Jake Rathert
Posted: Sun Nov 11, 2012 9:32 am Post subject: prd spark plug? |
| What spark plug do most people use for the prd motor? I am using a W29ES-ZU plug right now but trying to find a replacement is a pain. Anybody know who carries them or is there a better more available plug I should use? Thanks |
Bret Moreland
Posted: Mon Nov 12, 2012 10:02 am Post subject: PRD Spark Plug |
I use NGK BR10EIX for hot weather and NGK BR9EIX for cooler weather. If you are planning to run the PRD Spec class you must run NGK standard BR8EG, BR9EG or BR10EG. Never had any kind of plug issue using the NGK Iridium.
You can get them at your local kart shop or auto parts store. You may have to order them from the auto parts store, they usually don't stock them. You may also want to try a local motorcycle shop, they usually have them in stock but I find that they are a little more expensive.
Bret Moreland _________________ Bret Moreland
PRD Spec Heavy
TAG Heavy
RLV
A-BETT-ENT
Avanti MMK
bretzeke@aol.com |
