Bondurant - LB
MRP - SS
KG Plastics - FB
Kart centerline?
Bill Schmidt
PostPosted: Sun Jul 22, 2012 8:49 pm    Post subject: Kart centerline? Reply with quote
What is the best reference to use for the centerline of my kart chassis? I noticed that the rear axle is a little offset to the right and I want to center it.
Bill Schmidt
'88 Red Devil F500 4-link rear (Rotax)
Rob Kozakowski
PostPosted: Mon Jul 23, 2012 8:21 am    Post subject: Reply with quote
Measure from outside bearing hangers to end of axle. Unless you have reason to do otherwise, set to the same distance on both sides.
Roger Miller
Site Admin
PostPosted: Mon Jul 23, 2012 8:44 am    Post subject: Reply with quote
And then the same for setting the rear hubs, use the bearing hangers as the reference, and then measure from there. Even if the axle is a little off, having the hubs properly spaced will take care of things.
Bill Schmidt
PostPosted: Mon Jul 23, 2012 9:17 pm    Post subject: Reply with quote
Thanks a million guys! I appreciate the help.
Bill Schmidt
DB time: 0.202228 (68.58%), total time:0.294896, queries:38
