MIR Racewear - LB
MRP - SS
DRT Racing - FB
Motor life expectancy...
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Fri Sep 28, 2012 3:59 pm    Post subject: Reply with quote
Randy Pierson wrote:
When stock moto first started they were making 33hp with the R2. Now the needle is pushing 40hp almost. The costs have followed the power increase
I'm, out there???
It's way cheaper than any serious ICC setup... You want to compare them to a stock ICC, that's one thing, compare Stock Moto to a motor in that KZ1 video... You have to compare top of the food chain, to top of the food chain...
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Ken Schilling
PostPosted: Fri Sep 28, 2012 4:04 pm    Post subject: Reply with quote
Cesar Rull wrote:
Thank you for the responses.
(Why do drivers often times put their arms out of the kart as if trying to touch the sides of the kart? I have seen that very often. Does it mean anything?)
Cesar,
If what you are referring to is happening on the starting grid...
It's most likely one of a couple of things:
- The driver is reaching towards both rear tires to slightly roll the kart into the correct position on the grid.
- Same as above except, once positioned correctly on the grid, is slightly moving the kart back & forth to keep the tires from sticking to the pavement. This is very common is Europe where they use very soft tires.
- The driver is simply stretching.
Ken Schilling
SKUSA Data Administrator
Jimmy McNeil
PostPosted: Fri Sep 28, 2012 4:10 pm    Post subject: Reply with quote
Randy, you make some good points. Let me take a stab at these one at a time.
Quote:
Back in the day, you remember those, when stock moto was rather new we all ran the R2 pipe. Those days were great. The pipe limited the hp so no matter what cylinder you had, '97,'99 etc it was all about the same.
No Randy I dont. Ive been racing stock honda now for 4 years and the pipe has been R4 since I started and will continue to be R4 for many many years.
Quote:
then we could run '01 cylinders and heads...
Im going to agree with you here, allowing the 01 stuff into the class was a mistake. It was necessary at the time but has caused some problems since. BTW did you listen to the Lancaster race? My 99 passed the top 01 cylinder in the Nation on the long straight. Ive raced against the 01's for the past couple years and they are pretty darn close on hp.
Quote:
opps but wait then we could run '01 reeds and cages, ohh but there's more. Then we could run any reed, then the PWM or the PWK...gotta have both you know..to test! But wait there is more...how about the new fuel system from Swedetech...but wait now SRS has a fuel system...oh no...now we have to run a timing plate ...there goes all my testing....
Disallowing the 01 reed cage, big deal. It cost $89 bucks for the stock 99 cage. Most people were already running the 99 so it didnt make much difference. Do you want me to get into the icc reed cages and intakes. I spent close to $2000 on intakes, reed cages and a clutch baskets getting an icc ready for one race.
Stock honda has two carbs to choose from, both Keihen, one has better top end, one has better low end.
Icc has two carbs to choose from, both dellorto, one has better top end, one has better bottom end.
The Dellorto is $295
The Keihen is $215
Advantage stock honda
Did you see the fuel system I was running at the Nats on my icc? Its bad ass and you cant get it.
You can call SRS or swedetech and they will sell you a fuel system for a stock honda.
Again, big deal. The timing plate cost $15 and is a good thing. It helps keep everyone on a level playing feild.
I think its hilarious that you are pointing out the changes to stock honda since its inception. It was done because thats what the customer wanted, people wanted the stock intake, people wanted the timing plate etc etc. It didnt make the engines faster, it made them more reliable and saved the racer money, while at the same time leveling the playing field.
A new racer can go to an engine builder and get a stock honda that can win at a national event year after year. Only a dozen or so guys in the US can get an icc that is capable of winning a SuperNats and thats if they have $$$ to pay the price.
I started karting on icc's. I had two and my teammates had at least two each. After a year we found out that the ones we had wouldnt perform on a sprint track. We bought different ones only to find out that a new model came out a few months later that was superior so a couple of us bought those. then we found out they were only good at tight high grip tracks, if we wanted to win on the longer low grip tracks it would take a $8000 Maxter to get it done.
Between that and the $1000 to $1500 rebuilds every three months, the new/different intakes, clutch baskets, reed cages, engine mounts that changed the angle of the engine for different tracks, anodized aluminum clutch plates that would eat up the friction discs in two to three starts, carbon fiber silencers, different weighted gears, and holly crap if you blew one up you better be ready to take a second out on the house, etc etc etc etc etc etc etc etc etc etc etc etc etc etc....
No wonder the class died out and only a couple tracks in the country still run them.
I run my stock honda all year on one rebuild and we are at the track 3 weekends a month, we drive the crap out of them and they keep on going.
As far as the icc being faster, I did a lot of testing at Buttonwillow for the Nats. Its a tight, banked high grip track. I would be willing to bet theirs not an icc in the US that can go .2 faster than my stock honda.
Quote:
and to keep up with the development from when I had my first stock moto 7 years ago, all the "upgrades" cost more than the motor.
Thats just funny, you have that backwards. Ive lived both sides, the stock honda is a cinch compared to the icc.
Now having said all that, if the table starts to turn and all the fast guys get back on icc's, ill be one of the first in line to get one. Ill just have do dig a little deeper into my pocket. Will I be happy about it, No. But ill just focus on the bright side, clean looking package and a little faster Rolling Eyes
Cesar, go to your local track and see whats running. If they have a good icc turn out and thats what you want, go for it. You wont be disappointed with the performance, they are hella fun to drive. But it would suck to spend all the $$$ on a icc to find that everyone is on honda's.
