Italian Motors - LB
RLV - SS
Leading Edge Motorsports
Help Please with No Spark to Plug but starter turns over
Todd Renaud
PostPosted: Wed Jun 06, 2012 11:50 am    Post subject: Help Please with No Spark to Plug but starter turns over Reply with quote
With my Senior FR125, the starter will turn over when the starter button is engaged but no spark gets to the plug.
Right now, I don't have any extra spare parts to try and swap out so before I go buying/searching for some, any suggestions on what I can test with a test light or voltmeter to at least see where the "spark" gets to before it disappears.
We originally didn't have the harness connected properly as the starter wouldn't even turn over. That's why I feel it COULD be something with our connections and not necessarily a failed part.
Also, what triggers the coil so that it will fire the plug?
TIA...Todd
Matthew Chin
PostPosted: Wed Jun 06, 2012 12:06 pm    Post subject: Reply with quote
There is a small crank angle sensor (or something similar) on the backside of the engine that has a 2 prong plug that goes to it to determine when to send the spark. It is under the exhaust closer to the drivers seat. Make sure that it is plugged in and is not loose.
Todd Renaud
PostPosted: Wed Jun 06, 2012 12:43 pm    Post subject: Reply with quote
Thanks. Double-checked that and same issue. Still wondering if there is a way to see how far the "spark" will travel = maybe even a wire in the harness is bad?
Curtis Cooksey
Advertiser
Advertiser
PostPosted: Wed Jun 06, 2012 1:49 pm    Post subject: become one Reply with quote
Mistake
www.accelerationkarting.com
Todd Renaud
PostPosted: Wed Jun 06, 2012 2:55 pm    Post subject: Re: become one Reply with quote
Curtis Cooksey wrote:
Mistake
Which part?
Matthew Chin
PostPosted: Wed Jun 06, 2012 5:18 pm    Post subject: Reply with quote
is your grounding strap good?
russ jolly
PostPosted: Thu Jun 07, 2012 9:30 pm    Post subject: no spark Reply with quote
Pull your plug leave it in the boot and let it rest on the head. turn it over. if no spark try pulling the boot and reconnecting it, sometimes they get loose. If that doesnt work get a volt meter and test the volts going to the coil,...
Bruce Woodrow
PostPosted: Thu Jun 07, 2012 11:21 pm    Post subject: Reply with quote
Since you know the battery is OK (engine turns), there are only 5 items in the system to check:
1. Ignition switch - you can check this with a test light or voltmeter
2. Crankshaft sensor - never heard of one causing a problem unless physically damaged
3. Ignition coil assembly - only easy way to check is by replacement
4. Main wiring harness - after checking ignition switch, disconnect the coil connector, switch on ignition switch and make sure there is a 12v feed at one of the terminals.
5. Engine/coil grounding - the grounding eyelet on the main harness should be attached to the engine casing (usually using one of the coil mount studs) AND the coil casing and engine casing must be connected by 1, or preferably 2, grounding wires (again using the coil mount studs)
Hope this helps,
Bruce
DB time: 0.122633 (38.94%), total time:0.314966, queries:38
