Alex Ventura
Joined: 15 Apr 2012 Posts: 43 Location: United States, California, Anaheim
Posted: Fri Sep 21, 2012 10:02 pm Post subject: GoPro on Leopard Radiator |
| So I have a GoPro and I mounted it on the rad, and when I just had the engine running the vibrations made the video awful. I have the standard Leopard radiator and notice that I am able to move it quite easily. Should I try to tighten the rad mounts or do you guys have any other effective methods of stopping vibrations? |
Kerry Matthews
Joined: 01 Oct 2008 Posts: 773 Location: United States, California, Sacramento
Posted: Sat Sep 22, 2012 12:55 am Post subject: |
Mounting the camera on the radiator will result in vibration. Bad vibration. Had it on my TaG kart & my shifter. Haven't found anyplace on the rear part of the frame where I can mount a camera that doesn't have the vibration. _________________ Play now, work later! |
Joined: 03 Oct 2004 Posts: 1413 Location: United States, Wisconsin, Sun Prairie
Posted: Sat Sep 22, 2012 8:02 am Post subject: |
Never had an issue with vibration when I mounted it on the radiator. Just using the standard adhesive pad.
A few organizations require specific mounting locations now, like the front fairing, as seen in Europe. Haven't had any issues with vibration from that either. _________________ T.J. Koyen
www.oktanevisual.com
Exprit/Leopard |
marc-andre hubert
Posted: Sat Sep 22, 2012 8:37 am Post subject: |
| just installed mine on the side pod, will try in a few weeks, these things vibrate regardless.. |
Alex Ventura
Posted: Sat Sep 22, 2012 5:03 pm Post subject: |
| I guess I am going to try and tighten the rad up a bit, or find a different mounting spot. |
gregg boyce
Joined: 27 Jul 2004 Posts: 1143 Location: United States, Tennessee, nashville
Posted: Sat Sep 22, 2012 8:26 pm Post subject: |
Low on the driver fairing works well, but you obviously won't get a view of your steering. Mount a few inches above the lower mount point.
GB _________________ My imaginary friend says your crazy. |
Matt Koerner
Posted: Sun Sep 23, 2012 11:34 pm Post subject: |
Try using the second highest setting. Its better for the vibration. _________________ Racing is life. Everything else is just waiting. |
Juan D Gomez
Posted: Mon Sep 24, 2012 5:45 am Post subject: |
Zip-tie the Rad to one of the seat struts with a little bit of tension helps a lot. Used the 720p 60fps
Video without it: (used youtube software to enhance video and reduce vibration. track has really bad bumps in a couple of places but really smooth everywhere else.)
http://www.youtube.com/watch?v=JvUYp4jz27o
Video after Zip-tie: (Really smooth track with bumps on the back straight. No enhancements used on this video)
http://www.youtube.com/watch?v=bC8TpNV0-zg
good luck. _________________ KART/MARRS
Arrow AX-9 CIK/MISI Parilla Leopard
"Of course I don't look busy, I did it right the first time" |
