SKUSA (non-flash) - LB
Leading Edge Motorsports
Why is Karting so expensive ?? Hmmm lets see!
Michael Boone
PostPosted: Fri Aug 31, 2012 9:02 am    Post subject: Why is Karting so expensive ?? Hmmm lets see! Reply with quote
How much dose in cost to Homologue all that stuff on a kart??? lets find out! Thanks KartMag!
Ok lets play nice children don't make Mr Howden send you to a corner!!
Viva la Karting!!
MB
If you can't keep up don't worry I'll be coming around again !
KZ 125 Masters
FFSA National race Director
http://www.ask-ancenis.fr/
Spencer Uzri
PostPosted: Fri Aug 31, 2012 10:16 am    Post subject: Reply with quote
It seems to be human nature to inevitably complicate even the simplest of things - or anything, really.
Ryon Beachner
Advertiser
Advertiser
PostPosted: Fri Aug 31, 2012 12:07 pm    Post subject: Reply with quote
In all fairness the article lists each individual piece of homologated bodywork, then lists the price to homologate the entire set. So, the individual prices can be thrown out. This leaves us with;
Chassis: 6000
Brakes: 5610
Engine: 13950
Carb: 3010
Airbox: 3010
Fuel Tank: 1550
Bodywork: 12040
Suit: 3010
Total: EUR 48,180
This is assuming a single manufacturer is making all of the above, and submitting it for homologation. Which is not the case, however we'll keep it all in one big number to be on the expensive side.
Much like the cost of molds, these fees are all amortized over the production life of the part, and as the CIK homologates each of these things ever 3 years, we will assume that none of these are granted a homologation extension at the end of that three years, again to keep that number as bad as possible.
We will also assume that production is only going to produce enough for one complete kart, and no extras to try and keep that cost up as high as possible, as well as ignoring the fact that multiple brands use the same set of bodywork, same engine, carburettor, etc and do not have to pay for homologation up front.
So, with the production numbers I've heard of what OTK, and CRG produce a year averaging somewhere around 4000 karts a year we then multiply that by the amount of years these products will be in production, and divide that by the homologaion cost to find the cost that is actually passed on to the consumer in each purchase.
4000 x 3 = 12,000
48180 / 12,000 = 4.015
4.015 Euro = 5.0312 USD
So we can reasonably assume that less than $5 of the cost of a complete kart goes to the CIK when built for a CIK class. Even less than that goes to the CIK when the kart is built for a class that does not use a homologated carb, airbox or engine.
I don't think this is why karting is so expensive...
2Wild Karting
www.2wildkarting.com
Shop: (949) 206-9906
Byron Rothenhoefer
PostPosted: Sat Sep 01, 2012 6:17 am    Post subject: Reply with quote
For example a new 2012 cr450r with fuel injection is about 8400$. An all new stock Honda shifter kart would be about 11k. Makes you wonder.
Bear #13
DR Kart
Brian Fisher Racing Engines
Andy Seesemann
Expert
Expert
PostPosted: Sat Sep 01, 2012 10:24 am    Post subject: Reply with quote
Wonder about what?
How much Honda pays the CIK to homologate all those parts that come in the CR125 kit?
Wink
A
Andy Seesemann
FULL THROTTLE KARTING
Orange County, CA.
www.fullthrottlekarting.com
Rotax Challenge of the Americas
www.rotaxchallenge.com
WKA District 10 Trustee
www.worldkarting.com
Really Good Guy.
Tom Barth
PostPosted: Fri Sep 07, 2012 4:09 pm    Post subject: Reply with quote
Karting is not expensive....Formula 1 is expensive.
Tom Barth
http://www.greenflagkarting.com/
Power is good...more power is better... too much power is just right!
PostPosted: Sat Sep 08, 2012 6:14 am    Post subject: Reply with quote
Unfortunately karting will remain expensive as long as it's a small marketplace. But, if you really analyze the costs for a season of racing you'll find far more cost in expendables and transportation than base equipment. And, if you're not racing at the top level you can amortize your equipment cost over several years, or buy used equipment at half the price of new.
