joe padilla
Posted: Sun Nov 25, 2001 7:20 pm Post subject: removing grip |
ok i've seen the threads to tighten up the rear of the kart, now i need ideas on how to loosen up the rear- i've already got small hubs on the rear no side bar or rear bar and the third bearing support taken out, by the way im in the supersportsman class with YDS tires, and i wanted to know how wide in the front is to wide, i have a TONYKART ESPIRIT
any thoughts on seat struts would be great also- leave them or loose them, joe |
Pete Ryan
Joined: 24 Nov 2001 Posts: 275 Location: United States, California, San francisco
Posted: Sun Nov 25, 2001 7:22 pm Post subject: removing grip |
| i am pretty sure that if you drop the rear axel it will get rid of some rear bite |
John Denman
Joined: 19 Jul 2001 Posts: 4846 Location: United States, Texas, McKinney
Posted: Sun Nov 25, 2001 8:14 pm Post subject: removing grip |
| If you are running cast aluminum wheels try some Douglas or Lansing wheels. They flex more and take some bite out. |
E EJeffries
Joined: 28 Sep 2001 Posts: 216 Location: United States, Ohio,
Posted: Mon Nov 26, 2001 4:13 am Post subject: removing grip |
Pete,
I think you'd want to raise the axle (i.e., lower the chassis) to remove grip. To remove or add front grip, the same thing can be done by adjusting the spindle height.
Lower the chassis = less grip (the inverse also holds true)
Moreover, seat placement can affect grip. The same logic applies (lower the seat = less grip).
Eric  |
Mark Dismore Jr Advertiser
Posted: Mon Nov 26, 2001 8:31 am Post subject: removing grip |
quote: Originally posted by speedmodel:
Pete,
Eric
You'd think lowering the axle would increase grip by raising the chassis but it just isn't true. You also pick up a push by raising the front of the kart (loweing the spindles).
Mark |
E EJeffries
Posted: Mon Nov 26, 2001 8:43 am Post subject: removing grip |
Mark,
As to not get Joe confused on the issue, I believe you and I are saying the same thing about the relationship between the chassis and axle height and their relative affect on grip.
Eric |
Pete Ryan
Posted: Mon Nov 26, 2001 10:19 am Post subject: removing grip |
| thats how i thought it was but my dad said lowering it would remove the grip so i just listened to what he said |
E EJeffries
Posted: Mon Nov 26, 2001 12:34 pm Post subject: removing grip |
lower chassis = less grip
Eric |
Posted: Mon Nov 26, 2001 1:55 pm Post subject: removing grip |
Eric
higher rear of chassis = less grip
higher front of chassis = less grip |
Posted: Mon Nov 26, 2001 2:00 pm Post subject: removing grip |
| If you raise the ride height you loose grip, I have tested it and I know what it does. This is what I found and that's what I believe. |
Paul Kish
Joined: 27 Jul 2001 Posts: 158 Location: United States, Ohio, Poland
Posted: Mon Nov 26, 2001 2:42 pm Post subject: removing grip |
Eric
I think it's as easy as raise the back up and you are moving some of the weight forward. Less weight on the back and you have less grip at the back. Same for the front. Move it up and you make the front have a little less weight. So you also have a little less grip.
Hope I got that right.
As long as you add weight to the tire and you are not doing something else in the process that ends up reducing grip, you will increase grip. Reduce weight from a tire and you will in general reduce grip.
Different tires though have different grip limits and charateristics on different track surfaces. As long as any weight addition to any tire does not cause the grip capabilities of a tire to be exceeded you will get more grip because as hard as you push the tire down into the track with weight the harder the track will push back. The rest is just how you make the weight push down on the track so that you can alter the way the track pushes back on the tire. |
Keith Archambeau
Joined: 18 Jul 2001 Posts: 121 Location: United States, California, Chatsworth, Ca.
Posted: Mon Nov 26, 2001 2:55 pm Post subject: removing grip |
joe p. (original poster) I bet your really confused now! speedmodel is correct.
May try moving seat forward.
Softer axel
Remove seat struts
What your looking for with a wide front is more front grip at corner exit.
RACE! |
E EJeffries
Posted: Mon Nov 26, 2001 5:10 pm Post subject: removing grip |
Joe,
There you go, a unanimous, concise answer from everyone!
Dis and I have differing opinions based upon our own experience, but, as I inferred from Paul's comment, it may indeed be due to other varibles such as chassis design, tires, etcetera. In other words, there might be two right answers.
I'd suggest trying a few of the ideas mentioned and see if you find any improvement. Try only one change at a time so you can measure the impact.
Good luck,
Eric |
Pete Ryan
Posted: Mon Nov 26, 2001 5:11 pm Post subject: removing grip |
| so my dad was right and i was wrong |
Posted: Mon Nov 26, 2001 6:08 pm Post subject: removing grip |
| All I know is what I've found in testing. Whether or not everyone agrees. When I made the changes the kart did what I said above. I know because I moved the parts and it was my butt in the seat. |
