Ocala Gran Prix - LB
Top Kart USA - SS
SCCA Enterprises - FB
RLV R4 Pipe - why so bad???
Troy V Smith
PostPosted: Mon Oct 15, 2012 11:54 am    Post subject: Reply with quote
I am now on the second RLV R4H pipe this year. The first lasted me most of the year, the newest of the two (ordered to replace the first cracked one) has lasted me no more than two track days! This is ridiculous. Both of my pipes have cracked in the same place, just forward of the spring clip hoops - are others in the same place or is this an issue with just the way I mount the pipe? You'd think the pipe to be a little more reliable...either way. With as much as we pay for them, they shouldn't be disposable, or in need of repair after a few days!
It's great that they repair them, but for cryin out loud, I'd think a dependable pipe would be included in the $325 sale price!
TVS Motorsports -
"We may not be the fastest on the track...
but we're having the most FUN!"
joseph hollinger
PostPosted: Mon Oct 15, 2012 1:51 pm    Post subject: Reply with quote
Whats the grey stuff under the hose clamps?
Sam Zavaglia
PostPosted: Mon Oct 15, 2012 4:29 pm    Post subject: Reply with quote
Troy,
Not saying it is but wondering if the heat generated by the installation/weld of your EGT nut is a factor in weakening that area?
Joe,
They grey stuff looks right up your alley, I could imagine your kart with that stuff all over protecting everything. At first I thought it was your kart but then I couldn't see an ST GFS.
www.samzavaglia.com
PostPosted: Mon Oct 15, 2012 4:49 pm    Post subject: Reply with quote
Sam Zavaglia wrote:
Troy,
Sam, I would say the same thing, looks like the crack propagated near that EGT Bung. You can actually see the crack right in the middle of the heat band from the weld. There's a reason why the spring hooks are brazed, brazing puts much less heat into it....
Also, of the cracked pipes I've seen, they don't crack at the head pipe section, it's either that next curved section or the first cone section....
You could probably tig weld that crack up, then normalize that area to get the temper out....
We complain about a $325 pipe, myself included, try and build one...
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Howie Idelson
PostPosted: Mon Oct 15, 2012 5:23 pm    Post subject: Reply with quote
Why not install the EGT bung at the factory? If you wanna use it drill it out, if not leave it. It would be in the same location for al and data could be shared if you wanted. Jus sayin...Also, how bout a heat shield?
Howie Idelson
howieidelson@mac.com
www.coroflot.com/howieidelson
Troy V Smith
PostPosted: Mon Oct 15, 2012 5:40 pm    Post subject: Reply with quote
Yea Guys - you're right on target with the heat/weld causing the issue. I just got an email back from Rod at RLV and he has said that was most likely the cause as well. So, let me ask - where are most folks installing the bung for EGT - as obviously this spot (or welding) hasn't worked out well for me? Does brazing the bung work out pretty well?
I completely agree with Howie - install the bung at the factory if it is going to cause issues like this!
Tha material around the pipe is .02 gasket material. One, I use it to prevent scaring up of the pipe due to hose clamps, and secondly, I thought it would add just a small bit of cushion without too much flex. Doesn't hold in heat like a wrap would either.
TVS Motorsports -
PostPosted: Mon Oct 15, 2012 6:53 pm    Post subject: Reply with quote
Really pushing for a $500 pipe!!!!
I tig weld all of mine, with a 1/16" Tungsten, back purged, run it really quick!!!! Never had one crack there.....
CR
Troy V Smith
PostPosted: Mon Oct 15, 2012 7:15 pm    Post subject: Reply with quote
A $500 pipe would have done me way better than the now 3 @ $325. Rolling Eyes
So can anyone fix this one, or is it to the scrap heap?
TVS Motorsports -
Howie Idelson
PostPosted: Mon Oct 15, 2012 7:32 pm    Post subject: Reply with quote
I've done work for two of the largest pipe manufacturers. I have an understanding of the cost of building stamped and welded pipes. $325 even $225 is excessive.
Howie Idelson
Sam Zavaglia
PostPosted: Mon Oct 15, 2012 8:13 pm    Post subject: Reply with quote
I've bronzed a M5 nut with great success for EGT into R4H, still no problems. Same stuff as used by RLV on the exhaust spring lugs.
Some people may like their EGT bungs in a different position or size to what the factory may do, so best left not done. Wink
I would have your pipe fixed with an oxy and some wire, what's it called Chris "fusion welding", real easy repair, the same way sectioned pipes are welded together.
www.samzavaglia.com
Erik Maxfield
PostPosted: Mon Oct 15, 2012 8:40 pm    Post subject: Reply with quote
I braze my EGT bungs on and do not have issues with cracking. Not that it matters much but I road race, Routinely see over 1350 EGT (with 1000 minimum) on long straights and do not have much of an issue with cracking.
Just a data point.
(That EGT is with 110 octane FYI... do not get that high with 100 octane) The EGT bung is in roughly the same area.
Erik
The early bird gets the worm.....
The second mouse gets the cheese....
Stock CR125.
Chassis-FrankenKART
Intrepid/ITAL combination
Jimmy McNeil
PostPosted: Mon Oct 15, 2012 9:18 pm    Post subject: Reply with quote
I had a icc pipe crack near the egt bung I welded, I had put it under water to cool it off. A local Machine told me that was a no no. Let it cool off gradualy, no water. Dont know if thats B.S. Just repeating what I was told.
Like I said earlier, I think they had a bad batch, Ive been running the same pipe most of the year with no problems and the new pipe seems to be working well.
Alex King
PostPosted: Mon Oct 15, 2012 9:51 pm    Post subject: Reply with quote
If they indeed had a bad batch and they acknowledged it - that would be great for consumer confidence, but wouldn't that also prompt for a factory recall (on the bad batch)?
PostPosted: Tue Oct 16, 2012 3:49 am    Post subject: Reply with quote
Maybe you should have your own pipe made legal and save everybody $$$$$?
PostPosted: Tue Oct 16, 2012 3:53 am    Post subject: Reply with quote
You have a couple of choices, bring it to a welder to have repaired, if it cracks again, send it to RLV, and have them replace the section.
Or just send it to RLV and have them replace the section....
CR
Page 3 of 4
DB time: 0.078521 (40.78%), total time:0.192553, queries:38
