Sean Kisselbach
Posted: Mon Sep 10, 2012 8:41 pm Post subject: Reglassing a seat--- Updated with Pics |
Anyone ever done this? I have a Tillett seat. I ended up in the rumble strips during a club race over the weekend and really tore away the bottom of the seat. I don't want to spend the money on a brand new seat.
Last edited by Sean Kisselbach on Tue Sep 11, 2012 1:32 pm, edited 1 time in total |
Ted Hamilton
Joined: 26 Jan 2006 Posts: 987 Location: United States, North Carolina, King
Posted: Mon Sep 10, 2012 8:45 pm Post subject: |
Done often, with varying levels of success. You can buy patch kits from some of the auto parts stores and Wally world, etc., or you can order online. If you can find a hobby shop that has bidirectional cloth instead of random unwoven, that's wht I'd use... I'd also use epoxy instead of resin, but to each their own.... Make sure you make the patch quite a bit larger than the area you wore through, and I'd rough up the surrounding area with sandpaper and then clean it all with alcohol and tack cloth prior to fixing... _________________ Owner, www.hamiltonhelmets.com // UAS Racer #76 // Karting for karting's sake...keep it fun! |
Oscar Aguilera
Posted: Mon Sep 10, 2012 9:11 pm Post subject: |
depending on how cheap you want to be....we used to put a number plate in the bottom of the seat...some would rivot it...i would duct tape it.
that was back in the day  |
Chris Hurst
Joined: 27 Jul 2007 Posts: 569 Location: United States, California,
Posted: Mon Sep 10, 2012 9:11 pm Post subject: Re: Reglassing a seat |
| Sean Kisselbach wrote: | | Anyone ever done this? I have a Tillett seat. I ended up in the rumble strips during a club race over the weekend and really tore away the bottom of the seat. I don't want to spend the money on a brand new seat. |
While I was back east some how my seat cracked and my neighbor repaired it with a fiberglass patch kit from pep boys or something. Worked very well and I haven't had any problems with it since. It was super cheap I think maybe $20 or $30 dollars.
As for the sanding part, you're on your own there. I was itching for 2-3 days because the fiber gets everywhere. Good luck! |
Sean Kisselbach
Posted: Mon Sep 10, 2012 9:23 pm Post subject: |
Ok this is isn't unheard of. Thank you for the help. I will sand it but im going to wear a long sleeve shirt and gloves. As for the number plate, that sounds like a great quick fix but im sure my track wouldn't allow that to pass tech. I don't have to be too cheap but don't want to spend hundreds on a new seat. I might try to find someone local who has done this before. I know we drive hard and get things dirty but i like to have my stuff looking good. A clean kart is a happy kart, A happy kart is a fast kart.  |
Tim Doll
Joined: 18 Jul 2001 Posts: 2643 Location: United States, Washington,
Posted: Tue Sep 11, 2012 7:55 am Post subject: |
A couple notes about working with fiberglass resin.
First, it stinks - really, really stinks. Garage (with the door to the house closed) is OK, outside if the weather permits is even better (this part is really important if you're married ).
Second, it tends to get everywhere and it's hard to clean up (use acetone) so use some sort of drop cloth. Very skin unfriendly and the acetone to clean it off isn't much better - use gloves.
Third - cure time is very temperature sensitive. Ideally you want the temp cool when you're working it (to slow the cure), then warm to set up.
Everett, Washington
paul rees
Posted: Tue Sep 11, 2012 10:42 am Post subject: Seat fix |
| Surf Board Shops carry a product call Solar Patch . When exposed to sun light it goes off and hardens . Could be used in a quick fix app. |
Chris Livengood
Joined: 24 Jul 2001 Posts: 2432 Location: United States, Pennsylvania, Da Burgh
Posted: Tue Sep 11, 2012 11:17 am Post subject: |
Clean the surfaces thoroughly with a DA type or similar sander (nothing too aggressive). Remove all loose edges and cracks. Cut fiberglass cloth (mat is the unwoven material) to fit the shape of the bottom of the seat (a good utility knife and a piece of ply-wood works great). You may want to to do two layers. Mix up resin and hardener. The cheap stuff is alway polyester resin. Epoxy resins are more expensive, but lighter for the same strength. Follow directions for mixing instructions. Rubber gloves are great, also those super cheap Harbor Freight metal handled paint brushes are great for stirring and spreading of the resin. Apply a coating of resin on to seat. Lay cloth in resin, then use additional resin to fully impregnate the the cloth. Repeat these steps for second layer if desired.
