MIR Racewear - LB
Ribtect - SS (non-flash)
Leading Edge Motorsports
LEOPARD CLUTCH
peter MAZZARELLA
PostPosted: Thu Oct 11, 2012 4:34 pm    Post subject: LEOPARD CLUTCH Reply with quote
PUTTING MY CLUTCH ON LEOPARD ENGINE FOR ROAD RACING DO I NEED TO USE A KEY-WAY OR IMPACT IT ON.
Paul Makarucha
PostPosted: Thu Oct 11, 2012 7:33 pm    Post subject: Reply with quote
Yes to both and make sure to lap the clutch!
CKR/KZ
CRG/ICA
http://Jaymotorsports.com
Patrick Hubbell
PostPosted: Mon Nov 12, 2012 12:25 pm    Post subject: Reply with quote
Definitely lap the friction hub to the crankshaft using valve lapping compound.
No impact wrench here. use a torque wrench and a piston stop. The 24mm nut is the critical one and it is left hand thread. When torqed and installed correctly you should be able to see at least one full thread beyond the face of the nut. Be sure to install the conical washer correctly. If you were looking at a cross sectional view of the washer, the widest side faces the friction hub. This is so critical to get it correct. If you don't the friction hub will come loose and in most cases fuse itself to the crankshaft then shear the crank's PTO shaft.
Patrick Hubbell
Jean Stafford
PostPosted: Fri Nov 16, 2012 10:36 am    Post subject: Reply with quote
My 09 Leopard doesn't have a key-way in the "Clutch" hub. Friction material bolts to the starter ring with three 6 mm hex head bolts. Starter gear does not have a key-way.
Clean off the taper, both, and use red loc-tite, or 648. ROTAK is the same way.
There are some Leopard belt drive drums available for road racing.
USE A TORQUE WRENCH. You can flatten out the small washer and bind up the drum. NO IMPACT!
Jean Stafford
Stafford's Racing
Dayton, Ohio
ROTAX Repair station,
jean@sgandt.com
Started Karting in 1959
"Some people are like 'Slinkies', worthless, but they bring a smile to your faqce when you push them downstairs."
patrick slattery
PostPosted: Sat Nov 17, 2012 11:20 am    Post subject: Reply with quote
So you guys are recommending using a piston stop. I was always told that was a no no, has that thought changed or was I mis informed?
Jim Derrig
PostPosted: Mon Nov 19, 2012 7:49 am    Post subject: Reply with quote
use a piston stop to tighten the outer nut that holds the drum. it doesn't need much torque. use a clutch holder tool to tighten the big nut that hold the clutch itself.
JIM SILVERHEELS
PostPosted: Tue Nov 20, 2012 4:07 pm    Post subject: Jean Reply with quote
Jean, are you saying to put Locktite on the tapered mating surfaces or just the locknut please?
Oscar Biondi
PostPosted: Tue Nov 20, 2012 4:25 pm    Post subject: Reply with quote
Jim, loctite is not really necessary. In any case it would only be used for the nut. You can lap the friction hub and the shaft tapered mating surfaces with lapping compound for a perfect fit. Definitely use a torque wrench.
DB time: 0.580415 (65.69%), total time:0.883565, queries:38
