Italian Motors - LB
Streeter - SS
Leading Edge Motorsports
Summit Point ICC gearing
Chris Tyrrel
PostPosted: Sat Oct 06, 2012 6:16 pm    Post subject: Summit Point ICC gearing Reply with quote
I have a friend that is planning on heading to Summit Point for the last WKC race of the year...does anyone know the gearing for a TM ICC at Summit?
STOCK HONDA SODI KART
On Track Karting, Ultimate Indoor Racing
2 locations...Wallingford CT, and Brookfield CT
GOT DRIVE?
www.ontrackkarting.com
Chris Tyrrel
PostPosted: Mon Oct 08, 2012 11:44 am    Post subject: Reply with quote
anybody??? Bueller, Bueller??
GOT DRIVE?
Jim McMahon
PostPosted: Mon Oct 08, 2012 1:49 pm    Post subject: Reply with quote
Well in the complete absence of any other information I guess you could start with 18:21 / 19:22. That's a typical gear to break into triple digits. Hopefully someone will chime in and get you something specific for that track, its got some steep inclines!
Failing that I made some gearcalc sheets too:
http://www.overt.ie/files/racing/technical/motor/gearcalc/
Be sure to verify tire circumference before doing a calculation. The K9 and K9B have the same exact ratios, the K9C is a little different hence has a different sheet.
Chris Hegar
PostPosted: Mon Oct 08, 2012 2:42 pm    Post subject: Reply with quote
Internal ratios may throw those final ratio numbers off you might want to ask a guy like Tom Barth, he seems to have an answer for everything TM.
www.Hegar4.com
Jason Santander
Location: United States, California, Santa Clara, Earth
PostPosted: Mon Oct 08, 2012 9:32 pm    Post subject: Reply with quote
strongly recommend 19-22
View user's profile Send private message Visit poster's website Yahoo Messenger
Jim McMahon
PostPosted: Tue Oct 09, 2012 8:52 am    Post subject: Reply with quote
Did you look at the sheets Chris? The sheets are based on the homologated gear ratios for each motor package.. Primary and all 6 gears accounted for. Of course if the motor is bent and has non homologated ratios then all bets are off but otherwise they should be accurate.
Chris Hegar
PostPosted: Tue Oct 09, 2012 8:55 am    Post subject: Reply with quote
You know I don't pay attention. Rolling Eyes
www.Hegar4.com
Chuck Weaver
PostPosted: Sun Oct 28, 2012 2:05 pm    Post subject: Reply with quote
wish those included my SGM ratios
I race for fun,,, If I win, that's a bonus!
Chuck Weaver
Jim McMahon
PostPosted: Thu Nov 01, 2012 6:59 am    Post subject: Reply with quote
What model SGM do you have, if I can find a homologation sheet for it I can make a gearcalc for you.
Jim McMahon
PostPosted: Thu Nov 01, 2012 7:43 am    Post subject: Reply with quote
Well I found a sheet from SGM that lists the ratios as parts for a number of their motors. Ive added a spreadsheet called SGM-All.
Just select the tab (at the bottom) for the model motor you have have.
DB time: 0.072659000000001 (39.19%), total time:0.185389, queries:38
