Mike Edwards
Joined: 07 Apr 2008 Posts: 22 Location: United States, Colorado, Littleton
Posted: Wed Jun 20, 2012 1:46 pm Post subject: Rotax Sr Motor Issue |
This past week-end in Dallas my son Tyler was having problems at the start of each race at the drop of the green flag. The motor would not come up to speed for 3-4 laps and than run better. He explained it to me as if the power valve wasn't opening. We tried several different power valves and carbs with no luck......Any ideas?
Mike Edwards |
John Savage
Joined: 30 Jan 2002 Posts: 1252 Location: United Kingdom (Great Britain), not USA state,
Posted: Wed Jun 20, 2012 3:38 pm Post subject: Re: Rotax Sr Motor Issue |
| Mike Edwards wrote: | This past week-end in Dallas my son Tyler was having problems at the start of each race at the drop of the green flag. The motor would not come up to speed for 3-4 laps and than run better. He explained it to me as if the power valve wasn't opening. We tried several different power valves and carbs with no luck......Any ideas?
Mike Edwards |
Mike, it is often the case that new power valve will stick, you need to make sure that all oil residue is removed after each session.
You may also find this video useful:
http://vimeo.com/36795487 _________________ Dellorto, Mikuni and Keihin Jetting & Kart Set-up Software
www.rotaxjetting.com www.kartsetupsoftware.com |
Carlos Calderon
Joined: 16 May 2006 Posts: 890 Location: United States, California, San Jose
Posted: Wed Jun 20, 2012 4:35 pm Post subject: |
When you install it, make sure that the valve moves move freely by hand. If it doesn't, you may have installed it slightly crooked. Ensure that it's straight.
Also, like John said, make sure there isn't any oil in the bellow (green rubber piece) and that the passage from the engine side into the bellow is clear.
Also, check the "exhaust packing" in the pipe. It may be that the stinger (long metal piece inside) has cracked and blocked the exit path. Or it may be that the packing is interfering. Perhaps swap over for a "known good" pipe if you don't want to change the packing yourself, to confirm that's what it is. _________________ Aluminos |
josh dorn
Joined: 27 Oct 2009 Posts: 42 Location: Australia, Alabama,
Posted: Thu Jun 21, 2012 12:41 am Post subject: pv |
| pv blades from 09 onwards have been made crooked, ei the stud thread is on abit of an angle, and sometimes the actual blade is made bad. in aus ive seen 4 engines all with the same issue you describe - most try find an old blade to use or a better new one. |
Greg Gabriel
Posted: Thu Jun 21, 2012 10:27 am Post subject: |
| ask falcone |
