Bondurant - LB
Russell Karting - SS
2201 CR125 Cylinder
Goto page Previous  1, 2, 3, 4, 5  Next
Tyson Henry
PostPosted: Wed Nov 21, 2012 8:37 pm    Post subject: Reply with quote
Venkat Reddy wrote:
Reading Alex\Steve comments on the 01 cylinder, am going to try a 01 cylinder, my right elbow sure could use some relief
Mine too! Elbow is bruised and beat up every time out.
Alex King
PostPosted: Wed Nov 21, 2012 9:37 pm    Post subject: Reply with quote
You guys should definitely give it a try and I am certain that you will not regret it. My only regret is that...it took about 4 years for me to finally try it - should have done it earlier. The engine keeps cleaner...give gives you a bit more elbow room...it sounds better...power delivery is better hence easier to drive so that you can just go faster and longer and faster and longer...don't confuse this with a viagra ad haha!
Now...make no mistake about this guys...if you do go for 01 cylinder, the best engine builder for that is MRC (Musgrave Racing Company). They just made their debut at SKUSA SuperNats last week...two drivers only competing there...one went home with the 'S2' title...
Chris Laird
PostPosted: Wed Nov 21, 2012 10:21 pm    Post subject: Reply with quote
I can't help but wonder if everybody that watched the S1 race would disagree. Any thoughts on Fritz's motor Alex?
Alex King
PostPosted: Wed Nov 21, 2012 10:57 pm    Post subject: Reply with quote
No thoughts but since you mentioned. I just looked it up and saw that Billy qualified on pole with 44.827 while this guy Fritz qualified in 8th with 45.101. But to be quite honest, I think you are comparing apples with oranges since Billy ran in S2 and the person you mentioned (Fritz) in S1. I am confused with your comment, are you suggesting that Billy is better than Fritz?
Jimmy McNeil
PostPosted: Wed Nov 21, 2012 11:18 pm    Post subject: Reply with quote
In the warm up Fritz did a 44.3 Shocked s2 was a 44.8
Cant remember what happened to him in qual, he prob had one wheel fall off to do a 45.1 Wink
Chris Laird
PostPosted: Wed Nov 21, 2012 11:20 pm    Post subject: Reply with quote
I definitely wasn't saying that Billy is better than Fritz. No way to tell since they race at different times. I was saying Fritz had the best stock Honda at the track and it was an 01' built by Swedetech. If you would like to compare lap times though you may be interested to know that Fritz's fastest lap was only about 5 tenths faster. I can definitely see how a half second isn't a big deal. I do understand your loyalty though.
Mike Goebel
PostPosted: Thu Nov 22, 2012 1:17 am    Post subject: Reply with quote
Qualifying S2 Pole
Billy Musgrave 44.827
Home built Engine with $30 fuel pump Shocked
Qualifying S1 Pole (15 min later) Shocked
Simas Juodvirsis 44.917
Euro KZ2 2012 champion
Engine builder???
Shocked Shocked Shocked Shocked Shocked Shocked
Mike G.
Simas Helmet did look better though!
Closet KZ Lover!!!
mfg Technology Centre
Steve Buckner
PostPosted: Thu Nov 22, 2012 10:38 am    Post subject: Reply with quote
Mike Goebel wrote:
Qualifying S2 Pole
Mike G.
SwedeTech avengers are coming, everyone run.
Chris Laird
PostPosted: Thu Nov 22, 2012 10:42 am    Post subject: Reply with quote
Billy. Fritz
Heat 1 45.429 15 mins 44.934
Warm up 45.178 10 mins 44.596
Heat 2 45.189 45 mins 44.911
Heat 3. 45.235. 15 mins. 44.851
Warm up 44.875. 20 mins. 44.363
Main. 44.957. 75 mins. 44.678
So when you look at the times Billy was faster or slower? I watched all of the S2 AND S1 races and Fritz would pull 8-10 kart lengths on the straight. Didn't see that in S2. Maybe 3 lengths at most. Maybe seeing is believing?
Alex King
PostPosted: Thu Nov 22, 2012 11:55 am    Post subject: Reply with quote
If I was the owner of SwedeTech, I would meet with my attorney(s) to explore way(s) to prevent Mr. Laird from referring to the SwedeTech name on public forums. As an end consumer who is not exclusively limited to SwedeTech – as I have bought engines from Woltjer, DDR, SwedeTech and MRC – I personally find Mr. Laird a significant turnoff to the SwedeTech brand, and believe he makes other end consumers less likely and/or doubtful in purchasing SwedeTech products.
Mike Goebel
PostPosted: Thu Nov 22, 2012 12:14 pm    Post subject: Reply with quote
Chris Laird wrote:
Billy. Fritz
If I'm reading this data correctly its shows that on average the later session times resulted in faster lap times. This of course follows the typical increase in rubber being laid down creating a more preferred traction surface resulting in faster turn speeds for the same radius allowing higher G loads to achieve quicker section times. This in it self makes Billy's qual time even more devastating to the "Pro" drivers with the "Pro" hand picked equipment Wink Shocked
Billy would have WON S1 easily Shocked
Mike G.
BTW my helmet would have looked better on either driver than that crap they were donning.
Closet KZ Lover!!!
Chris Laird
PostPosted: Thu Nov 22, 2012 12:48 pm    Post subject: Reply with quote
Well Mike, unfortunately you're not reading the data correctly. Your theory has a few holes in it. If it was correct, the fast times would swap from the end of a session to the beginning of the next. Ex. Billy would have a faster time for his warm up than Fritz did in heat 1. Then billy would be faster in heat 2 than Fritz in his warm up and so on. You don't even need a complicated formula to figure that out. At this point we should probably all just pop open a Sierra Nevada and admire your helmet. That's something we all agree on. Very Happy Very Happy
Ryon Beachner
Advertiser
Advertiser
PostPosted: Thu Nov 22, 2012 12:57 pm    Post subject: Reply with quote
How disrespectful are you people to drivers that you actually think engines are what win races at this level?
2Wild Karting
www.2wildkarting.com
Shop: (949) 206-9906
Ryon Beachner
Advertiser
Advertiser
PostPosted: Thu Nov 22, 2012 12:58 pm    Post subject: Reply with quote
delete.
2Wild Karting
Mike Goebel
PostPosted: Thu Nov 22, 2012 1:06 pm    Post subject: Reply with quote
So waht you are saying Ryon is that you finished 17th because of the dirvers ability Laughing Laughing Laughing Laughing
Mike G.
P.S. your Helmet should have put you farther up the grid Wink
Closet KZ Lover!!!
Page 2 of 5
DB time: 0.073731000000001 (39.55%), total time:0.186441, queries:38