I actually think it's karters that make karting expensive though. US based clubs don't need to require CIK homologated equipment, and if racers were willing to run lower powered karts with hard tires the cost per event could be quite low. As it stands now, other forms of racing ie. mini sprints or spec SCCA classes are pretty competitive price wise with karting.
But, costs continue to rise because racers are willing to pay extra for an advantage not related to their actual effort in preparation or driving. I wish it was as simple as eliminating the CIK from US racing but if you look at the number of prepped, cut tires in the average dirt oval racers trailer you'll quickly realize the problem isn't just imported. Yes, they do use the same tires all season but they use a lot of them and the prep isn't cheap either.
The big issue is that karting needs to be reasonable at the entry level for new families to get involved. This can and is being done by local clubs that offer classes where folks can get started with older equipment and low powered engines. As long as these classes don't become just another place for the more experienced racers to pad their trophy rooms we might have a chance of keeping drivers long enough for them to get hooked.
JMHO,
Heartbeat Power, LLC.
Jon Romenesko
PostPosted: Sat Sep 08, 2012 11:57 am    Post subject: Reply with quote
JMHO,
YES! I've been preaching for using hard tires at the club level for years. I don't see a reason to use sticky tires if you're just trying to have fun at the club level. Sure, lots of grip is fun, but if you're not racing at the national level, I fail to see the point. Don't argue that you race at the club level to prepare for the national level, so you need to run the same tires....if you're truly serious about the national level you're going to test on those tires anyways. A $250 set of tires that's only effectively fast for one event is a good way to price out shoestring racers from competing in a full club season, IMO.
GP10/CR125
http://theslipangle.com/
"When you're racing, it's life. Anything that happens before or after...it's just waiting"
--Steve McQueen, LeMans
Oscar Aguilera
PostPosted: Sat Sep 08, 2012 7:51 pm    Post subject: Reply with quote
the tires come into the cost part based on what regional or skusa level races do.
most clubs have a few guys that race regionally and then some of them race nationally...and those guys usually have family or are involved them selves in the club. the natural thing to do is use the same tires that the other levels use. those tire manuf offer $$$ to use there tires and the clubs love money.
IMO the club level should run all the classes on hard tires and only the top level class on softer stuff....we would have better drivers in the end.
it never stops to amaze me that so many drivers that want the grip of softer tires.....only to get more worn out in the heat of the day after 3-5 laps and cant hold the wheel anymore.
and then have tires that will need to be replaced about every race to run up front.
as for mini sprints....the car can be bought used for what a used shifter sells for and a new one is a little more than a new all out stock 125...as for racing expenses...
ITS ALMOST NOTHING COMPARED TO KARTING!
front tires will last all season. left rear will go half the season and the right rear will need to be replaced about 3 times in the year. other than you would benifit from 2 other left rear sized tire and wheel for ease of tuning (stagger)....you wont replace those other sizes more than once for the season.
methanol is $3 a gallon...entry fee is $10 and pit pass is $25-$30 per person.
BUT WE RACE FOR MONEY! $300 to win and the pay out goes down to all that make the A main.
its also less physical in the dirt....no high heat of the sun, we race at night...
i love road courses and i love shifters and all karts on the pavement. but there is no argument for me racing a shifter over a mini sprint when the fields are deeper on the dirt in talent and we usually have a full main of 24 cars. with an occasional b main to boot.
BUT i still own my shifter and i will be back at it when our season is over on the dirt.
my heart is in a shifter...but to race at the level i prefer.(which is the most important part of racing for me)...the dirt is where it is at for me.
here we go again....if an american company built a competitive kart that didnt get homologated.....it should be cheaper?
and yeah i agree some dads or drivers make karting more expensive by buying stuff they might not need,,,,but they do the same on the dirt. that will never change. so imo you cant count that as why karting so expensive.
you can check out my racing videos on you tube at hbs racing or face book at hbsracing@yahoo.com.
i can see and know many a kart racers that could switch to the dirt and clean up if they wanted to.
just my opinion,,,nothing can take the karter out of me,,,there is nothing like it.
Stu Hayner
PostPosted: Sat Sep 08, 2012 9:46 pm    Post subject: Karting cost Reply with quote
Oscar Aguilera
I'm very old school, for sure, but I have been trying (most times in vane) to convince clubs and shops that the new karter does NOT have to be buying a $8K 125cc kart as their first experience in the sport. Bring back the 100cc engines, drop the rediculous entree fees, $230 set of tires, $80 for 5 gal fuel and let these new guys learn and have some fun.
