Pax Rolfe
Posted: Wed Mar 28, 2012 6:49 pm Post subject: Autocross alignment and setup? |
How drastically does a good autocross setup and alignment differ from a track setup. Let's start with Camber and Toe. From what I've seen, nearly zero on both seems to be the recommendation. Does this apply to solo? _________________ Pax
Tulsa, OK |
Alan Sheidler
Posted: Thu Mar 29, 2012 7:20 am Post subject: |
| Zero is a good place to start for camber and toe. For caster, you may have to experiment a bit. Depending on the stiffness of your chassis, especially at the front, you may have to increase the caster angle to get more/quicker bite. That can also vary based on the locations of events. The increased traction on old concrete had us reducing front grip to keep our karts driveable. |
Brad Fish
Posted: Thu Mar 29, 2012 12:57 pm Post subject: |
I was just wondering the same thing as Pax.
Can I get some recommendations for chassis set up resources? I have seen a bunch of books, manuals, and websites, but I can't tell if any of them are good.
Thanks, |
Jason Vehige
Joined: 21 Apr 2006 Posts: 282 Location: United States, Tennessee, Nashville
Posted: Thu Mar 29, 2012 6:27 pm Post subject: |
In general .... I run as little castor as possible , 0 ish toe, remember...you're weight will add some toe in if you align it without you in the kart, pretty narrow up front, if it pushes add castor
Out back I tend to search for as much grip as possible.... Right now I am using a stiff rear setup... As narrow as wide hubs will allow... If it hopps mid corner try a bit wider in back...
Play around and make big changes at first to get a feel for what they do..... Beware of chasing old tires, it will mess You up!!! _________________ Jason Vehige
05 Vanspeed Sirio / SGM sl204 |
Brian Garfield
Joined: 04 Apr 2004 Posts: 667 Location: United States, Maryland, SKCA Racing!
Posted: Thu Mar 29, 2012 6:36 pm Post subject: |
Here's my very simple opinion on this:
Every chassis requires a different setup. Zero EVERYthing. If the kart drives straight, and turns in... you're done...for awhile.
All I ever did with mine was make sure it felt comfortable for me to drive. I can tell you the settings were almost never the same left to right...
In the end, if it's not giving you a problem, just drive it that way. If you're gunning for a National championship, you're gonna need to study up so that YOU completely understand what each change does. At that point, you drive and then you fix it.
Brian |
Bill Schmidt
Joined: 05 Jul 2010 Posts: 241 Location: United States, Kansas, Kansas City
Posted: Thu Mar 29, 2012 9:03 pm Post subject: |
What do you do if you drive an antique like mine and have no castor or camber adjustment? Probably buy a newer kart? _________________ Bill Schmidt
'88 Red Devil F500 4-link rear (Rotax) |
Alan Sheidler
Posted: Fri Mar 30, 2012 12:06 am Post subject: |
| Bill Schmidt wrote: | | What do you do if you drive an antique like mine and have no castor or camber adjustment? Probably buy a newer kart? |
You're in something older than my (96) Renspeed?
Are you sure it was originally a shifter chassis? Plenty of karts made for 2 or 4-cycle setups had no caster/camber adjustments, unless you drilled out the kingpin holes and put in the alignment pills yourself. Of course, they did not have front brakes either, but those could be added. |
Joe Ricard
Joined: 23 Jun 2009 Posts: 868 Location: United States, Mississippi,
Posted: Fri Mar 30, 2012 4:46 am Post subject: |
Bill needs to buy my ICC. Not so new but not so old either.
Things I've had to undo going from parking lots and cones to brandy new sprint track is swap out SKM C hard axle to a soft axle, 140MM long double clamp hubs to 70mm single clamp magnesium hubs. and remove one pair of seat struts.
Bill I got all that stuff still.  _________________ Arrow AX-8/ Rotax Sr. |
Bill Schmidt
Posted: Fri Mar 30, 2012 5:24 am Post subject: |
| Alan Sheidler wrote: | | Bill Schmidt wrote: | | What do you do if you drive an antique like mine and have no castor or camber adjustment? Probably buy a newer kart? |
My kart is an American made Trackmagic circa 1995. It had the butterfly shifter that broke on me at last years Nats. As far as I can tell it was all factory stock _________________ Bill Schmidt
Christian Hubbell
Joined: 01 Feb 2006 Posts: 236 Location: United States, Michigan, Waterford
Posted: Fri Mar 30, 2012 5:56 pm Post subject: |
| I wouldn't worry about getting a new chassis. Set it at zero toe, and just drive the thing. Still plenty to play with, toe, ackerman, rear width, front width, tire pressures, weight balance to name a few. The TM guys were pretty smart and set the caster and camber to what works for that chassis. Those two are really the very last things to tweak for a certain condition and setup. You can be plenty fast with that chassis. |
Bill Schmidt
Posted: Sat Mar 31, 2012 9:04 am Post subject: |
| Christian Hubbell wrote: | | I wouldn't worry about getting a new chassis. Set it at zero toe, and just drive the thing. Still plenty to play with, toe, ackerman, rear width, front width, tire pressures, weight balance to name a few. The TM guys were pretty smart and set the caster and camber to what works for that chassis. Those two are really the very last things to tweak for a certain condition and setup. You can be plenty fast with that chassis. |
Christian,
I know exactly what you are saying, however, I really dont have any akerman to play with. My TM steering arms are about 2.5 inches long, whereas every modern chassis I have seen are about 5 inches long. And mine only has 1 set of holes in them. _________________ Bill Schmidt
Christian Hubbell
Posted: Sat Mar 31, 2012 10:25 am Post subject: |
| How do they mount to the steering rack side? Usually you can move things around there. |
Bill Schmidt
Posted: Sat Mar 31, 2012 8:54 pm Post subject: |
Okay, I brain farted there for a minute. It isnt the length that is a problem of the arm it is the width. The width where the tierod mount hole is about 3/4" wide. I suppose a tab could be welded onto the arm? Or, of course, buy new arms altogether (probably a better idea). _________________ Bill Schmidt
Pax Rolfe
Posted: Wed Apr 04, 2012 7:07 pm Post subject: |
Thanks for the responses. I did zero out the camber and toe while also adding caster. Kart was very neutral, slight push in one fast sweeper, not at all twitchy but turned in great. Result was FTD and 7th in PAX. Not bad I think for only 17 runs ever in the kart. _________________ Pax
Tulsa, OK |
