E J Resnick
Posted: Fri Jun 15, 2012 8:38 am Post subject: Gearing |
| Is there is major difference between running a 12 tooth front sproket versus a 13 tooth sproket if you adjust the rear gear for the correct ratio? |
Matt Clark
Joined: 26 Apr 2005 Posts: 183 Location: United States, Florida, Tampa
Posted: Fri Jun 15, 2012 9:41 am Post subject: |
It's a ratio so as long as you adjust the other part equally it should have no effect.
Chris McGinley
Joined: 28 Nov 2008 Posts: 359 Location: United States, New Jersey, Sewell
Posted: Fri Jun 15, 2012 3:55 pm Post subject: |
This topic will probably stir up some controversy...but, here goes...
I've found the 11 tooth gear to work better on twisty and tight tracks .... the motor seems to spin up a bit better. I'm sure a physics expert can explain the actual effects of the fulcrum, inertia, etc...I won't purport to be that expert However, I don't know that the smaller driver (when you have an option) is best in all situations.
I'd recommend testing each gear at your track and see if you get a different result on the stopwatch - that's the only way to know for sure. _________________ Chris McGinley
Monster Raceworks
Rotax Masters
http://www.njkarting.org
http://www.btbsecurity.com |
Angel ramirez
Joined: 01 May 2007 Posts: 131 Location: Mexico, QUINTANA ROO, CANCUN
Posted: Wed Jun 20, 2012 5:55 am Post subject: |
11 tooth smaller diameter = less lever resistance against the engine = faster acceleration. _________________ Racing for the pure art of racing. |
Don Holmboe
Joined: 26 Aug 2002 Posts: 323 Location: United States, Oregon, Tigard
Posted: Wed Jun 20, 2012 7:01 am Post subject: |
The incease in "leverage" at the driver is offset by the decrease in leverage at the axle. To put in bluntly, someone is smokin too much dope when analyzing this issue. The overall "leverage" is the RATIO. _________________ Don Holmboe
Competition Motors Corp.
cmckart@yahoo.com
http://cmckarts.com
(503) 624 0621 |
Ihor Bilyy
Joined: 13 Jul 2005 Posts: 538 Location: United States, Georgia, Canton
Posted: Wed Jun 20, 2012 10:34 am Post subject: |
| Don Holmboe wrote: | | The incease in "leverage" at the driver is offset by the decrease in leverage at the axle. To put in bluntly, someone is smokin too much dope when analyzing this issue. The overall "leverage" is the RATIO. |
EKN should add Like button I would click here |
Scott Grenier
Posted: Wed Jun 20, 2012 11:10 am Post subject: |
| I was thinking the same thing Ihor! |
John Savage
Joined: 30 Jan 2002 Posts: 1266 Location: United Kingdom (Great Britain), not USA state,
Posted: Wed Jun 20, 2012 3:26 pm Post subject: |
| Scott Grenier wrote: | | I was thinking the same thing Ihor! |
All I want to know is where is Don getting his dope? _________________ Dellorto, Mikuni and Keihin Jetting & Kart Set-up Software
www.rotaxjetting.com www.kartsetupsoftware.com |
al nunley
Posted: Thu Jun 21, 2012 6:45 am Post subject: Re: Gearing |
| E J Resnick wrote: | | Is there is major difference between running a 12 tooth front sproket versus a 13 tooth sproket if you adjust the rear gear for the correct ratio? |
This has been debated more times then you can count on Bob’s 4cycle forum.
Both view points, pro and con, have been posted many times.
How about testing it for us and report back. Lots of people have said they’ve tested it and both conclusions have been reported. It seems a never ending discussion.
Myself, I think many can’t calculate a gear ratio. _________________ If the data does not support the theory, get a new theory. (Al Nunley)