Randy Pierson
PostPosted: Fri Sep 28, 2012 4:49 pm    Post subject: Reply with quote
Jimmy,
Having owned and run both I can tell you that one is not cheaper than the other. Have the experience in that I have 7 karts and motors running every weekend not one at a time.
But..we all go thru this 2 or 3 times a year, fanning the flames on the internet. Stupid but we all seem to chime in..must be some kind of sickness...
I'll see you soon, Goebel and I can watch you run while we are holding our Corona's.
Your fan from the Great White North.....Randy
Jimmy McNeil
PostPosted: Fri Sep 28, 2012 4:58 pm    Post subject: Reply with quote
Your rite, I laugh when I see these debates but by the end of it I usually end up chiming in lol.
You'll be happy to hear we are upgrading the size of our ice chest for this years Nats. We brought a ton of adult refreshments last year, I think they lasted two days lol. I think Gobel did the most damage Evil or Very Mad that guys an animal.
Cesar Rull
PostPosted: Fri Sep 28, 2012 8:55 pm    Post subject: Reply with quote
yep. I agree, There is a race this weekend I will try my best to make it and really see what is out there.
Jeff DeMello
PostPosted: Fri Sep 28, 2012 11:20 pm    Post subject: Reply with quote
Come on Jimmy you had him watching over all the coolers in the tent Shocked
That's like putting the Fox in the hen house to keep them out of danger.. Laughing
Jeff DeMello
Emmick F125 Pavesi
Marty Lemons
PostPosted: Mon Oct 01, 2012 7:47 am    Post subject: Reply with quote
From Kartweb.com article explaining the CR125:
How long will Honda supply the parts?
Honda has one of the best Supply Chains in all of industry in fact they are considered by many including GM, Ford and Mercedes Benz to be a model to follow. Most of their motorcycle and ATV parts are available for products that are 15 years old and more. Obviously if a part has some demand they will sell them. There have been over 20,000 1998 & 99 CR125 motorcycles sold in the US and most are still running. There have been over 2000 CR125 Kit motors sold, and they are currently selling 400 a year, several times more then all the ICC's combined. CR125 parts will be available for at least another 10 years.
Does a culture based on seperation and competition, of scientific sophistication and mideval religion, offer happiness even as it ravishes the Earth that sustains it?
visit: www.stereointegrity.com
www.Obsidiancaraudio.com
Cesar Rull
PostPosted: Mon Oct 01, 2012 2:45 pm    Post subject: Reply with quote
what makes all this really difficult if the fact that the honda motors NEED to be 99 and have a specific cylinder and carb too to be legal, whereas the ICC motors are all spec motors arent they?
I am not going to be racing the state series anytime soon, but I would like to have that option in the future. I understand there is all kinds of rules for classes and I would have to buy a honda motor only to find out that I cannot run it in an event. Therefore I am looking at ICC.
But I am getting confused now. You guys are telling me that the ICC motors are not being made?! I know the hondas are not being made but there are tons of replacement parts for them. Is that the case for the ICC?
joseph hollinger
PostPosted: Mon Oct 01, 2012 2:49 pm    Post subject: Reply with quote
Cesar:
Keep your eye on the ball here: the only thing that counts is what they run at the track(s) where you will be racing. Out here in the west, there is basically no such thing as an ICC. Same is true for the national series. But there are some places where ICC is king. Pick the right one for where you race.
Honda still makes the 99 CR125 in kit form. That's what the motor builders buy and use to make the motors they sell. KZ's (ICC) are still manufactured overseas. There just isn't that much demand for them over here.
Cesar Rull
PostPosted: Mon Oct 01, 2012 2:53 pm    Post subject: Reply with quote
^ One thing i realized I cannot find anywhere that sells ICC parts online for the topend refresh for instance like there is for the hondas.
Tim Salvino
PostPosted: Mon Oct 01, 2012 2:58 pm    Post subject: Reply with quote
You dont need to go online to find Honda parts Wink
Go to your nearest Honda motorcycle dealer, and if they dont have the part on a shelf, they can usually have it in a day or two. ANY part. From a case half to a cylinder stud to a transmission bearing.
There are a few places that have ICC parts online, but they can be hard to find. Tom Barth at Green Flag Karting can get TM parts, and i think some others.
Go look up the price of a brand new OEM Honda Crank and connecting rod assembly.
Now look up one for an ICC.
Are you still thinking about buying an ICC?
Cesar Rull
PostPosted: Mon Oct 01, 2012 3:00 pm    Post subject: Reply with quote
I went to homestead to watch yesterday. A bunch of the TAG stuff.. did not seem appealing to me. So when I inquired about the shifters I was told they were mostly Hondas and a few ICC's. Mostly hondas.
This communicated to me that at the club level these two cars would run together and not problem, everyone has fun. (unfortunately yesterday the shifter race had already taken place saturday).
My question is, in the US - you are telling my that hondas are what is run over on the west side. I guess you have club level > state level > regional and then national is that correct?
Is ICC run at the state level, and do they have their own class, or are they run with the Hondas?
And I know some smart a__ is going to tell me to worry about learning how to drive first, but this motor deal is an important investment. My question is, outside club level, are ICCs not run in the US?
joseph hollinger
I just looked at the ICC section over at fastech racing. Top end parts are pretty much limited to gaskets and a ball hone.
joseph hollinger
PostPosted: Mon Oct 01, 2012 3:04 pm    Post subject: Reply with quote
No. You have local events, some local series and national events.
SKUSA runs some regional series and they do not have a class for ICC.
Page 5 of 7
DB time: 0.070627000000002 (31.36%), total time:0.225245, queries:38
