IKF Region 7 - LB
DRT Racing - FB
pwm carb jetting
Christian Garcia
PostPosted: Wed Jun 20, 2012 2:25 pm    Post subject: pwm carb jetting Reply with quote
What's a good place to start with jetting its a pwm carb bored to a 40 mm pump around setup, 2002 Cr 250 ported, rlv pipe, will be used on Sprint tracks.
Mark Croslyn
PostPosted: Wed Jun 20, 2012 4:19 pm    Post subject: Main jet Reply with quote
Some of the best info I was ever told. "Its easier to change a main jet than a piston". Has echoed in my ears every time I stick a motor. You no doubt have other things that need to be considered when someone gives you a number.
Good luck
Ian Harrison
PostPosted: Wed Jun 20, 2012 5:33 pm    Post subject: Reply with quote
Otherwise . . . . .
DGH needle, clip in P3
55 pilot
205 Main
Airscrew 1.5 to 2 turns out
Oh and see Mark's comment above!!
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
Roger Miller
Site Admin
PostPosted: Wed Jun 20, 2012 6:49 pm    Post subject: Reply with quote
I would suggest a 60 on the pilot, that's just to be safe, and if you are running stock ignition, keep the revs at 10, 10.1 max
Then start looking at your plug color and EGTs and go from there.
Christian Garcia
PostPosted: Fri Jun 22, 2012 8:16 am    Post subject: Reply with quote
Thanks so much again all your input is greatly appreciated.
DB time: 0.062019999999999 (40.62%), total time:0.1527, queries:38
