Patrick Hubbell
patrick slattery
PostPosted: Fri Nov 30, 2012 2:39 pm    Post subject: Reply with quote
8400 to 8600 on a SSX Can. We have seen 10300 to 10500 on a L2 pipe
al nunley
PostPosted: Sun Dec 23, 2012 5:15 pm    Post subject: Reply with quote
On my dyno, in the late 80’s, the KT100 reached peak torque right at 10,300, plus or minus a little, with all fixed pipes.
Testing at the track is good if you don’t have a dyno. Play with the clutch and see what happens.
Brian Spek
PostPosted: Fri Dec 28, 2012 7:29 am    Post subject: Reply with quote
when buying at kt100, what is a good dyno reading for hp? can class.. thanks.
al nunley
PostPosted: Fri Dec 28, 2012 4:59 pm    Post subject: Reply with quote
A little lower on my dyno, but that could just be the difference between my dyno, a water break, and yours.
patrick slattery
PostPosted: Wed Jan 09, 2013 5:01 pm    Post subject: Reply with quote
Brian, you can't go by one guys dyno vs another one. They are all different, calibration is not always the same, etc. You want to be more interested in how your motor compares to other engines on that same dyno. Some will get 18.00 hp on a can while other dynos will only show 12-13 with the same motor. It's all about comparison from a knows dyno source.
DB time: 0.111226 (36.08%), total time:0.308271, queries:38