Bring back Novice classes, and NO 125cc engines so the new drivers have a chance to learn instead of having to look over their shoulder all the time waiting to get lapped.
I have a garage filled with "only driven once or twice" karts, that the previous owner said "karting just wasn't that much fun for me" or "I needed more room in my garage" or "my wife wanted me to spend more time working in the yard", when in fact, the kart was way too fast or overwhelming to enjoy. I take these "only driven once or twice karts - pull the 125 Rotax, Leopard or PRD off, put on a KT100 or HPV (KPV) and teach the new guy how to drive it and maintain it.
For an idea that I have been told was a thing of the past, we now have 25-30 active drivers and 80 very interested new to karting guys in SoCal that have joined the F100karter.com group. We are spending much less and having more fun than we have for the last 20 years.
JMHO
Remember......it's not always the best arrow...but more importantly the best Indian.
Chris Hurst
PostPosted: Sat Sep 08, 2012 10:48 pm    Post subject: Reply with quote
delete.
Chris Hurst
PostPosted: Sat Sep 08, 2012 10:53 pm    Post subject: Re: Karting cost Reply with quote
Stu Hayner wrote:
Oscar Aguilera
JMHO
Is anyone listening to this guy? I am looking forward to making it out to one of your events sometime soon Stu. Not sure if I can do the 14th because of work / school, but I am definitely going to have to come out and get some time in with you guys. Those HPVs are serious fun and are a great tool to learn on. Some of the costs shown in this article are ridiculous and I would be very interested to see the profit margins on those prices.
3010 euros to homologate a driving suit? Is that per suit or a one time fee the company pays to homologate their product?
Michael Boone
PostPosted: Sun Sep 09, 2012 11:27 am    Post subject: Reply with quote
Chris that's a one time fee for the design of a suit, spoiler etc etc. If you change or redesign it you have to pay again!
MB
KZ 125 Masters
Oscar Aguilera
PostPosted: Sun Sep 09, 2012 7:08 pm    Post subject: Reply with quote
the kt100 died for 2 reasons....it was too much constant rebuilding to run at the front and it was too small to pull the weight of the "big boy" americans in this country.
running a bunch of new guys to teach them how to drive is a great idea! but most people dont realize how physical karting is and to get passed by a mini max means your going slow....and to tire out in a $10,000 kart means you dont belong?
it was awesome in malaysia with the rental karts having a pull start kt100 and a dry clutch.....but they were not covered in heavy @ss plastic bumpers. it was for fun and no one could tweak on the kart....as soon as you let drivers "tune" the costs go up. as soon as the field is so close together on the track because of no competitive advantage...the costs go up.
if you want a hobby go buy an r/c plane....if you want a race car then you must want to race...and that is where the pocket book takes over when the body and ability cant make up the lost ground.
i remember when the kt100 costed an arm and a leg and we all found left over 125 shifter motors which required little to no maintenance and went way faster???
if they leave the rules alone you will find all these stock 125 coming down in price...it is already happening. i will stand behind the fact that i believe.....had we kept the full mod 125s and not switched to icc....the costs to get in would be way down as well. i still believe that the price to compete at the top level and have some of these same guys race at the local level will always drive the costs up by drivers having a perceived need to buy more stuff,,,,and spend more money.
the chassis cost so much because they all cost that much... there is no single chassis maker that has decided to lower the price of there kart in order to corner the market...they know they will only sell so many....and they only have so many dealers...
if an american importer decided to lower the price and order 2x more chassis up front for the year 2013....then maybe the price will start to be a factor. they are not going to lower the price if they are not going to get a better break on the buying price.
just my opinion
Chris Hurst
PostPosted: Sun Sep 09, 2012 7:36 pm    Post subject: Reply with quote
MB
No wonder in 2010 the profit margins in the automotive related industry were 1.8%, among the lowest in any industry in the United States. So if the regulations change you have to design a new suit / chassis / etc and homologate it all again?
Shocked
DB time: 0.134524 (33.69%), total time:0.399286, queries:38