Take your time and get all materials and items full prepared before mixing resin, otherwise your results will vary. Proper ventilation for all activities is a must.
Pro-tip, apply the glass to the inside of the seat. This will raise the bottom of your seat incrementally, as you will probably have to repair it once or twice more, until it no longer wears out every weekend. _________________ http://www.Chrislivengood.net
http://www.Work-Racing.com
http://www.OurZeal.com
http://www.Karting101.com
"Auto racing, helping white guys get laid since 1887!!!" |
Joined: 19 Jul 2002 Posts: 4300 Location: United States, South Jerrrsey,
Posted: Tue Sep 11, 2012 12:52 pm Post subject: |
How bad is the seat? Is it just scraped up, has it broken through in places, is there a big rip across it or has the whole bottom broke off for the most part?
Some repairs are easy to do, some repairs require scarf joints, multiple layers, proper strand orientation ect. Even then you're gluing something onto the lay up, it's not part of the lay up anymore. If you hit a rock it could penatrate or the bottom breaks out at speed you could be in a situation.
Yamaha KT100 Service Center
40 years karting experience |
Sean Kisselbach
Posted: Tue Sep 11, 2012 1:14 pm Post subject: |
| Im going to give this a shot in a few days when i have the time to get out in the garage. The seat isn't cracked or broken through at any point but is very thin on the bottom. I went off track for a split second and basically grinded the rumble strips. Within 5 seconds i thought my backside was on fire and i assumed i broke all the way through. i continued to race on and it felt ok (i was in the middle of a heat race for a club event). The damage took the bottom of the seat down to about 1 layer of fiberglass and to a chunk of my brake rotor. I duct taped it for what it was worth and finished my race day without any further problems. I will post a few pictures of the damage later on today. |
Sean Kisselbach
Posted: Tue Sep 11, 2012 1:31 pm Post subject: |
I just posted the pictures now to make this faster. Im not worried about the brake rotor but i thought i would post a pic anyway. This all happened at once. |
Brian Mead
Joined: 18 Mar 2007 Posts: 787 Location: United States, Tennessee, Franklin
Posted: Tue Sep 11, 2012 4:53 pm Post subject: |
| Run that bad boy as is. As Oscar said, push comes to shove duct tape a number panel on the bottom and sit on it. |
Sean Kisselbach
Posted: Tue Sep 11, 2012 5:00 pm Post subject: |
| Brian Mead wrote: | | Run that bad boy as is. As Oscar said, push comes to shove duct tape a number panel on the bottom and sit on it. |
Thank you for your opinion but as i told Oscar my track would not let me run if i did something like that. I also don't like to have "rigged" stuff. Correctly putting things together and repairing things correctly is what i like to do. I have put alot of time into making my kart ship shape. |
Mike Goebel
Posted: Tue Sep 11, 2012 5:29 pm Post subject: |
| Sean Kisselbach wrote: | | I have put alot of time into making my kart ship shape. |
What about the chipped Rotor???
Dude just glass it from the inside with mat and epoxy resin. Then remove the duct tape and glue the bottom with the same epoxy resin.
mfg Technology Centre
Sean Kisselbach
Posted: Tue Sep 11, 2012 5:32 pm Post subject: |
[quote="Mike Goebel"] | Sean Kisselbach wrote: | | I have put alot of time into making my kart ship shape. |
Mike G.[/quote0]
I just did that on Saturday. New one on order from comet.  |
